[Readme] Sony Bravia 2014
Rewhite
Post Tue Nov 11, 2014 10:22 pm
Re: [Readme] Sony Bravia 2014
isiliadis wrote:I own the Sony bravia KDL 40W605b, I am able to stream all kind of movies with sound and very qood quality.
But I am unable to see any srt files, in Greek or in any other language.
Tried through vista also, thinking that the desktops xp was the problem, but no luck so far.
When I check the enable burned in subs option I cannot the tv set refuses to play the movie.
Any recomendations?
Hi, yeah after certain firmware update there are smooth experience with streaming but subtitles problems still existing, I suggest that problem is in our language character set (I am from Russia and we share some symbols). First check subtitle file, it must starts from 0 line, its common that .srt line start from random number and serviio don't likes it at all. Second check srt files for uncommon tags sometimes its just purely converted .ass with a lot of trash tags. If you have tHiS KiNd oF pRobLeM check this link http://forum.serviio.org/viewtopic.php?f=11&t=17290&p=92995#p92995.
If you want use .ass I have very bad news for you, looks like Serviio glitching from huge arrange of style options scripts and tags, so if file don't open, its easy to convert subs to .srt, usually it wipe all style option and then I make all file with [italic] as I describe on link but its necessary only if you had similar problem. Btw You can post .srt sample here and I can do some test with it.
rossomike1966
Post Thu Nov 13, 2014 2:42 pm
Hello everyone,
i am owner of KDL 32W705B (2014) and i selected SONY BRAVIA 2012 US profile on the Serviio Console, because with "SONY BRAVIA 2013" a lot of ".avi" file doesn't work fine (sound is good but no video.. :( ), and with this profile the situation is fine now.. :D
I'm trying to play some .mkv file but they don't play...(no sound no video)...here the details...
Generale
ID univoco                              : 267438053452552576152146643316479360472 (0xC932B20EFE77CC3B182EA96A16CFFDD8)
Nome completo                           : C:\Cartoons\Oblivion.2013.ITA.AC3.1080p.BluRay.x264-HRS.mkv
Formato                                 : Matroska
Versione formato                        : Version 2
Dimensione                              : 2,53 GiB
Durata                                  : 2o 4min
Bitrate totale                          : 2.909 Kbps
Creato con                              : HandBrake rev0
Compressore                             : libmkv 0.6.5
Formato                                 : AVC
Formato/Informazioni                    : Advanced Video Codec
Profilo formato                         : High@L4.1
Impostazioni formato, CABAC             : Si
Impostazioni formato, ReFrames          : 5 frame
ID codec                                : V_MPEG4/ISO/AVC
Bitrate                                 : 2.400 Kbps
Larghezza                               : 1.920 pixel
Altezza                                 : 804 pixel
Rapporto aspetto visualizzazione        : 2,40:1
Modalità frame rate                     : Variabile
Spazio colore                           : YUV
Croma subsampling                       : 4:2:0
Profondità bit                          : 8 bit
Tipo scansione                          : Progressivo
Compressore                             : x264 core 130 r2273 b3065e6
Impostazioni compressione               : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1,00:0,00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=2400 / ratetol=1,0 / qcomp=0,60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20,0 / qblur=0,5 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / ip_ratio=1,40 / aq=1:1,00
Lingua                                  : Inglese
Default                                 : Si
Forced                                  : No
Colori primari                          : BT.709
Caratteristiche trasferimento           : BT.709
Coefficienti matrici                    : BT.709
colour_range                            : Limited
Formato                                 : AC-3
Formato/Informazioni                    : Audio Coding 3
Estensione modo                         : CM (complete main)
Impostazioni formato, Endianness        : Big
ID codec                                : A_AC3
Durata                                  : 2o 4min
Modalità bitrate                        : Costante
Bitrate                                 : 448 Kbps
Canali                                  : 6 canali
Posizione canali                        : Front: L C R, Side: L R, LFE
Frequenza campionamento                 : 48,0 KHz
Profondità bit                          : 16 bit
Modo compressione                       : Con perdita
Dimensione della traccia                : 400MiB (15%)
Lingua                                  : Italiano
Default                                 : Si
Forced                                  : No
Testo #1
Formato                                 : PGS
ID codec                                : S_HDMV/PGS
ID codec/Informazioni                   : The same subtitle format used on BDs/HD-DVDs
Lingua                                  : Italiano
Default                                 : No
Forced                                  : No
Testo #2
Formato                                 : PGS
Lingua                                  : Inglese
Default                                 : No
Forced                                  : No
Testo #3
Formato                                 : PGS
Lingua                                  : Francese
Default                                 : No
Forced                                  : No
Menu
00:00:00.000                            : Chapter 1
00:04:31.371                            : Chapter 2
00:12:51.829                            : Chapter 3
00:21:25.301                            : Chapter 4
00:27:20.155                            : Chapter 5
00:35:30.353                            : Chapter 6
00:40:06.796                            : Chapter 7
00:46:16.040                            : Chapter 8
00:52:22.197                            : Chapter 9
01:01:59.733                            : Chapter 10
01:07:59.425                            : Chapter 11
01:16:25.848                            : Chapter 12
01:22:08.190                            : Chapter 13
01:25:31.768                            : Chapter 14
01:30:22.559                            : Chapter 15
01:36:30.384                            : Chapter 16
01:40:29.123                            : Chapter 17
01:46:27.439                            : Chapter 18
01:53:05.337                            : Chapter 19
01:58:23.863                            : Chapter 20
i have two question:
1) Why "SONY BRAVIA 2013" profile doesn't work for my TV ?
