Sony BDP-Sx100 (2013) do not play online sources
My BluRay (Sony BDP-Sx70/SMP-N100 (2010)) plays normally files recorded in the service folder, but do not play online sources. Does anyone have any tips?
SERVIO.LOG:
SERVIO.LOG:
- Code:
java.io.IOException: Read end dead
at java.io.PipedInputStream.checkStateForReceive(PipedInputStream.java:262)
at java.io.PipedInputStream.receive(PipedInputStream.java:226)
at java.io.PipedOutputStream.write(PipedOutputStream.java:149)
at org.serviio.external.io.PipedOutputStreamMultiplexer$3.call(PipedOutputStreamMultiplexer.java:87)
at org.serviio.external.io.PipedOutputStreamMultiplexer$MultiplexCaller.multiplex(PipedOutputStreamMultiplexer.java:119)
at org.serviio.external.io.PipedOutputStreamMultiplexer.write(PipedOutputStreamMultiplexer.java:89)
at org.serviio.external.io.PipedOutputBytesReader.processOutput(PipedOutputBytesReader.java:58)
at org.serviio.external.io.OutputReader.run(OutputReader.java:47)
2019-08-14 02:06:06,388 DEBUG [PipedOutputStreamMultiplexer] Removing client from multiplexer: Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV
2019-08-14 02:06:06,401 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true": AVC_TS_MP_HD_AAC_MULT5_ISO
2019-08-14 02:06:06,401 DEBUG [VideoDeliveryEngine] Delivering file 'https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true' using transcoding (profile: bdp2013 > quality: ORIGINAL > OnlineTranscoding > [MPEG2TS] > matcher: 1)
2019-08-14 02:06:06,401 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2019-08-14 02:06:06,401 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2019-08-14 02:06:06,401 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,Date: Wed, 14 Aug 2019 05:06:06 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows_10 UPnP/1.0 DLNADOC/1.50 Serviio/2.0,transferMode.dlna.org: Streaming]]
2019-08-14 02:06:08,630 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:13,627 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:16,464 DEBUG [SearchManager] Committing search index
2019-08-14 02:06:18,630 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:23,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:28,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:33,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:34,523 DEBUG [RendererSearchSender] Searching for Renderer devices
2019-08-14 02:06:34,523 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface eth3 (Intel(R) Ethernet Connection (7) I219-V) and address 192.168.1.103, timeout = 0
2019-08-14 02:06:34,523 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2019-08-14 02:06:34,523 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.103:61752s
2019-08-14 02:06:34,524 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-08-14 02:06:34,524 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.103:61752s
2019-08-14 02:06:35,424 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.102:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-08-14 02:06:35,424 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:06:35,424 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:06:35,430 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:36,700 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2019-08-14 02:06:36,700 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2019-08-14 02:06:36,700 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 81)
2019-08-14 02:06:37,061 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.102:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-08-14 02:06:37,061 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:06:37,061 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:06:37,066 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:37,349 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.102:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-08-14 02:06:37,349 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:06:37,349 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:06:37,353 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:38,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:40,523 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2019-08-14 02:06:43,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:46,465 DEBUG [SearchManager] Committing search index
2019-08-14 02:06:48,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:53,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:57,961 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Intel(R) Ethernet Connection (7) I219-V) and address 192.168.1.103, timeout = 0
2019-08-14 02:06:57,962 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device d5d83c03-42e3-377d-afa7-8f5cd9997f2a
2019-08-14 02:06:58,569 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51507: GET /deviceDescription/d5d83c03-42e3-377d-afa7-8f5cd9997f2a HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]]
2019-08-14 02:06:58,569 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,569 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,570 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device d5d83c03-42e3-377d-afa7-8f5cd9997f2a from 192.168.1.102 (headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";])
2019-08-14 02:06:58,570 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,570 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,570 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]
2019-08-14 02:06:58,571 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,573 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony BDP-Sx100 (2013)'
2019-08-14 02:06:58,583 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51508: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]]
2019-08-14 02:06:58,584 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,584 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,584 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2019-08-14 02:06:58,586 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2019-08-14 02:06:58,595 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51509: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]]
2019-08-14 02:06:58,595 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,596 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,596 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2019-08-14 02:06:58,599 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2019-08-14 02:06:58,611 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51510: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";,Host: 192.168.1.103:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 280,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"]]
2019-08-14 02:06:58,612 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,612 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,612 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.102
2019-08-14 02:06:58,613 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,613 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:58,654 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2019-08-14 02:06:58,659 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51511: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";,Host: 192.168.1.103:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 273,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"]]
