Post Wed Apr 13, 2016 10:09 am
Transcoding for C6000
Hello!
how can i transcode the file below on a samsung C6000?
Complete name                            : C:\6x01 - Il Principio.avi
Format                                   : AVI
Format/Info                              : Audio Video Interleave
File size                                : 327 MiB
Duration                                 : 42mn 46s
Overall bit rate                         : 1 068 Kbps
Writing application                      : VirtualDubMod 1.5.1.1a (build 1639/release)
Writing library                          : VirtualDubMod build 1639/release
Format                                   : MPEG-4 Visual
Format settings, BVOP                    : 1
Format settings, QPel                    : No
Format settings, GMC                     : 2 warppoints
Format settings, Matrix                  : Default (H.263)
Muxing mode                              : Packed bitstream
Codec ID                                 : DX50
Codec ID/Hint                            : DivX 5
Duration                                 : 42mn 46s
Bit rate                                 : 939 Kbps
Width                                    : 480 pixels
Height                                   : 272 pixels
Frame rate                               : 25.000 fps
Bits/(Pixel*Frame)                       : 0.288
Stream size                              : 287 MiB (88%)
Writing library                          : DivX 5.0.5 (UTC 2003-04-24)
Format                                   : MPEG Audio
Format version                           : Version 1
Format profile                           : Layer 3
Mode                                     : Joint stereo
Mode extension                           : MS Stereo
Codec ID                                 : 55
Codec ID/Hint                            : MP3
Duration                                 : 42mn 46s
Bit rate                                 : 116 Kbps
Stream size                              : 35.5 MiB (11%)
Alignment                                : Aligned on interleaves
Interleave, duration                     : 24 ms (0.60 video frame)
Interleave, preload duration             : 132 ms
Thanks a lot!