2) How can i do to play this .mkv file? (i have many file like that.. :( )
Thk
Smart TV Sony Bravia KDL-32W705B (2014)
Post Fri Nov 21, 2014 1:44 pm
rossomike1966 wrote:i am owner of KDL 32W705B (2014) and i selected SONY BRAVIA 2012 US profile on the Serviio Console, because with "SONY BRAVIA 2013" a lot of ".avi" file doesn't work fine (sound is good but no video.. :( ), and with this profile the situation is fine now.. :D
Sony Bravia 2012 US profile transcode all AVI files.
Sony Bravia 2013/2014 profile delivered some avi files in native format.
According to the codec list, your device may support avi files, but with Xvid or Motion JPEG video codec.
What is the video codec off your avi files ?
rossomike1966 wrote:I'm trying to play some .mkv file but they don't play...(no sound no video)...here the details...
This MKV/AVC/AC3 should be delivered in native format with 2013/2014 profile, there is probably something in this file that device does not support.
Do you enable subtitles on serviio console ?
Could you provide detailed logging when you start to play such files ?
I suggest to remux your mkv file with this tools.
Tools : Remux to the same container type
Remux_to_same_container type.jpg (47.21 KiB) Viewed 17516 times
Post Wed Nov 26, 2014 5:31 pm
On latest 2014 custom profile, we change mime-type order, in order to support TS containing 50fps video.
I would like to know if 2014'users that use custom 2014 profile had problems with other files format, TS containing 24fps or 30fps video?
kissmydrone
Post Fri Nov 28, 2014 3:06 pm
I'm using Sony Bravia 48W605B - today after software update of the TV - does not play web resources (like twitch.tv streams) ...
rossomike1966
Post Mon Dec 01, 2014 10:26 am
Illico wrote:On latest 2014 custom profile...
Where can i choose this profile for my SONY TV?
In my Serviio Console the newest profile is Sony Bravia Tv 2013... :?
Post Mon Dec 01, 2014 3:30 pm
I update the first post of this topic with the code you have to set on ./serviio/config/profiles.xml file.
On this latest custom profile, we change mime-type order, in order to support TS containing 50fps video and transcode MPEGTS/h264 with mp3 audio.
I would like to know if 2014'users that use this custom profile had problems with other files format, TS containing 24fps or 30fps video?
rossomike1966
Post Thu Dec 04, 2014 7:51 pm
I try to give my contribution to this new profile....
