LG 37LS5600 - MKV NO SOUND ISSUE
Hello, I just set up Serviio Server on my computer however I'm having problems with some .mkv files. Some of them don't play sound on my TV. I searched the forum and found some solutions such as changing the .mkv file's h264 level to 4.1 and removing transcoding section from LG TV's profile. But these solutions didn't fix my problem, I'm still unable receive sound using these files.
My current profile :
I'm using Serviio 1.6.1. MediaInfo of some of the files :
MediaInfo :
- Code:
<Profile id="8" name="LG TV / player" extendsProfileId="1">
<Detection>
<HttpHeaders>
<friendlyName.dlna.org>LG.*</friendlyName.dlna.org>
</HttpHeaders>
</Detection>
<!-- ResourceTransportProtocolHandler>org.serviio.upnp.protocol.http.transport.LGProtocolHandler</ResourceTransportProtocolHandler -->
<MediaFormatProfiles>
<MediaFormatProfile mime-type="video/mp4" name="">AVI</MediaFormatProfile>
</MediaFormatProfiles>
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" >
<Matches container="flv" />
<Matches container="asf" vCodec="wmv2"/>
<Matches container="rm" />
<Subtitles>
<SoftSubs mime-type="text/srt" />
</Subtitles>
MediaInfo :
- Code:
Unique ID : 232972889304129656375440184174099249204 (0xAF44F2459316ADB6A09E5463236B3834)
Complete name : F:\Filmler\Batman Series\Batman Begins\Batman.Begins.2005.720p.BluRay.DTS.x264-ESiR [PublicHD].mkv
Format : Matroska
Format version : Version 1
File size : 6.55 GiB
Duration : 2 h 20 min
Overall bit rate : 6 697 kb/s
Movie name : Batman.Begins.2005.720p.BluRay.DTS.x264-ESiR
Encoded date : UTC 2008-11-28 21:43:24
Writing application : mkvmerge v2.4.0 ('Fumbling Towards Ecstasy') built on Oct 11 2008 20:13:15
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Attachments : CronosPro-Bold.ttf / CronosPro-Semibold.ttf / CronosPro-SemiboldIt.ttf / times.ttf / timesbd.ttf
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 5 180 kb/s
Width : 1 280 pixels
Height : 536 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.315
Stream size : 4.94 GiB (75%)
Title : Batman Begins
Writing library : x264 core 65 r1016M dbc5ef0
Encoding settings : cabac=1 / ref=8 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=9 / psy_rd=0.8:0.6 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=5180 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=30 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.70
Language : English
Default : Yes
Forced : No
Format : DTS
Mode : 16
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 1 510 kb/s
Channel(s) : 6 channels
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 spf)
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : 150 ms
Stream size : 1.48 GiB (23%)
Title : DTS 5.1 @ 1.5 Mbps
Language : English
Default : Yes
Forced : No
Text #1
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Language : English
Default : Yes
Forced : No
- Code:
Unique ID : 223058811130073827192563659469137528150 (0xA7CF907AA644935E87D55D3E331A4556)
Complete name : F:\Filmler\Lord of The Rings\1 - Fellowship Of The Ring\Fellowship Of The Ring.mkv
Format : Matroska
File size : 25.7 GiB
Duration : 3 h 28 min
Overall bit rate : 17.7 Mb/s
Encoded date : UTC 2009-03-23 15:46:12
Writing application : mkvmerge v2.5.3 ('Boogie') built on Mar 7 2009 15:00:41
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=18
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Bit rate : 16.6 Mb/s
Maximum bit rate : 17.0 Mb/s
Width : 1 920 pixels
Height : 1 088 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.331
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
GOP, Open/Closed of first f : Closed
Stream size : 24.1 GiB (94%)
Title : The Fellowship Of The Ring
Writing library : TMPGEnc 2.58.44.152
Language : English
Default : Yes
Forced : No
Color primaries : BT.601 PAL
Transfer characteristics : BT.470 System B, BT.470 System G
Matrix coefficients : FCC 73.682
Format : DTS
Mode : 16
Codec ID : A_DTS
Bit rate : 755 kb/s
Bit depth : 24 bits
Stream size : 1.10 GiB (4%)
Language : English
Default : Yes
Forced : No
