Post Sat Feb 14, 2015 9:17 am
42LS5600 Profile
My Tv: http://www.lg.com/uk/tvs/lg-42LS5600-led-tv
Hi guys. I'm a newbie about these media servers and transcoding stuff. I tried to use Plex, Wild Media Server, Kodi, but none of them worked fine for me. Yesterday, i've installed Serviio. It's the better one for me. I played some of my movies with Serviio, they worked fine. When i use Generic Profile, my tv could play its native codecs and detect subtitles. Later, i tried LG Profile. It was worse then Generic Profile, because tv couldn't even play some videos that work in Generic Profile and also isn't able to detect subtitles. After that, i tried PS3 profile. With this profile, tv was able to play movies with dts. But while i'm using ps3 profile, some movies could not even start to play. Somehow, tv does not support some movies in this profile. Also, tv didn't detect the external subtitles.
In the profiles i tried, none of them were able to play this video:
Unique ID                   : 173838057218571007230409589689024837836 (0x82C7FDF2DE6DD711B6FAD1105334F8CC)
Complete name               : F:\Downloads\Superbad.2007.720p.BluRay.x264-HaB\Superbad.2007.720p.BluRay.x264-HaB.mkv
Format                      : Matroska
Format version              : Version 2
File size                   : 5.37 GiB
Duration                    : 1h 58mn
Overall bit rate mode       : Variable
Overall bit rate            : 6 476 Kbps
Movie name                  : Superbad
Encoded date                : UTC 2011-08-27 09:07:59
Writing application         : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
Writing library             : libebml v1.2.1 + libmatroska v1.1.1
Format                      : AVC
Format/Info                 : Advanced Video Codec
Format profile              : High@L4.1
Format settings, CABAC      : Yes
Format settings, ReFrames   : 9 frames
Codec ID                    : V_MPEG4/ISO/AVC
Duration                    : 1h 58mn
Bit rate                    : 5 628 Kbps
Width                       : 1 280 pixels
Height                      : 694 pixels
Display aspect ratio        : 1.85:1
Frame rate mode             : Constant
Frame rate                  : 23.976 fps
Color space                 : YUV
Chroma subsampling          : 4:2:0
Bit depth                   : 8 bits
Scan type                   : Progressive
Bits/(Pixel*Frame)          : 0.264
Stream size                 : 4.66 GiB (87%)
Writing library             : x264 core 116 r2074 2641b9e
Encoding settings           : cabac=1 / ref=9 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=11 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=96 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=10 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=80 / rc=crf / mbtree=1 / crf=18.1 / qcomp=0.75 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=2:1.00
Language                    : English
Default                     : Yes
This is the mediainfo of the movie with dts. My TV can natively play this video without any sound. It can't play any dts. I was able to watch this movie with dts when i used ps3 profile.
Complete name               : F:\Downloads\The.Inbetweeners.2.2014.720p.BluRay.X264-AMIABLE\The.Inbetweeners.2.2014.720p.BluRay.X264-AMIABLE.mkv
Format                      : Matroska
File size                   : 4.37 GiB
Duration                    : 1h 32mn
Overall bit rate            : 6 802 Kbps
Writing application         : mkvmerge v6.6.0 ('The Edge Of The In Between') built on Dec 1 2013 17:55:00
Writing library             : libebml v1.3.0 + libmatroska v1.4.1
Format                      : AVC
Format settings, ReFrames   : 5 frames
Duration                    : 1h 32mn
Bit rate                    : 5 291 Kbps
Height                      : 536 pixels
Display aspect ratio        : 2.40:1
Frame rate                  : 25.000 fps
Color space                 : YUV
Bit depth                   : 8 bits
Bits/(Pixel*Frame)          : 0.308
Stream size                 : 3.31 GiB (76%)
Writing library             : x264 core 142 r2491 24e4fed
Encoding settings           : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=5291 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 /
So, i need a profile based on these problems. I've tried to make some changes on profiles, but it didn't work. I need your help.