here a .avi file that does not play (only audio)
Generale
Nome completo                           : D:\Cartoons\La Casa di Topolino Stagione 1\La casa di Topolino - 02 - Una sorpresa per Minnie SatRip CRUSADERS.avi
Formato                                 : AVI
Formato/Informazioni                    : Audio Video Interleave
Dimensione                              : 225MiB
Durata                                  : 22min
Bitrate totale                          : 1.390 Kbps
Compressore                             : MPlayer
Formato                                 : MPEG-4 Visual
Profilo formato                         : Simple@L1
Impostazioni formato, BVOP              : No
Impostazioni formato, QPel              : No
Impostazioni formato, GMC               : No warppoints
Impostazioni formato, Matrix            : Default (H.263)
ID codec                                : DX50
ID codec/Suggerimento                   : DivX 5
Durata                                  : 22min
Bitrate                                 : 1.153 Kbps
Larghezza                               : 640 pixel
Altezza                                 : 480 pixel
Rapporto aspetto visualizzazione        : 4:3
Frame rate                              : 25,000 fps
Spazio colore                           : YUV
Tipo scansione                          : Interlacciato
Ordine scansione                        : Top field first
Bit/(pixel*frame)                       : 0.150
Dimensione della traccia                : 186MiB (83%)
Compressore                             : Lavc51.44.0
Formato                                 : MPEG Audio
Versione formato                        : Version 1
Profilo formato                         : Layer 3
Modo                                    : Joint stereo
Estensione modo                         : MS Stereo
ID codec                                : 55
ID codec/Suggerimento                   : MP3
Durata                                  : 22min
Bitrate                                 : 224 Kbps
Canali                                  : 2 canali
Frequenza campionamento                 : 44,1 KHz
Dimensione della traccia                : 36,2MiB (16%)
Allineamento                            : Audio allineato
Durata intervallo                       : 26 ms (0,65 frame)
 Intervallo pre caricamento             : 809 ms
Compressore                             : LAME3.97
here a .mkv file that play very well...
ID univoco                              : 245715387813295441880550442378825668648 (0xB8DB0FF41D3279969725837753999828)
Nome completo                           : D:\Cartoons\Film\Hercules.Il.Guerriero.2014.ITA.AC3.Subs.1080p.BluRay.x264-HRS\Hercules.Il.Guerriero.2014.ITA.AC3.Subs.1080p.BluRay.x264-HRS.mkv
Formato                                 : Matroska
Versione formato                        : Version 4 / Version 2
Dimensione                              : 2.62 GiB
Durata                                  : 1h 41mn
Bitrate totale                          : 3 685 Kbps
Data codifica                           : UTC 2014-11-26 19:03:06
Creato con                              : mkvmerge v7.3.0 ('Nouages') 64bit built on Oct 22 2014 18:34:02
Compressore                             : libebml v1.3.0 + libmatroska v1.4.1
Attachements                            : F1_T2_Video - .rar
TITLE                                   : Hercules.Il.Guerriero.2014.ITA.AC3.Subs.1080p.BluRay.x264-HRS
ARTIST                                  : ...:::HRS:::...
DIRECTOR                                : ...:::HRS:::...
DURATION                                : 01:33:43.992000000
NUMBER_OF_FRAMES                        : 1159
NUMBER_OF_BYTES                         : 34309
_STATISTICS_WRITING_APP                 : mkvmerge v7.3.0 ('Nouages') 64bit built on Oct 22 2014 18:34:02
_STATISTICS_WRITING_DATE_UTC            : 2014-11-26 19:03:06
_STATISTICS_TAGS                        : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Formato                                 : AVC
Impostazioni formato, CABAC             : Yes
Impostazioni formato, ReFrames          : 5 frames
Bitrate                                 : 3 300 Kbps
Larghezza                               : 1 920 pixels
Altezza                                 : 800 pixels
Rapporto aspetto visualizzazione        : 2.40:1
Modalità frame rate                     : Variable
Spazio colore                           : YUV
Profondità bit                          : 8 bits
Tipo scansione                          : Progressive
Titolo                                  : Hercules.Il.Guerriero.2014.ITA.AC3.Subs.1080p.BluRay.x264-HRS
Impostazioni compressione               : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1,00:0,00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=3300 / ratetol=1,0 / qcomp=0,60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20,0 / qblur=0,5 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / ip_ratio=1,40 / aq=1:1,00
Lingua                                  : English
Default                                 : Yes
Forced                                  : No
Formato                                 : AC-3
ID codec                                : A_AC3
Durata                                  : 1h 41mn
Modalità bitrate                        : Constant
Bitrate                                 : 384 Kbps
Canali                                  : 6 channels
Frequenza campionamento                 : 48.0 KHz
Profondità bit                          : 16 bits
Modo compressione                       : Lossy
Dimensione della traccia                : 279 MiB (10%)
Titolo                                  : ITALIANO
Lingua                                  : Italian
Default                                 : Yes
Forced                                  : No
Text #1
Formato                                 : UTF-8
ID codec                                : S_TEXT/UTF8
ID codec/Informazioni                   : UTF-8 Plain Text
Titolo                                  : SUB ITA FORCED
Lingua                                  : Italian
Default                                 : Yes
Forced                                  : Yes
Text #2
Formato                                 : UTF-8
Titolo                                  : SUB ITA
Lingua                                  : Italian
Default                                 : No
Forced                                  : No
Text #3
Formato                                 : UTF-8
Titolo                                  : SUB ENG
Lingua                                  : Italian
Default                                 : No
Forced                                  : No
Menu
00:00:00.000                            : en:...:::HRS:::...
