LG 32LE550 (My TV turn off when I put playlist m3u
I have a problem when i want to see a stream video. I've copied plugins and i've done all. But I don't know why my TV turn off when I played playlist.
I write:
http://-SW-ufile:///D:/CarpetaServiio/m ... -SW-tVIDEO I thin is right!
Then I go my TV, I see the list but...then turn off.
I saw the log and...
Someone can help me?
Thanks!
I write:
- Code:
2013-12-28 10:24:08,899 WARN [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2013-12-28 10:24:10,536 WARN [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2013-12-28 10:24:32,397 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://50.23.65.36/live playpath=xtremmmmmmmmmmmmmm?id=189855 swfUrl=http://mips.tv/content/scripts/eplayer.swf live=1 pageUrl=http://mips.tv/ Conn=S:OK --live. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:320)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:237)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:116)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:454)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:97)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:135)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:299)
... 2 more
2013-12-28 10:24:33,072 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://50.7.69.234/edge playpath=l886gblcix3g7rt swfUrl=http://cdn.ilive.to/player/player_ilive_2.swf live=1 pageUrl=http://www.ilive.to/ token=KUHD8273kljDG. It might not play.
... 2 more
2013-12-28 10:24:33,800 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://streaming.freelivetv.tv/live playpath=foxxx62175064af5d201ae8851697f6297d9d swfUrl=http://freelivetv.tv/embed/noreproductor.php?o=1&kpublica=11944 live=1 pageUrl=http://freelivetv.tv/. It might not play.
... 2 more
2013-12-28 10:24:34,482 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://50.7.69.138/edge playpath=qf6d3hdupyv0s2d swfUrl=http://cdn.ilive.to/player/player_ilive_2.swf live=1 pageUrl=http://www.ilive.to/ token=KUHD8273kljDG. It might not play.
... 2 more
2013-12-28 10:24:35,155 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://50.7.69.186/edge playpath=lhz1koxd78ok7it swfUrl=http://cdn.ilive.to/player/player_ilive_2.swf live=1 pageUrl=http://www.ilive.to/ token=KUHD8273kljDG. It might not play.
... 2 more
2013-12-28 10:24:39,140 WARN [EventDispatcher] Error 412 received from event subscriber
2013-12-28 10:24:40,400 WARN [EventDispatcher] Error 412 received from event subscriber
2013-12-28 10:25:00,751 WARN [ContentDirectory] Object with id V_M/Gravity doesn't exist
2013-12-28 10:25:02,011 WARN [ContentDirectory] Object with id V_M/Gravity doesn't exist
2013-12-28 10:25:15,699 WARN [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2013-12-28 10:25:16,577 WARN [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
Thanks!
