New to Serviio MKV/VP9/Opus issue
hazzanz
Post Tue Apr 25, 2017 12:59 am
Hi, I downloaded and installed this a few days ago and have successfully got it running - up to a point! ;)
Movies mostly play fine but I have a few Music Videos that I am struggling with. After a few hours of reading here (and feeling like me head is going to explode :? ) I have gathered some info to see if anyone can help me:
Serviio Server
Windows Server 2012 Standard
16GB RAM
2 TB HDD
TV's
Sony Bravia KDL-65W850A (2013/14)
Samsung UA40J5500 (J Series)
FFMPEG Results
C:\Program Files\Serviio\lib>ffmpeg.exe -i "E:\Media\Music Videos\Adele - Send M
y Love (To Your New Lover) - 1080.mkv"
ffmpeg version 3.0.2 Copyright (c) 2000-2016 the FFmpeg developers
built with gcc 4.9.3 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enab
le-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype
-lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-
os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
--bindir='/jenkins/workspace/FFmpeg - Win32/target'
libavutil 55. 17.103 / 55. 17.103
libavcodec 57. 24.102 / 57. 24.102
libavformat 57. 25.100 / 57. 25.100
libavdevice 57. 0.101 / 57. 0.101
libavfilter 6. 31.100 / 6. 31.100
libswscale 4. 0.100 / 4. 0.100
libswresample 2. 0.101 / 2. 0.101
libpostproc 54. 0.100 / 54. 0.100
Input #0, matroska,webm, from 'E:\Media\Music Videos\Adele - Send My Love (To Yo
ur New Lover) - YouTube - 1080.mkv':
COMPATIBLE_BRANDS: isomiso2avc1mp41
MAJOR_BRAND : isom
MINOR_VERSION : 512
ENCODER : IDMmkvlib0.1
LANGUAGE : und
HANDLER_NAME : AudioHandler
Duration: 00:03:45.00, start: 0.000000, bitrate: 2703 kb/s
Stream #0:0: Video: vp9 (Profile 0), yuv420p(tv, bt709/unknown/unknown), 192
0x1080, SAR 1:1 DAR 16:9, 25 fps, 25 tbr, 1k tbn, 1k tbc (default)
Stream #0:1: Audio: opus, 48000 Hz, stereo, fltp (default)
MediaInfo Results
Unique ID : 65392825175610104412735799271089255734 (0x31323334353637383930313233343536)
Complete name : \\nas\e$\Media\Music Videos\Adele - Send My Love (To Your New Lover) - 1080.MKV
Format : Matroska
File size : 72.5 MiB
Duration : 3 min 45 s
Overall bit rate : 2 704 kb/s
Writing application : IDMmkvlib0.1
Writing library : IDMmkvlib0.1
Language : und
Format : VP9
Codec ID : V_VP9
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Default : Yes
Forced : No
Format : Opus
Codec ID : A_OPUS
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Bit depth : bit0
Compression mode : Lossy
Default : Yes
Forced : No
Any help would be greatly appreciated
Cheers
Harry
Post Tue Apr 25, 2017 7:53 am
Re: New to Serviio MKV/VP9/Opus issue
can you post ffmpeg -i for the file? I'm suspecting the audio codec is not supported.
hazzanz
Post Tue Apr 25, 2017 10:20 am
Hi, is that not what I posted under the heading "FFMPEG Results"? If that is not the correct result can you please provide further guidance on how to run the command as that is the result I got as I (admittedly, very confusingly) ran the command. I was concerned about the last line "At least one output file must be specified".
Can you please check my syntax for running the command?
Cheers
Harry
hazzanz
Post Thu Apr 27, 2017 10:47 am
Hi Zip,
Any chance of any further assistance?
When I ran the FFMPEG -i command this is what I got
FFMPEG Results
MAJOR_BRAND : isom
MINOR_VERSION : 512
LANGUAGE : und
Cheers
Harry
