Post Sat Feb 06, 2016 10:51 am
ISO files
Can't find help in previous toppics and support section so here's my problem:
I use an LG Portable Theater DP1W attached to my television together with Serviio running on my PC.
LG portable Theater sees all the files I share Serviio consloe except for "ISO" files.
Any idea what can be the problem?
** When I mount the same ISO-file by using a USB-stick directly into the LG Portable Theater it is recognized. **
Thanks in advance.
M.K.
