Samsung C-Series vs MKV files. Transcoding?
patanpatan
Post Wed Mar 23, 2011 2:24 am
Hi guys.
First of all, I'm a newbie :D
I'm having a problem with my Samsung C550. I can't play some of my .mkv files. Some of them play right, some others give me on the TV an error message "Unsupported Video Codec" (actually it's in spanish so the translation could be different, the original message is "Codec de Video no admitido").
I've checked a file that works and another that doesn't with ffmpeg -i. Both files throw similar information:
This one works fine:
 matroska,webm @ 013cbc10  Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/
1001) -> 23.98 (48000/2002)
Input #0, matroska,webm, from
  Duration: 00:42:52.02, start: 0.000000, bitrate: 384 kb/s
    Stream #0.0(eng): Video: h264, yuv420p, 1280x720, PAR 1:1 DAR 16:9, 23.98 fp
s, 23.98 tbr, 1k tbn, 47.95 tbc
    Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
This one doesn't:
matroska,webm @ 0037bb50 Estimating duration from bitrate, this may be inaccur
ate
  Duration: 00:43:10.14, start: 0.000000, bitrate: 448 kb/s
    Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
The only difference is the bitrate, 448 kb/s seems to be unsupported. I really don't know what's the meaning of that, but I've read the forum and I think I need transcoding. The profile is Samsung C-Series, the default installation values. How do I enable transcoding? or do I need to convert the files?
Post Wed Mar 23, 2011 12:13 pm
Re: Samsung C-Series vs MKV files. Transcoding?
Yes, some files fail to play, because of the way they are encoded. Can you post MediaInfo of the file?
patanpatan
Post Thu Mar 24, 2011 1:14 am
Hi! thanks for your reply.
Is this useful?
Unique ID                        : 236863155911076373887428805126331214456 (0xB2322F395E4773F1B9186B580F72AA78)
Complete name                    : C:\Users\patanpatan\Videos\BSG\season.2.[720p.hdtv, ac3.5.1, x264]\Battlestar.Galactica.s02e17.720p.hdtv.ac3.5.1.x264-KrAcK.mkv
Format                           : Matroska
File size                        : 1.08 GiB
Duration                         : 42mn 52s
Overall bit rate                 : 3 593 Kbps
Encoded date                     : UTC 2006-12-14 18:24:52
Writing application              : mkvmerge v1.7.0 ('What Do You Take Me For') built on Apr 28 2006 17:20:19
Writing library                  : libebml v0.7.7 + libmatroska v0.8.0
Format profile                   : High@L5.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 11 frames
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 42mn 52s
Bit rate                         : 3 205 Kbps
Width                            : 1 280 pixels
Height                           : 720 pixels
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.145
Stream size                      : 962 MiB (87%)
Writing library                  : x264 core 54 svn-598M
Encoding settings                : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=hex / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / slices=2 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=3205 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Language                         : English
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : A_AC3
Duration                         : 42mn 52s
Bit rate                         : 384 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Stream size                      : 118 MiB (11%)
Post Thu Mar 24, 2011 6:13 am
is to high and not supported, that why file doesnt play. High@L4.1 or below is required.
Post Thu Mar 24, 2011 7:56 am
Cerberus wrote:Format profile : High@L5.1 is to high and not supported, that why file doesnt play. High@L4.1 or below is required.
Two solutions:
1/ remux your file with TsMuxer tools by changing h264 profile level to 4.1.
2/ Try new 0.5.1 serviio feature : H264 profile/level is now extracted from H264 videos and transcoding matcher has been updated to support transcoding of files with certain profile/level;
Could you add these lines on the first video section on your samsung profile:
   <Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.1" />
sunnyday
Post Fri Mar 25, 2011 12:58 pm
When remuxing mkvs, pay extra attention to disable Matroska feature "Header Removal Compression".
AFAIK. none of Samsung's DLNA devices implement this feature.
http://www.bunkus.org/videotools/mkvtoo ... ompression
Samsung UE46D5005XXE | Samsung BD-C6500
Post Fri Mar 25, 2011 1:29 pm
sunnyday wrote:When remuxing mkvs, pay extra attention to disable Matroska feature "Header Removal Compression".
Yes :
viewtopic.php?f=6&t=1132#p5402
gonjeng
Post Sun Mar 27, 2011 2:32 am
FYI , you could just use H264LevelEditor to change your h264 profile level .
it is free and takes a few seconds to change h264 profile level .
Fast and easy.
Link:
http://coolsoft.altervista.org/en/h264leveleditor?curver=1.0.0
OMEN
Post Sun Mar 27, 2011 7:35 am
gonjeng, Thanks!
Sony BDV-E970W | Samsung LE-46C750R2 | Windows XP
Post Sun Mar 27, 2011 7:46 am
gonjeng wrote:FYI , you could just use H264LevelEditor to change your h264 profile level .
Fast and easy.
Link:
i will test this on monday and if it works well i will ask zip if he can add the to the FAQ page..
patanpatan
Post Sun Mar 27, 2011 11:54 pm
Thanks guys, I'll try your suggestions
___________________________________________
EDIT:
Illico, I've added the new transcoding but it didn't work.
