Sony BDP-S580 unsupported files
sam_1421
Post Tue Jan 31, 2012 7:48 am
I'm trying to make a perfect transcoding profile for my BDP-S580, so far it's pretty good, but there are still some files I can't play. So here is one of them, can you tell me what line add to the transcoding section of my profile? (the file plays perfectly on my computer)
Complete name                  : L:\Series\South Park\S06\south park 6x15.avi
Format                         : AVI
Format/Info                    : Audio Video Interleave
File size                      : 139 MiB
Duration                       : 21mn 55s
Overall bit rate               : 889 Kbps
Writing application            : VirtualDubMod 1.5.10.2 Fr | www.trad-fr.com ||  (build 2540/release)
Writing library                : VirtualDubMod build 2540/release
Format                         : MPEG-4 Visual
Format settings, BVOP          : 1
Format settings, QPel          : No
Format settings, GMC           : No warppoints
Format settings, Matrix        : Default (H.263)
Muxing mode                    : Packed bitstream
Codec ID                       : DX50
Codec ID/Hint                  : DivX 5
Duration                       : 21mn 55s
Bit rate                       : 800 Kbps
Width                          : 576 pixels
Height                         : 432 pixels
Display aspect ratio           : 4:3
Frame rate                     : 25.000 fps
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Compression mode               : Lossy
Bits/(Pixel*Frame)             : 0.129
Stream size                    : 125 MiB (90%)
Writing library                : DivX 5.1.1 (Maupiti) (UTC 2003-11-19)
Format                         : MPEG Audio
Format version                 : Version 1
Format profile                 : Layer 3
Codec ID                       : 55
Codec ID/Hint                  : MP3
Duration                       : 21mn 55s
Bit rate mode                  : Constant
Bit rate                       : 80.0 Kbps
Channel(s)                     : 2 channels
Sampling rate                  : 48.0 KHz
Delay relative to video        : 24ms
Stream size                    : 12.5 MiB (9%)
Alignment                      : Aligned on interleaves
Interleave, duration           : 40 ms (1.00 video frame)
Interleave, preload duration   : 504 ms
Thank you!
Sam
Post Tue Jan 31, 2012 8:58 am
Re: Sony BDP-S580 unsupported files
Try to change the FourCC: XVID, XVID
http://wiki.serviio.org/doku.php?id=avi4cc
sam_1421
Post Tue Jan 31, 2012 1:51 pm
Nice, it actually works, thanks! But I have plenty of these files; is there a way to tell Serviio to read these files as XVID? Or at least, do all the files in batch mode?
Thank you!
Post Tue Jan 31, 2012 3:01 pm
sam_1421 wrote:Nice, it actually works, thanks! But I have plenty of these files; is there a way to tell Serviio to read these files as XVID?
Not yet, don't know if ZIP would like.
sam_1421 wrote:Or at least, do all the files in batch mode?
Don't know...with google:
http://forum.doom9.org/archive/index.php/t-36713.html
eclp
Post Tue Jan 31, 2012 3:13 pm
sam_1421 wrote:...is there a way to tell Serviio to read these files as XVID?
Good idea!
sam_1421
Post Wed Feb 01, 2012 6:35 pm
Batch mode is possible on Linux, but I didn't find anything on Windows :/
But can't we simply add an entry in the profile to support it?