00:08:10.814                            : en:Chapter 2
00:14:15.845                            : en:Chapter 3
00:23:38.282                            : en:Chapter 4
00:31:23.793                            : en:Chapter 5
00:41:12.188                            : en:Chapter 6
00:51:34.410                            : en:Chapter 7
00:57:31.350                            : en:Chapter 8
01:05:57.700                            : en:Chapter 9
01:16:07.935                            : en:Chapter 10
01:24:28.986                            : en:Chapter 11
01:34:24.373                            : en:Chapter 12
again..a mkv.file that does not play (not video or audio)..
Generale
ID univoco                              : 186363030335843034338383290624716475261 (0x8C3436CCF7A91EBA317232BBB23E8B7D)
Nome completo                           : D:\Cartoons\Film\V.Per.Vendetta.2005.ITA.AC3.Subs.1080p.BluRay.x264-HRS\V.Per.Vendetta.2005.ITA.AC3.Subs.1080p.BluRay.x264-HRS.mkv
Formato                                 : Matroska
Dimensione                              : 3,19 GiB
Durata                                  : 2o 12min
Bitrate totale                          : 3.448 Kbps
Data codifica                           : UTC 2014-11-12 18:04:34
TITLE                                   : V.Per.Vendetta.2005.ITA.AC3.Subs.1080p.BluRay.x264-HRS
DURATION                                : 02:11:48.025000000
NUMBER_OF_FRAMES                        : 1822
NUMBER_OF_BYTES                         : 75849
_STATISTICS_WRITING_DATE_UTC            : 2014-11-12 18:04:34
Formato                                 : AVC
Durata                                  : 2o 12min
Bitrate                                 : 3.000 Kbps
Larghezza                               : 1.918 pixel
Altezza                                 : 800 pixel
Modalità frame rate                     : Costante
Frame rate                              : 23,976 fps
Spazio colore                           : YUV
Bit/(pixel*frame)                       : 0.082
Dimensione della traccia                : 2,71 GiB (85%)
Titolo                                  : V.Per.Vendetta.2005.ITA.AC3.Subs.1080p.BluRay.x264-HRS
Impostazioni compressione               : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1,00:0,00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=3000 / ratetol=1,0 / qcomp=0,60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20,0 / qblur=0,5 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / ip_ratio=1,40 / aq=1:1,00
Lingua                                  : Inglese
Default                                 : Si
Forced                                  : No
Formato                                 : AC-3
ID codec                                : A_AC3
Durata                                  : 2o 12min
Bitrate                                 : 448 Kbps
Canali                                  : 6 canali
Dimensione della traccia                : 425MiB (13%)
Lingua                                  : Italiano
Default                                 : Si
Forced                                  : No
Testo #1
Formato                                 : UTF-8
Titolo                                  : SUB ITA
Lingua                                  : Italiano
Default                                 : No
Forced                                  : No
Testo #2
Formato                                 : UTF-8
Titolo                                  : SUB ENG
Lingua                                  : Inglese
Default                                 : No
Forced                                  : No
Menu
00:02:24.311                            : en:(02)00:02:24:310
00:09:07.881                            : en:(03)00:09:07:880
00:11:00.410                            : en:(04)00:11:00:409
00:16:26.986                            : en:(05)00:16:26:986
00:21:56.649                            : en:(06)00:21:56:648
00:25:01.500                            : en:(07)00:25:01:500
00:30:09.808                            : en:(08)00:30:09:808
00:35:37.469                            : en:(09)00:35:37:468
00:40:37.435                            : en:(10)00:40:37:435
00:43:14.258                            : en:(11)00:43:14:258
00:48:02.713                            : en:(12)00:48:02:713
00:49:40.978                            : en:(13)00:49:40:978
00:54:11.081                            : en:(14)00:54:11:081
00:56:39.563                            : en:(15)00:56:39:562
01:00:31.294                            : en:(16)01:00:31:294
01:04:47.050                            : en:(17)01:04:47:049
01:09:41.177                            : en:(18)01:09:41:177
01:12:07.490                            : en:(19)01:12:07:489
01:18:49.725                            : en:(20)01:18:49:725
01:21:13.035                            : en:(21)01:21:13:034
01:26:01.656                            : en:(22)01:26:01:656
01:29:20.689                            : en:(23)01:29:20:688
01:32:08.356                            : en:(24)01:32:08:356
01:36:21.275                            : en:(25)01:36:21:275
01:39:28.462                            : en:(26)01:39:28:462
01:44:17.585                            : en:(27)01:44:17:584
01:48:50.357                            : en:(28)01:48:50:357
01:52:03.717                            : en:(29)01:52:03:717
01:53:57.664                            : en:(30)01:53:57:664
01:57:51.564                            : en:(31)01:57:51:564
01:59:35.335                            : en:(32)01:59:35:334
02:04:38.471                            : en:(33)02:04:38:471
Dear Illico, can you help me please?