2019-08-14 02:06:58,659 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,659 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,659 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.1.102
2019-08-14 02:06:58,660 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,660 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,701 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony BDP-Sx100 (2013)'
2019-08-14 02:06:58,707 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2019-08-14 02:06:58,774 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51512: GET /deviceDescription/d5d83c03-42e3-377d-afa7-8f5cd9997f2a HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]]
2019-08-14 02:06:58,774 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,775 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,775 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device d5d83c03-42e3-377d-afa7-8f5cd9997f2a from 192.168.1.102 (headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";])
2019-08-14 02:06:58,775 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,775 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]
2019-08-14 02:06:58,776 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,776 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,776 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony BDP-Sx100 (2013)'
2019-08-14 02:06:58,784 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51513: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]]
2019-08-14 02:06:58,784 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,784 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,786 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2019-08-14 02:06:58,786 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2019-08-14 02:06:58,793 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51514: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]]
2019-08-14 02:06:58,793 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,794 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,794 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2019-08-14 02:06:58,794 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2019-08-14 02:06:58,805 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51515: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";,Host: 192.168.1.103:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 280,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"]]
2019-08-14 02:06:58,805 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,805 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,806 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.102
2019-08-14 02:06:58,806 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,806 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,848 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2019-08-14 02:06:58,851 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51516: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";,Host: 192.168.1.103:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 273,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"]]
2019-08-14 02:06:58,852 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,852 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,852 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.1.102
2019-08-14 02:06:58,853 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,853 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,894 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony BDP-Sx100 (2013)'
2019-08-14 02:06:58,897 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2019-08-14 02:06:58,965 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51517: GET /deviceDescription/d5d83c03-42e3-377d-afa7-8f5cd9997f2a HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]]
2019-08-14 02:06:58,965 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,965 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,966 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device d5d83c03-42e3-377d-afa7-8f5cd9997f2a from 192.168.1.102 (headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";])
2019-08-14 02:06:58,966 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,966 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,966 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]
2019-08-14 02:06:58,967 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,967 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony BDP-Sx100 (2013)'
2019-08-14 02:06:58,977 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51518: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:57 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]]
2019-08-14 02:06:58,977 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,977 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,978 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2019-08-14 02:06:58,981 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2019-08-14 02:06:58,989 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51519: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:57 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]]
2019-08-14 02:06:58,989 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,989 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,989 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2019-08-14 02:06:58,989 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2019-08-14 02:06:59,002 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51520: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";,Host: 192.168.1.103:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 280,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"]]
2019-08-14 02:06:59,002 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:59,002 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:59,002 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.102
2019-08-14 02:06:59,003 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:59,003 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:59,045 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2019-08-14 02:06:59,048 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51521: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";,Host: 192.168.1.103:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 273,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"]]
2019-08-14 02:06:59,048 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:59,049 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:59,049 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.1.102
2019-08-14 02:06:59,049 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:59,050 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:59,091 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony BDP-Sx100 (2013)'
2019-08-14 02:06:59,093 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2019-08-14 02:06:59,775 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:40 (advertisement duration is 1800 sec.)