But, using the gonjeng's solution it's working as a charm.
Thank's guys!
paulmuaddib
Post Tue Mar 29, 2011 6:32 pm
Thank you gonjeng!!!
rafaelg
Post Mon May 23, 2011 4:10 pm
I have a very similar problem like described in this topic. MKV file did not play with Samsung C/D series profile included as is in Serviio 0.5.2 version. I added this simple line as suggested somewhere, and it worked.
<Video targetContainer="mpegts" targetVCodec="mpeg2video">
<Matches container="matroska"/>
This line will transcode every MKV file that it has been found, and I think it is better to narrow a bit with the new parameters 'vCodec', profile' and 'levelGreaterThan' included in 0.5.2. Unfortunately it did not work (or I was unable find a solution):
<Matches container="matroska" profile="high" levelGreaterThan="4.1"/>
The logs follows:
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "\Users\Rafael\Videos\[AU]Black
 Lagoon Robertas Blood Trail 01[17F10B88].mkv"
686-mingw32-
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
[matroska,webm @ 003cbb30] max_analyze_duration reached
[matroska,webm @ 003cbb30] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (125703
29/262144) -> 23.98 (12570329/524288)
Input #0, matroska,webm, from '\Users\Rafael\Videos\[AU]Black Lagoon Robertas Bl
ood Trail 01[17F10B88].mkv':
  Duration: 00:34:19.28, start: 0.000000, bitrate: N/A
    Stream #0.0: Video: h264, yuv420p, 1920x1080, PAR 1:1 DAR 16:9, 23.98 fps, 2
    Stream #0.1(jpn): Audio: aac, 48000 Hz, stereo, s16
    Stream #0.2: Subtitle: ass
    Stream #0.3: Attachment: [0][0][0][0] / 0x0000
      filename        : BLUEBOLD.TTF
    Stream #0.4: Attachment: [0][0][0][0] / 0x0000
      filename        : HATTEN.TTF
Unique ID                        : 188036180506930558890834063768002245394 (0x8D7673791A9E806BA0B9F7F598343312)
Complete name                    : C:\Users\Rafael\Videos\[AU]Black Lagoon Robertas Blood Trail 01[17F10B88].mkv
Format                           : Matroska
File size                        : 790 MiB
Duration                         : 34mn 19s
Overall bit rate                 : 3 216 Kbps
Encoded date                     : UTC 2010-10-25 00:09:22
Writing application              : mkvmerge v4.1.1 ('Bouncin' Back') realizado en Jul  3 2010 22:54:08
Writing library                  : libebml v1.0.0 + libmatroska v1.0.0
Cover                            : Yes / Yes
Format settings, ReFrames        : 16 frames
Duration                         : 34mn 19s
Width                            : 1 920 pixels
Height                           : 1 088 pixels
Original height                  : 1 080 pixels
Original display aspect ratio    : 16:9
Writing library                  : x264 core 104 r1688 0b36c6d
Encoding settings                : cabac=1 / ref=16 / deblock=1:0:0 / analyse=0x3:0x113 / me=esa / subme=10 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=5 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=12 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=80 / rc=crf / mbtree=1 / crf=17.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:0.70
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format profile                   : LC
Codec ID                         : A_AAC
Duration                         : 34mn 19s
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Language                         : Japanese
Text
Format                           : SSA
Codec ID                         : S_TEXT/SSA
Codec ID/Info                    : Sub Station Alpha
Compression mode                 : Lossless
Attached the supported video and audio formats for C650 series (in case you have not at your hand)
Many thanks in advance.
Rafael
C650 series video+audio formats.pdf
C650 video + audio formats
(57.75 KiB) Downloaded 1062 times
Post Mon May 23, 2011 4:18 pm
This particular file won't play because the profile is too high (16 ref frames). Your level-based transcode config should work, could you provide detailed log of when you try to play the file?
rafaelg
Post Tue May 24, 2011 2:40 pm
Well, here is the debug-level log file. It seems the file is always played in native format, but could not find why.
Hope this helps a bit.
Cheers.
serviio log.rar
debug log
(8.51 KiB) Downloaded 846 times
Post Tue May 24, 2011 3:04 pm
H264 profile and level was probably not stored into the serviio library properly.
Could you
- Delete or rename the logging file.
- Rename the mkv file
- Restart the serviio service
- Force library update
- Check the detailed logging when file is added to the library.
EDIT : in 0.6 serviio will detect profile differently.
rafaelg
Post Tue May 24, 2011 4:37 pm
Ok, I did step-by-step your suggested list and here is the attached results. However, refreshing the library was more clear and I have found this sentence that it says all:
2011-05-24 18:21:16,709 WARN  [VideoExtractionStrategy] Couldn't resolve H264 profile/level for file 'rebel_track.mkv' because Sequence parameter set header was not recognized
So, the problem is the way that file was encoded. Too bad, :(
I read the topic about how will be detected h264 files in the next release. I really hope that will solve those damn h264 files, :)
Many thanks for your work.