MarkyMarc43
Post Sat Dec 06, 2014 3:53 pm
I recently purchased the Sony XBR-65X850B (4K TV) and I am unable to play 4K videos from my Mac. I have changed to the profile "Sony Bravia TV (2012) US, and that allows me to view 4K still JPGs, but not MP4s.
I cannot find the /profiles/congig.xml file on my Mac, and not that it would really matter, I wouldn't know the first thing about writing a profile.
Does anyone else already have a profile that works, and can you explain how to update it?
Any help would be very appreciated.
MJC
Post Sat Dec 06, 2014 6:21 pm
It seems that 4K is not supported over DLNA according to this list
4K video have to be downscaled to 1920x1080 resolution, probably with "maxHeight" option we could do this...
Could you provide information about your 4K file ? (see signature links, ffmpeg -i, MediaInfo tool)
MarkyMarc43
Post Sat Dec 06, 2014 6:28 pm
Illico wrote:It seems that 4K is not supported over DLNA according to this list
Sort of renders the whole point of having a 4K TV useless no? I can get 2160P JPGs to display in a slideshow. Quite spectacular. I have no idea what you meant by your last comments "..info about your 4K file (see signature links..."
I'm completely new at this. Thanks for your response.
P.S. I am able to get a 4K video to play directly from a USB Thumbdrive so I suspect it is possible.
Post Sun Dec 07, 2014 9:23 am
MarkyMarc43 wrote: I have no idea what you meant by your last comments "..info about your 4K file (see signature links..." I'm completely new at this. Thanks for your response.
Sorry, I forgot signature links, see below...
MarkyMarc43 wrote:P.S. I am able to get a 4K video to play directly from a USB Thumbdrive so I suspect it is possible.
Sony devices have different features support btw USB & DLNA sources, for example external subtitles files are not supported over DLNA (suppported over USB).
We need more info about format supported.
Post Sun Dec 07, 2014 9:35 am
I found this link ( i-Manual): http://esupport.sony.com/US/p/model-hom ... manualsTab
and found Codec List for USB/DLNA : http://docs.esupport.sony.com/imanual/N ... ist.html#4
Nothing about 4K format ??!
MarkyMarc43
Post Sun Dec 07, 2014 10:02 pm
Illico wrote:I found this link ( i-Manual): http://esupport.sony.com/US/p/model-hom ... manualsTab
Thank you for those - I had seen them. I assumed the lack of mention of 4K was on Sony's part, but really? A 4K TV that doesn't support 4K content? In the interim I suppose I will have to just enjoy the native 3840 x 2160 JPG Slideshow with music through Serviio.
Thanks for the info though. Much appreciated.
Post Mon Dec 08, 2014 12:13 am
I hope the DLNA standard gets updated for 4K. I also have one now, and 4K video (I have the UHD hard drive Samsung offered) is spectacular. Now of Amazon or Netflix would just have more that 8-9 titles with it!
