Serviio 1.4.1.2 + Samsung UN65ES8000 Not Resuming
I'm running Serviio 1.4.1.2 on a Synology NAS, via this package: http://pcloadletter.co.uk/2012/01/25/se ... no-package. Viewing via a Samsung UN65ES8000 SmartTV.
Previously, if I would stop a file and then play it again later, it would resume where I left off; a couple of week ago I updated the Synology operating system, which in turn required me to re-install Serviio. Since then update, videos no longer resume. Serviio does seem to have correctly identified and selected the "Samsung TV / Player (E/F-series)" profile (screenshot: http://screencast.com/t/HpmAmTrJ). Unfortunately, I'm not certain which version of Serviio was installed and working previously.
Although I've found loads of other threads discussing similar issues (i.e. viewtopic.php?f=10&t=11760, viewtopic.php?f=10&t=14823, etc), I cannot seem to find a solution that gets my TV to resume videos like it used to. Is it possible that resuming has been broken in the latest update? Or do I need to somehow modify my profile?
Thanks in advance!
Thanks in advance!