2019-08-14 02:07:02,498 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:07:02,498 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:07:02,512 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:07:02,737 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:07:02,737 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:07:02,742 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:07:03,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:06,404 DEBUG [TimeoutStreamDelegator] Closing piped input stream and closing related feeder process
2019-08-14 02:07:06,404 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-128,5,main]
2019-08-14 02:07:06,407 DEBUG [ProcessUtils] Killing the Windows process: 10920
2019-08-14 02:07:06,417 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2019-08-14 02:07:06,417 DEBUG [AbstractAVTranscodingDeliveryEngine] Removing transcoding job 'transcoding-temp-f53802657f8243a7d86a6910b7b61720.stf' of client 'Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV'
2019-08-14 02:07:08,423 DEBUG [WebServer] I/O error: Pipe broken
2019-08-14 02:07:08,426 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51532: GET /resource/1000000810001992/MEDIA_ITEM/AVC_TS_MP_HD_AAC_MULT5_ISO-0/ORIGINAL HTTP/1.1, headers = [User-Agent: UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.103:8895,Accept: */*,X-AV-Physical-Unit-Info: pa="BLU-RAY HOME THEATRE SYSTEM",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BLU-RAY HOME THEATRE SYSTEM"; mv="2.0",getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming]]
2019-08-14 02:07:08,426 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:07:08,426 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:07:08,427 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:07:08,427 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:07:08,427 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV'
2019-08-14 02:07:08,427 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000810001992 and type 'MEDIA_ITEM' received
2019-08-14 02:07:08,428 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000810001992 (online)
2019-08-14 02:07:08,428 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 81)
2019-08-14 02:07:08,428 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000810001992, format AVC_TS_MP_HD_AAC_MULT5_ISO and profile Sony BDP-Sx100 (2013)
2019-08-14 02:07:08,428 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true
2019-08-14 02:07:08,428 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true": AVC_TS_MP_HD_AAC_MULT5_ISO
2019-08-14 02:07:08,428 DEBUG [VideoDeliveryEngine] Delivering item '1000000810001992' for client 'Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV'
2019-08-14 02:07:08,429 DEBUG [AbstractAVTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV'
2019-08-14 02:07:08,429 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true
2019-08-14 02:07:08,429 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib\ffmpeg.exe -fflags +genpts -threads 0 -analyzeduration 10000000 -i https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true -y -threads 0 -c:v copy -bsf:v h264_mp4toannexb -c:a:0 copy -map 0:0 -map 0:1 -sn -f mpegts pipe:
2019-08-14 02:07:08,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:08,929 DEBUG [StreamBasedTranscodingDeliveryStrategy] Adding client to stream multiplexer: Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV
2019-08-14 02:07:11,933 DEBUG [StreamBasedTranscodingDeliveryStrategy] Already multiplexing stream output to client: Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV
2019-08-14 02:07:11,933 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true": AVC_TS_MP_HD_AAC_MULT5_ISO
2019-08-14 02:07:11,933 DEBUG [VideoDeliveryEngine] Delivering file 'https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true' using transcoding (profile: bdp2013 > quality: ORIGINAL > OnlineTranscoding > [MPEG2TS] > matcher: 1)
2019-08-14 02:07:11,933 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2019-08-14 02:07:11,933 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2019-08-14 02:07:11,933 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,Date: Wed, 14 Aug 2019 05:07:11 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows_10 UPnP/1.0 DLNADOC/1.50 Serviio/2.0,transferMode.dlna.org: Streaming]]
2019-08-14 02:07:11,935 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2019-08-14 02:07:11,935 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2019-08-14 02:07:12,936 DEBUG [PipedOutputStreamMultiplexer] Caught exception: Read end dead
2019-08-14 02:07:12,936 DEBUG [PipedOutputStreamMultiplexer] Removing client from multiplexer: Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV
2019-08-14 02:07:13,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:16,467 DEBUG [SearchManager] Committing search index
2019-08-14 02:07:16,828 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51533: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";,Host: 192.168.1.103:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 598,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2019-08-14 02:07:16,828 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:07:16,829 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:07:16,829 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.102
2019-08-14 02:07:16,829 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:07:16,830 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:07:16,872 DEBUG [ContentDirectory] Browse() called for renderer BDV (profile bdp2013) with parameters: objectID = V_OF, browseFlag = BrowseDirectChildren, filter = av:mediaClass,dc:title,dc:date,@childCount,upnp:class,res,res@resolution,res@size,res@protocolInfo,res@duration,res@bitrate,av:containerClass,res@dlna:ifoFileURI, startIndex = 1, count = 10, sortCriteria =