Of course, for 4K video, I'll have to buy more hard drives. One of those is going to take a lot of space. Although I must say that the Samsung UHD hard drive is only 1 gig, and it has ten full length movies and a large number of shorts, and it's only half full. That new H265 codec must really compress well. :o
MarkyMarc43
Post Sat Dec 13, 2014 3:55 pm
Illico wrote:UPDATED: 01/12/2014
Sony Bravia 2014
It seems that for 2014 serie, Sony replaces R470 series by R480 (KDL-32R480, KDL-40R480) and W series finished by B letter (instead of A) (W950B, the W850B, the W800B, the W630B, and the W600B)
[EDIT]26/04/2014
Compare (2013) with (2014).
It seems that there are similar, but 2013 should support High profile Level 4.2, but 2014 (W serie) are limited to Level 4.0 for AVC/H264 codec.
If you see problem when you use "Sony Bravia 2013" please post information.
[EDIT2]01/12/2014 : Ticket https://bitbucket.org/xnejp03/serviio/i ... pport-2014
This is the new custom profile for 2013 / 2014 devices :
Edit ./serviio/config/profiles.xml (after a backup) and replace the profile section id="sony2013", save and restart serviio service or reboot PC to reload new profiles.
    <Profile id="sony2013" name="Sony Bravia TV (2013)(2014)" extendsProfileId="1">
        <!-- this is WIP, should be included in the inheritance tree if possible -->
        <!-- 2013/2014 models
              Codec list supported :2013 : http://pdf.crse.com/manuals/13MW802111/EN/codeclist.html#5
              Codec list supported :2014 : http://pdf.crse.com/manuals/14HM094111/EN/codeclist.html#10
              - Still images: JPEG (*.jpg / *.jpe / *.jpeg), MPO (*.mpo), RAW (*.arw)
              - Music: LPCM, MP1L1 / MP1L2 / MP1L3 / MP2L1 / MP2L2 / MP2L3 / MP2.5L3 (*.mp3), AAC-LC / HE-AAC v1/v2 (*.mp4 / *.m4a / *.3gp / *.3g2), WMA9 (*.wma)
              - Video: MPEG1 / MPEG2PS / AVCHD , MP4, Xvid, Motion JPEG, VC1, MKV, 3gpp, MOV, WebM
        <Detection>
            <UPnPSearch>
                <FriendlyName>BRAVIA (KDL-\d{2}W[56789]\d{2}[AB].)|(KD-\d{2}X[89]\d{3}[AB].)</FriendlyName>
            </UPnPSearch>
        </Detection>
        <DeviceDescription>
            <!-- act as WMP so that the TV doesn't show root categories -->
            <ModelName>Windows Media Player Sharing</ModelName>
            <ModelNumber>3.0</ModelNumber>
            <Manufacturer>Microsoft Corporation</Manufacturer>
        </DeviceDescription>
        <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SonyDLNAMessageBuilder</ContentDirectoryMessageBuilder>
        <ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.WMPContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
        <MediaFormatProfiles>
            <!-- Rename native WMA formats to those supported by the tv -->
            <MediaFormatProfile mime-type="audio/x-ms-wma" name="WMABASE">WMA_BASE</MediaFormatProfile>
            <MediaFormatProfile mime-type="audio/x-ms-wma" name="WMAFULL">WMA_FULL</MediaFormatProfile>
            <!-- Rename 3gp profiles that can be played as AVC -->
            <MediaFormatProfile mime-type="video/mp4" name="AVC_MP4_MP_SD_AAC_MULT5">AVC_3GPP_BL_QCIF15_AAC</MediaFormatProfile>
            <!-- Rename native avi formats to those supported by the tv -->
            <MediaFormatProfile mime-type="video/avi" name="">AVI</MediaFormatProfile>
            <!-- Rename native mpeg2ts with h264+ac3/aac formats to those supported by the tv (aac support is not advertised by the renderer but it works) -->
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3,AVC_TS_HD_24_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_HD_AC3</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3,AVC_TS_HD_24_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_SD_AC3</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3,AVC_TS_HD_24_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3,AVC_TS_HD_24_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
            <!-- Rename transcoded mpeg2ts with h264 to one of the TV's supported profiles -->
            <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
        </MediaFormatProfiles>
        <H264LevelCheck>FILE_ATTRIBUTES</H264LevelCheck>
            <!-- Transcode all h264 video with HIGH/MAIN > Level 4.2 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
            <!-- expected profile MPEG_TS_SD_EU/MPEG_TS_SD_NA/MPEG_TS_SD_KO -->
