LG 49UB850V - Profile for MKV HEVC 4K
OctavianH
Post Tue Jan 16, 2018 6:37 pm
Hello all,
Has anyone managed to play via DLNA a 4k mkv file encoded via HEVC? This seems to work only via USB, but normally with a proper profile should work via serviio.
Thanks in advance!
OctavianH
Post Thu Jan 18, 2018 8:03 am
Re: LG 49UB850V - Profile for MKV HEVC 4K
No one? :)
Post Fri Jan 19, 2018 11:23 am
Please post MediaInfo for the file
What profile are you currently using?
Panasonic Viera CS610A | Panasonic Viera V20A | Sony PS4 | Sony PS3 | Panasonic DMP-BD79 | Yamaha RX-V500D | iPad | Windows 10 | Serviio 1.9 Pro
OctavianH
Post Sun Jan 21, 2018 4:08 pm
First of all, thanks for the reply. Now the information:
MediaInfo of the file is:
Unique ID : 217965287305763989768422560859471244364 (0xA3FA965D9CCE8633A5F7F8EF23E46C4C)
Complete name : Z:\Video\4K\The Siege of Jadotville (2016) 2160p Netflix WEB-DL DD5.1 HEVC-TrollUHD.mkv
Format : Matroska
File size : 12.2 GiB
Duration : 1 h 48 min
Overall bit rate : 16.1 Mb/s
Encoded date : UTC 2017-09-05 00:53:27
Writing application : mkvmerge v8.3.0 ('Over the Horizon') 64bit
Writing library : libebml v1.3.1 + libmatroska v1.4.2
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 15.7 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.079
Stream size : 11.9 GiB (98%)
Title : English
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Matrix coefficients : BT.709
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 6 channels
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 298 MiB (2%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 40 s 375 ms
Bit rate : 109 b/s
Count of elements : 13
Stream size : 554 Bytes (0%)
Title : Forced
Language : English
Default : Yes
Forced : Yes
Text #2
Format : UTF-8
Duration : 1 h 46 min
Bit rate : 49 b/s
Count of elements : 1337
Stream size : 38.8 KiB (0%)
Title : SDH
Language : English
Default : No
Forced : No
Text #3
Format : UTF-8
Duration : 1 h 42 min
Bit rate : 77 b/s
Count of elements : 1138
Stream size : 58.1 KiB (0%)
Language : Arabic
Default : No
Forced : No
Text #4
Format : UTF-8
Bit rate : 41 b/s
Count of elements : 925
Stream size : 31.0 KiB (0%)
Language : Danish
Default : No
Forced : No
Text #5
Format : UTF-8
Bit rate : 45 b/s
Count of elements : 1005
Stream size : 33.9 KiB (0%)
Language : German
Default : No
Forced : No
Text #6
Format : UTF-8
Bit rate : 41 b/s
Count of elements : 1133
Stream size : 31.3 KiB (0%)
Language : Spanish
Default : No
Forced : No
Text #7
Format : UTF-8
Bit rate : 38 b/s
Count of elements : 1143
Stream size : 29.2 KiB (0%)
Language : Spanish
Default : No
Forced : No
Text #8
Format : UTF-8
Bit rate : 38 b/s
Count of elements : 820
Stream size : 28.9 KiB (0%)
Language : Finnish
Default : No
Forced : No
Text #9
Format : UTF-8
Bit rate : 43 b/s
Count of elements : 1110
Stream size : 32.3 KiB (0%)
Language : French
Default : No
Forced : No
Text #10
Format : UTF-8
Bit rate : 71 b/s
Count of elements : 1099
Stream size : 53.5 KiB (0%)
Language : Hebrew
Default : No
Forced : No
Text #11
Format : UTF-8
Bit rate : 42 b/s
Count of elements : 1147
Stream size : 31.9 KiB (0%)
Language : Italian
Default : No
Forced : No
Text #12
Format : UTF-8
Bit rate : 36 b/s
Count of elements : 1023
Stream size : 27.0 KiB (0%)
Language : Japanese
Default : No
Forced : No
Text #13
Format : UTF-8
Bit rate : 44 b/s
Count of elements : 1152
Stream size : 33.2 KiB (0%)
Language : Korean
Default : No
Forced : No
Text #14
Format : UTF-8
Bit rate : 41 b/s
Count of elements : 932
Stream size : 31.4 KiB (0%)
Language : Norwegian Bokmal
Default : No
Forced : No
Text #15
Format : UTF-8
Bit rate : 40 b/s
Count of elements : 860
Stream size : 30.3 KiB (0%)
Language : Dutch
Default : No
Forced : No
Text #16
Format : UTF-8
Bit rate : 34 b/s
Count of elements : 1122
Stream size : 25.7 KiB (0%)
Language : Polish
Default : No
Forced : No
Text #17
Format : UTF-8
Bit rate : 43 b/s
Stream size : 32.5 KiB (0%)
Language : Portuguese