2019-08-14 02:07:16,872 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [alfredo]
2019-08-14 02:07:16,873 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [alfredo]
2019-08-14 02:07:16,874 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [alfredo]
2019-08-14 02:07:16,874 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [alfredo]
2019-08-14 02:07:16,876 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2019-08-14 02:07:18,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:23,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:28,627 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:31,937 DEBUG [TimeoutStreamDelegator] Closing piped input stream and closing related feeder process
2019-08-14 02:07:31,937 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-148,5,main]
2019-08-14 02:07:31,937 DEBUG [ProcessUtils] Killing the Windows process: 7628
2019-08-14 02:07:31,948 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2019-08-14 02:07:31,948 DEBUG [AbstractAVTranscodingDeliveryEngine] Removing transcoding job 'transcoding-temp-f53802657f8243a7d86a6910b7b61720.stf' of client 'Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV'
2019-08-14 02:07:33,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:34,669 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.103:56073s
2019-08-14 02:07:34,669 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dslforum-org:device:InternetGatewayDevice:1 from address /192.168.1.103:56073s
2019-08-14 02:07:34,669 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-08-14 02:07:34,669 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.103:56073s
2019-08-14 02:07:34,670 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.103:56073
2019-08-14 02:07:35,671 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.103:56073s
2019-08-14 02:07:35,671 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-08-14 02:07:35,671 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dslforum-org:device:InternetGatewayDevice:1 from address /192.168.1.103:56073s
2019-08-14 02:07:35,671 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.103:56073s
2019-08-14 02:07:35,671 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.103:56073
2019-08-14 02:07:36,674 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.103:56073s
2019-08-14 02:07:36,674 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-08-14 02:07:36,674 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dslforum-org:device:InternetGatewayDevice:1 from address /192.168.1.103:56073s
2019-08-14 02:07:36,674 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.103:56073s
2019-08-14 02:07:36,675 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.103:56073
2019-08-14 02:07:36,701 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2019-08-14 02:07:36,701 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2019-08-14 02:07:36,701 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 81)
2019-08-14 02:07:38,627 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:40,571 DEBUG [RendererSearchSender] Searching for Renderer devices
2019-08-14 02:07:40,572 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface eth3 (Intel(R) Ethernet Connection (7) I219-V) and address 192.168.1.103, timeout = 0
2019-08-14 02:07:40,572 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2019-08-14 02:07:40,572 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.103:49258s
2019-08-14 02:07:40,572 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-08-14 02:07:41,262 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.102:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-08-14 02:07:41,262 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:07:41,262 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:07:41,267 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:07:43,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:43,854 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.102:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-08-14 02:07:43,854 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:07:43,854 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:07:43,858 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:07:43,972 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.102:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-08-14 02:07:43,972 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:07:43,972 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:07:43,977 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:07:46,468 DEBUG [SearchManager] Committing search index
2019-08-14 02:07:46,572 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2019-08-14 02:07:48,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:53,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:58,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:02,391 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.1.103:62218s
2019-08-14 02:08:02,392 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-08-14 02:08:02,496 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:08:02,496 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:08:02,503 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:08:02,731 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:08:02,731 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:08:02,736 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:08:03,392 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.1.103:62218s
2019-08-14 02:08:03,392 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-08-14 02:08:03,630 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:04,394 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.1.103:62218s