            <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" DAR="16:9" forceInheritance="true">
                <Matches container="*" vCodec="h264" profile="high_10" />
                <Matches container="*" vCodec="h264" profile="high_444" />
                <Matches container="*" vCodec="h264" profile="high_422" />
                <Matches container="*" vCodec="h264" profile="high" levelGreaterThan="4.2" />
                <Matches container="*" vCodec="h264" profile="main" levelGreaterThan="4.2" />
            <!-- Remux containers with h264 video + AC3 audio to MPEG-TS stream without transcoding -->
            <!-- Remux matroska/mpeg2video + AC3 audio to MPEG-TS stream without transcoding -->
            <Video targetContainer="mpegts" forceInheritance="true">
                <Matches container="avi" vCodec="h264" aCodec="ac3" />
                <Matches container="flv" vCodec="h264" aCodec="ac3" />
                <Matches container="wtv" vCodec="h264" aCodec="ac3" />
                <Matches container="matroska" vCodec="mpeg2video" aCodec="ac3" />
            <!-- Remux all other h264 video to MPEG-TS stream with ac3 audio transcoding -->
            <!-- Remux all other matroska/mpeg2video to MPEG-TS stream with ac3 audio transcoding -->
            <Video targetContainer="mpegts" targetACodec="ac3" forceInheritance="true">
                <Matches container="mpegts" vCodec="h264" aCodec="mp3" />
                <Matches container="*" vCodec="h264" aCodec="truehd" />
                <Matches container="*" vCodec="h264" aCodec="flac" />
                <Matches container="wtv" vCodec="h264" />
            <!-- All Others video/audio codec will be transcoded into mpeg2ts, mpeg2video and ac3 audio -->
                <Matches container="mpegts" vCodec="vc1" />
                <Matches container="flv" />
                <!-- example: flv/vp6/mp3 -->
                <Matches container="wtv" />
                <Matches container="ogg" />
                <Matches container="rm" />
                <!--Matches container="3gp" vCodec="mpeg4" /-->
                <!--Matches container="3gp" vCodec="h263" /-->
                <!-- digital camera video formats -->
                <Matches container="asf" vCodec="vc1" aCodec="wmapro" />
                <Matches container="mp4" vCodec="dvvideo" />
            <Audio targetContainer="lpcm" forceInheritance="true">
                <Matches container="rtp" />
                <Matches container="rtsp" />
                <Matches container="flac" />
                <Matches container="adts" />
            </Audio>
        <HardSubsTranscoding>
            <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" DAR="16:9" />
        </HardSubsTranscoding>
How exactly does one edit the "profiles.xml" on a mac?
I can't even find that file.
Thanks,
Victorious
Post Sun Dec 28, 2014 7:47 am
I have a strange issue where I can't play .ts files which are over 90 minutes long. I can play the same files which are less than 90 minutes just fine. I have Sony Bravia 48W600B with the latest update. The issue is, the TV mediaplayer starts, shows the video's name, control buttons, the correct length of the video, but actual playback never starts and the counter stays at 0:00:00. The menu vanishes after a few seconds, leaving a black screen.
I can play .mkv 1080p files which are over 90 minutes just fine, the only issue are the MPEG2 .ts files. I tried the default profiles.xml for Sony 2013 and also 2012 as well as changing the 2013 as per Illico's post 1 of this thread but no luck. The file is Video: 720x560, data range 15,000kbps, total bitrate 15,256kbps, 25fps. Audio: bitrate 256kbps, 2 Channels, 48kHz.
Any suggestions? It is driving me crazy!
Post Sun Dec 28, 2014 11:13 am
Could you provide details of this video file (ffmpeg - i result & MediaInfo tool result)(see signature links) ?
Victorious
Post Sun Dec 28, 2014 11:28 am
Illico wrote:Could you provide details of this video file (ffmpeg - i result & MediaInfo tool result)(see signature links) ?
Thanks for qucik reply. Here it is:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\Xxxxx>cd "\Program Files (x86)\Serviio\lib"
The system cannot find the path specified.
C:\Users\Xxxxx>cd "\Program Files\Serviio\lib"
C:\Program Files\Serviio\lib>ffmpeg.exe -i "F:\z Rec\gh.ts"
[mpeg2video @ 018BB760] Invalid frame dimensions 0x0.