Default : No
Forced : No
Text #18
Format : UTF-8
Bit rate : 41 b/s
Stream size : 30.9 KiB (0%)
Title : Brazilian
Default : No
Forced : No
Text #19
Format : UTF-8
Bit rate : 42 b/s
Count of elements : 857
Stream size : 31.6 KiB (0%)
Language : Swedish
Default : No
Forced : No
Text #20
Format : UTF-8
Bit rate : 45 b/s
Count of elements : 1086
Stream size : 34.3 KiB (0%)
Language : Turkish
Default : No
Forced : No
Text #21
Format : UTF-8
Bit rate : 41 b/s
Count of elements : 1153
Title : Simplified
Language : Chinese
Default : No
Forced : No
Text #22
Format : UTF-8
Bit rate : 42 b/s
Title : Traditional
Language : Chinese
Default : No
Forced : No
The Serviio version is 1.9 and the profile used is "LG TV / player". I have several files which are not recognized via DLNA but work fine via USB.
Post Mon Jan 22, 2018 10:29 am
The LG profile doesn't do much by default - it doesn't transcode anything.
To vary the profile to transcode your HEVC videos, try the following:
  • Edit the file config\profiles.xml using your favourite text editor (Notepad++ recommended)
  • find the line
    </MediaFormatProfiles>
    in the "LG TV / player" profile.
  • Add the following below that line
          <!-- Transcode all h265 video -->
          <Video targetContainer="mpegts" targetVCodec="mpeg2video maxHeight="1080"  targetACodec="ac3" aBitrate="384" DAR="16:9" >
                <Matches container="*" vCodec="h265"/>
  • Save the file
  • Restart your PC
If it doesn't work, try it without the maxHeight="1080" and let me know. You may also need to make this number smaller (eg. 720) for other files (if the aspect ratio is > 16:9). After each change save and restart.
If still not working revert the changes and let me know. You will need to make this change every time Serviio is upgraded.
Other files that are not being played may need to be added to the transcode block. Note that this will transcode ALL HEVC videos. Your PC must have the power to do this in real time (becomes a factor particularly with 4K video). If you only need to transcode HEVC 4K video (and not all HEVC) let me know - not sure it can be done, but we may be able to think of a work around.
OctavianH
Post Mon Jan 22, 2018 11:05 am
I will try this, but maybe I am understanding something wrong. I thought transcoding was needed only for a TV with a different resolution which does not decode HW the HEVC.
So basicly transcoding of this file will re-encode it in realtime with another Video and Audio codecs. This TV is 4K (3840x2160), same resolution as the file, and decodes HW via USB the HEVC.
So why I need transcoding?
Regarding the power of the PC, it is a HP MicroServer Gen8 upgraded to a Xeon 1265L V2 (quad core with HT) so I do not think the transcoding is a problem, what I do not understand is why I need it.
Thanks a lot in advance!
Post Tue Jan 23, 2018 3:35 am
It is a common misconception - just because the file plays by USB doesn't mean it will play via DLNA. Seems TV designers often have two different apps/sub systems - one for direct play via USB vs one for DLNA.
To complicate matters, DLNA pre-dates MKV files (there is no allowance for MKV in the DLNA spec). To overcome this, in the absence of transcoding, Serviio simply pushes any MKV directly to your TV. Given this, if Serviio is simply pushing the file to your TV as-is, and your TV cannot play it, it follows that your TV cannot support that file at that resolution over DLNA.
Hence your only option (other than playing via USB) is to transcode the file to something your TV will accept over DLNA.
Hope that makes sense....
OctavianH
Post Tue Jan 23, 2018 7:58 am
Thanks a lot for explanation, I was not aware of all these limitations. So your comment is very useful to me to understand the situation.
My purpose is to preserve the 4k resolution and audio quality of the file. The transcoding will alter it in any way? Because otherwise, I can stick to USB and leave it as it is...
Return to LG