Edited: Found this sentence that clarify better:
2011-05-24 18:22:08,646 DEBUG [LibraryManager] Metadata found via extractor EMBEDDED: VideoMetadata [title=rebel_track, filePath=C:\Users\Rafael\Videos\rebel_track.mkv, fileSize=827886936, audioBitrate=null, audioCodec=AAC, audioStreamIndex=1, bitrate=null, channels=2, container=MATROSKA, contentType=UNKNOWN, coverImage=org.serviio.library.metadata.ImageDescriptor@2598a35d, duration=2059, episodeNumber=null, fps=23.976, frequency=48000, h264Level=null, h264Profile=null, height=1080, seasonNumber=null, seriesName=null, timestampType=null, videoBitrate=null, videoCodec=H264, videoStreamIndex=0, width=1920]
That values seem not retrieved and not stored. So the parser don't know about h264 profile/level, right?
serviio log 2.zip
2nd log
(10.09 KiB) Downloaded 925 times
Post Tue May 24, 2011 6:39 pm
rafaelg wrote:That values seem not retrieved and not stored. So the parser don't know about h264 profile/level, right?
Right!
Thanks for your analyze.
Don't know if the h264 parameters could be fixed. Look at this tool.
rafaelg
Post Tue May 24, 2011 8:44 pm
Well, nothing to do then.
I knew those tools before posting in this thread (in fact, I was reading a lot here and there about this problem). Tried H264Level unsuccesfully (yes, i could lower the level but it doesn't work).
I will avoid to reencode every file for now.
Thanks again!
adam-bertil
Post Wed Jun 08, 2011 3:41 pm
I have a similar problem, I downloaded Band of Brothers in 1080p mkv files and 4 of 11 episodes are playable, when I try to play the other ones I get the "codec not supported message". I have a Samsung LE46C635 (LCD 6 Series) TV.
This is mediainfo from one of the files which aren't playable:
Unique ID                        : 195958560335869883158704121798780748608 (0x936C3EF4AD824851BDE36ACAED878340)
Complete name                    : G:\Downloads Film\TV\Band.Of.Brothers.2001.Blu-Ray.1080p.x264.DTS-WiKi\Band.Of.Brothers.Ep02.2001.BluRay.1080p.x264.DTS-WiKi.mkv
Format                           : Matroska
File size                        : 6.56 GiB
Duration                         : 52mn 1s
Overall bit rate                 : 18.1 Mbps
Encoded date                     : UTC 2008-12-11 03:37:10
Writing application              : mkvmerge v2.2.0 ('Turn It On Again') built on Mar  4 2008 12:58:26
Writing library                  : libebml v0.7.7 + libmatroska v0.8.1
Format settings, ReFrames        : 8 frames
Duration                         : 52mn 1s
Bit rate                         : 16.2 Mbps
Height                           : 1 080 pixels
Bits/(Pixel*Frame)               : 0.325
Stream size                      : 5.74 GiB (88%)
Writing library                  : x264 core 65 r1029M cb3c213
Encoding settings                : cabac=1 / ref=8 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=6 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=16176 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language                         : English
Audio #1
Format                           : DTS
Format/Info                      : Digital Theater Systems
Codec ID                         : A_DTS
Duration                         : 52mn 1s
Bit rate                         : 1 510 Kbps
Bit depth                        : 16 bits
Stream size                      : 562 MiB (8%)
Title                            : eng
Language                         : English
and this is mediainfo from one of the playable files:
eneral
Unique ID                        : 242101098682585717788252698943449126075 (0xB622F9BDC9B6416688A0218EE656D4BB)
Complete name                    : G:\Downloads Film\TV\Band.Of.Brothers.2001.Blu-Ray.1080p.x264.DTS-WiKi\Band.Of.Brothers.Ep01.2001.BluRay.1080p.x264.DTS-WiKi.mkv
Format                           : Matroska
Duration                         : 1h 13mn
Overall bit rate                 : 12.8 Mbps
Encoded date                     : UTC 2008-12-08 04:51:50
Format profile                   : High@L4.1
Format settings, ReFrames        : 4 frames
Duration                         : 1h 13mn
Bit rate                         : 10.9 Mbps
Bits/(Pixel*Frame)               : 0.220
Stream size                      : 5.46 GiB (83%)
Encoding settings                : cabac=1 / ref=4 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=6 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=10943 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language                         : English
Audio #1
Format                           : DTS
Codec ID                         : A_DTS
Duration                         : 1h 13mn
Bit depth                        : 16 bits
Stream size                      : 791 MiB (12%)
Title                            : eng
Language                         : English
The only difference I can see is High@L4.1 on the playable file and High@L5.1 on the file that's not playable.
I've tested a couple of solutions in this thread, H264LevelEditor, tsMuxer and adding following lines into the profiles-file in windows:
But none of the solutions have worked. I still don't really know how to use tsMuxer so maybe someone could help me out with that? Or are there any other solutions?
Thanks ;)