    Last message repeated 10 times
[mpegts @ 01E5E820] max_analyze_duration 5000000 reached at 5016000 microseconds
[mpegts @ 01E5E820] Could not find codec parameters for stream 3 (Unknown: none
([11][0][0][0] / 0x000B)): unknown codec
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[mpegts @ 01E5E820] Could not find codec parameters for stream 4 (Unknown: none
([5][0][0][0] / 0x0005)): unknown codec
[mpegts @ 01E5E820] Could not find codec parameters for stream 5 (Unknown: none
[mpegts @ 01E5E820] Could not find codec parameters for stream 6 (Unknown: none
([12][0][0][0] / 0x000C)): unknown codec
[NULL @ 018BCAE0] start time is not set in estimate_timings_from_pts
[NULL @ 018BD340] start time is not set in estimate_timings_from_pts
[NULL @ 018BDBC0] start time is not set in estimate_timings_from_pts
[NULL @ 018BE420] start time is not set in estimate_timings_from_pts
[mpegts @ 01E5E820] PES packet size mismatch
Input #0, mpegts, from 'F:\z Rec\gh.ts':
  Duration: 02:40:46.00, start: 73453.140978, bitrate: 3472 kb/s
  Program 1057
      service_name    : Nine Sydney
      service_provider: Nine Network Australia
  Program 1058
      service_name    : GEM
  Program 1059
      service_name    : GO!
    Stream #0:0[0x205]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420
p, 720x576 [SAR 64:45 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0:1[0x2bc](eng): Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stere
o, s16p, 192 kb/s
    Stream #0:2[0x245](eng): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
    Stream #0:3[0x901]: Unknown: none ([11][0][0][0] / 0x000B)
    Stream #0:4[0x321]: Unknown: none ([5][0][0][0] / 0x0005)
    Stream #0:5[0x322]: Unknown: none ([11][0][0][0] / 0x000B)
    Stream #0:6[0x323]: Unknown: none ([12][0][0][0] / 0x000C)
  Program 1060
      service_name    : EXTRA
  Program 1061
      service_name    : EXTRA 2
Victorious
Post Sun Dec 28, 2014 11:56 am
Here is also the media tool result:
Complete name                            : F:\z Rec\gh.ts
Format                                   : MPEG-TS
File size                                : 3.90 GiB
Duration                                 : 2h 40mn
Start time                               : UTC 2014-09-27 11:29:31
End time                                 : UTC 2014-09-27 14:10:15
Overall bit rate                         : 3 473 Kbps
Network name                             : Nine Network Australia
Country                                  : AUS (2) / AUS (3) / AUS (4) / AUS (5) / AUS (6) / AUS (7) / AUS (8)
Timezone                                 : +10:00:00 / +10:00:00 / +10:00:00 / +09:30:00 / +08:00:00 / +10:00:00 / +09:30:00
Menu ID                                  : 1059 (0x423)
Format                                   : MPEG Video
Format profile                           : Main@Main
Format settings, BVOP                    : Yes
Format settings, Matrix                  : Custom
Format settings, GOP                     : Variable
Format settings, picture structure       : Frame
Codec ID                                 : 2
Duration                                 : 2h 40mn
Bit rate                                 : 3 107 Kbps
Maximum bit rate                         : 15.0 Mbps
Width                                    : 720 pixels
Height                                   : 576 pixels
Frame rate                               : 25.000 fps
Standard                                 : PAL
Scan type                                : Interlaced
Scan order                               : Top Field First
Bits/(Pixel*Frame)                       : 0.300
Stream size                              : 3.49 GiB (89%)
Format                                   : MPEG Audio
Format version                           : Version 1
Format profile                           : Layer 2
Codec ID                                 : 4
Duration                                 : 2h 40mn
Bit rate                                 : 192 Kbps
Maximum bit rate                         : 201 Kbps
Delay relative to video                  : -411ms
Stream size                              : 221 MiB (6%)
Text
ID                                       : 581 (0x245)-801
Format                                   : Teletext Subtitle
Menu
List                                     : 517 (0x205) (MPEG Video) / 700 (0x2BC) (MPEG Audio, English) / 581 (0x245) () / 2305 (0x901) () / 801 (0x321) () / 802 (0x322) () / 803 (0x323) ()
Language                                 :  / English
Service name                             : GO!
Service provider                         : Nine Network Australia
Service type                             : digital television
Maximum bit rate                         : 6320000
