Post Wed Jan 04, 2017 10:57 am
.mov via Serviio doesnt play at Sony 2016 TV (generic dlna)
First of all: A happy and a peacefull new year to everybody!
I'm using Servio since 3 weeks and i'm totally happy with it. Congrats to the developers!
Nevertheless i have a little problem:
I got a lot of mov Files, i think there are from a small panasonic camera. Whatever: they play very well on my Sony TV when i "feed" them directly via USB. And they also (!) play very well, when i access the video via a network share directly from my Sony TV.
But: They DON't play, when Serviio is serving them via network, regardless which Serviio Profile i'm using. That means, it doesn't play via Serviio even with the Generic DLNA profile! The TV always reports that the file format is not supported.
It seems, that Serviio is changing something with the .mov Files, so that my Sony can't play them.
The facts:
Serviio V 1.8, Generic DLNA Profile, wired connectivity via ethernet, Sony Bravia LCD KD-43XD8077 from the XD80 2016 Line (it's a variant of the broader known KD-43XD8005; in the US the model is called XBR43X800D from the X800D product line). Serviio is running on Windows Server 2008 R2 (which is a Windows Home Server 2011).
Mediainfo output:
Complete name                            : T:\testvideo\testvideo.MOV
Format profile                           : QuickTime
Codec ID                                 : qt   2007.09.04 (qt  /pana)
File size                                : 65.1 MiB
Duration                                 : 20 s 0 ms
Overall bit rate                         : 27.3 Mb/s
Encoded date                             : UTC 2011-10-01 20:04:32
Tagged date                              : UTC 2011-10-01 20:04:32
Writing library                          : pana
Format                                   : JPEG
Codec ID                                 : jpeg
Bit rate                                 : 26.8 Mb/s
Frame rate                               : 30.000 FPS
Bits/(Pixel*Frame)                       : 0.970
Stream size                              : 63.9 MiB (98%)
Format                                   : PCM
Format settings, Sign                    : Signed
Codec ID                                 : twos
Bit rate                                 : 512 kb/s
Sampling rate                            : 16.0 kHz
Stream size                              : 1.22 MiB (2%)
FFMPEG output:
ffmpeg version 3.0.2 Copyright (c) 2000-2016 the FFmpeg developers
  built with gcc 4.9.3 (GCC)
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtmp --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enable-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config --bindir='/jenkins/workspace/FFmpeg - Win32/target'
  libavutil      55. 17.103 / 55. 17.103
  libavcodec     57. 24.102 / 57. 24.102
  libavformat    57. 25.100 / 57. 25.100
  libavdevice    57.  0.101 / 57.  0.101
  libavfilter     6. 31.100 /  6. 31.100
  libswscale      4.  0.100 /  4.  0.100
  libswresample   2.  0.101 /  2.  0.101
  libpostproc    54.  0.100 / 54.  0.100
[mjpeg @ 00a98760] Changing bps to 8
Guessed Channel Layout for  Input Stream #0.1 : stereo
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'D:\ServerFolders\Transfer\testvideo\testvideo.mov':
    major_brand     : qt
    minor_version   : 537331972
    compatible_brands: qt  pana
    creation_time   : 2011-10-01 20:04:32
  Duration: 00:00:20.00, start: 0.000000, bitrate: 27324 kb/s
    Stream #0:0(eng): Video: mjpeg (jpeg / 0x6765706A), yuvj420p(pc, bt470bg/unknown/unknown), 1280x720, 26810 kb/s, 30 fps, 30 tbr, 30 tbn, 30 tbc (default)
      encoder         : Photo - JPEG
    Stream #0:1(eng): Audio: pcm_s16be (twos / 0x736F7774), 16000 Hz, 2 channels, s16, 512 kb/s (default)
Any help to this situation is highly welcome, 'cause most of my videos are .mov videos. Thank you very much!