2019-08-14 02:08:04,394 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-08-14 02:08:05,395 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.1.103:62218s
2019-08-14 02:08:05,395 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-08-14 02:08:08,627 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:13,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:16,470 DEBUG [SearchManager] Committing search index
2019-08-14 02:08:18,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:23,627 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:28,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:33,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:36,361 DEBUG [PlaylistDAOImpl] Reading all Playlists
2019-08-14 02:08:36,702 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2019-08-14 02:08:36,702 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2019-08-14 02:08:36,702 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 81)
2019-08-14 02:08:38,630 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:43,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:45,841 DEBUG [ActionsServerResource] Action with name 'stopServer' was requested
2019-08-14 02:08:45,841 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2019-08-14 02:08:45,841 DEBUG [AbstractAVTranscodingDeliveryEngine] Deleting temporary transcoded files from: D:\Vídeos\Temp-Serviio\Serviio
2019-08-14 02:08:45,841 DEBUG [DiscoveryManager] UPNP device d5d83c03-42e3-377d-afa7-8f5cd9997f2a (192.168.1.103) is unavailable
2019-08-14 02:08:45,841 DEBUG [WebServer] Socket closed
2019-08-14 02:08:45,841 DEBUG [WebServer] Marking the web server for exit
2019-08-14 02:08:45,841 INFO [WebServer] WebServer shutting down
2019-08-14 02:08:45,841 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2019-08-14 02:08:45,841 DEBUG [DiscoverySSDPMessageListener] Socket closed: socket closed
2019-08-14 02:08:45,841 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2019-08-14 02:08:45,841 INFO [EventDispatcher] Leaving EventDispatcher
2019-08-14 02:08:45,841 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2019-08-14 02:08:45,891 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface eth3 (Intel(R) Ethernet Connection (7) I219-V) and address 192.168.1.103, timeout = 0
2019-08-14 02:08:46,358 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2019-08-14 02:08:46,472 DEBUG [SearchManager] Committing search index
2019-08-14 02:08:46,618 DEBUG [RendererSearchSender] Searching for Renderer devices
2019-08-14 02:08:46,618 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface eth3 (Intel(R) Ethernet Connection (7) I219-V) and address 192.168.1.103, timeout = 0
2019-08-14 02:08:46,618 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2019-08-14 02:08:47,834 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.102:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-08-14 02:08:47,834 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:08:47,834 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:08:47,838 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:08:48,071 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.102:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-08-14 02:08:48,071 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:08:48,071 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:08:48,076 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:08:48,505 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.102:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-08-14 02:08:48,505 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:08:48,505 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:08:48,510 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:08:48,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:52,618 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2019-08-14 02:08:53,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:58,425 DEBUG [PipeManager] Stopped PipeProcessingConsumer
2019-08-14 02:08:58,526 DEBUG [PipeManager] Stopped PipeProcessingConsumer
2019-08-14 02:08:58,526 INFO [LibraryOneTimeScanner] Interrupting library scan
2019-08-14 02:08:58,526 DEBUG [LibraryOneTimeScanner] Library scan has been interrupted
2019-08-14 02:08:58,526 INFO [LibraryDeltaScanner] Stopping the library delta scan
2019-08-14 02:08:58,526 DEBUG [FileDeltaPoller] Stopping FileDeltaPoller
2019-08-14 02:08:58,528 DEBUG [FileDeltaWatcher] Stopping FileDeltaWatcher
2019-08-14 02:08:58,528 INFO [PlaylistMaintainerWorker] Finished looking for playlist changes
2019-08-14 02:08:58,629 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Finished checking repositories status
2019-08-14 02:08:58,629 INFO [FeedUpdaterWorker] Finished looking for online resources information
2019-08-14 02:08:58,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:58,729 INFO [PluginCompilerThread] Finished looking for plugins
2019-08-14 02:08:58,832 INFO [SearchIndexer] Closing search index writer
2019-08-14 02:08:58,834 INFO [SearchIndexer] Closing search index writer
2019-08-14 02:08:58,855 INFO [PlaybackEventsManager] Playback of media item 1000000810001992 (https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true [https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true]) has stopped at 0% on Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV
2019-08-14 02:08:58,855 INFO [RendererSearchSender] Stopping Renderer searcher process
2019-08-14 02:08:58,856 INFO [DatabaseManager] Shutting down database
2019-08-14 02:08:58,856 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2019-08-14 02:08:58,887 WARN [DatabaseManager] DB shutdown returned: Derby system shutdown.
2019-08-14 02:08:58,888 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2019-08-14 02:08:58,888 DEBUG [AbstractAVTranscodingDeliveryEngine] Deleting temporary transcoded files from: D:\Vídeos\Temp-Serviio\Serviio
