MKV and LG 47LE5500 - Invalid File
When I try to play some MKV files I always get the "Invalid file" error. No idea why. Here is the info from MediaInfo and ffmpeg:
Here is complete log... there are some numbersformatexceptions for some other movie that plays fine, but no reference to the MKV movie (was testing on Wolverine.mkv)
- Code:
2011-10-31 09:12:05,392 ERROR [ActionNode] Cannot retrieve results of action command: Cannot execute library command for single item: For input string: "111/AttacktheBlock.avi"
org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for single item: For input string: "111/AttacktheBlock.avi"
at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItem(AbstractCommand.java:136)
at org.serviio.upnp.service.contentdirectory.definition.ActionNode.executeRetrieveItemAction(ActionNode.java:175)
at org.serviio.upnp.service.contentdirectory.definition.ActionNode.retrieveDirectoryObject(ActionNode.java:80)
at org.serviio.upnp.service.contentdirectory.ContentDirectory.Browse(ContentDirectory.java:199)
at sun.reflect.GeneratedMethodAccessor9.invoke(Unknown Source)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeOperation(ServiceInvoker.java:253)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeService(ServiceInvoker.java:93)
at org.serviio.upnp.webserver.ServiceControlRequestHandler.handleRequest(ServiceControlRequestHandler.java:74)
Caused by: java.lang.NumberFormatException: For input string: "111/AttacktheBlock.avi"
at java.lang.NumberFormatException.forInputString(Unknown Source)
at java.lang.Long.parseLong(Unknown Source)
at org.serviio.upnp.service.contentdirectory.command.AbstractListObjectsByFSHierarchyCommand.getFolderId(AbstractListObjectsByFSHierarchyCommand.java:211)
at org.serviio.upnp.service.contentdirectory.command.AbstractListObjectsByFSHierarchyCommand.retrieveSingleItem(AbstractListObjectsByFSHierarchyCommand.java:153)
at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItem(AbstractCommand.java:131)
... 14 more
2011-10-31 09:12:05,406 DEBUG [CompositeCache] get: key = V_F#FOL_R1$F111/AttacktheBlock.avi:BrowseMetadata:@id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency:0:0::8, localOnly = false
2011-10-31 09:12:05,406 DEBUG [LRUMemoryCache] getting item from cache local_default for key V_F#FOL_R1$F111/AttacktheBlock.avi:BrowseMetadata:@id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency:0:0::8
2011-10-31 09:12:05,406 DEBUG [LRUMemoryCache] local_default: LRUMemoryCache miss for V_F#FOL_R1$F111/AttacktheBlock.avi:BrowseMetadata:@id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency:0:0::8
2011-10-31 09:12:05,406 DEBUG [LRUMemoryCache] verifycache[local_default]: mapContains 10 elements, linked list contains 10 elements
2011-10-31 09:12:05,406 DEBUG [LRUMemoryCache] verifycache: checking linked list by key
2011-10-31 09:12:05,406 DEBUG [DoubleLinkedList] returning first node
2011-10-31 09:12:05,406 DEBUG [LRUMemoryCache] verifycache: checking linked list by value
2011-10-31 09:12:05,406 DEBUG [LRUMemoryCache] verifycache: checking via keysets!
2011-10-31 09:12:05,406 DEBUG [CompositeCache] local_default - Miss
2011-10-31 09:12:05,407 ERROR [ActionNode] Cannot retrieve results of action command: Cannot execute library command for single item: For input string: "111/AttacktheBlock.avi"
... 14 more
2011-10-31 09:12:08,508 DEBUG [CompositeCache] get: key = V_F#FOL_R1$F66:BrowseMetadata:upnp:class:0:0::8, localOnly = false
2011-10-31 09:12:08,508 DEBUG [LRUMemoryCache] getting item from cache local_default for key V_F#FOL_R1$F66:BrowseMetadata:upnp:class:0:0::8
2011-10-31 09:12:08,508 DEBUG [LRUMemoryCache] local_default: LRUMemoryCache miss for V_F#FOL_R1$F66:BrowseMetadata:upnp:class:0:0::8
2011-10-31 09:12:08,508 DEBUG [LRUMemoryCache] verifycache[local_default]: mapContains 10 elements, linked list contains 10 elements
2011-10-31 09:12:08,508 DEBUG [LRUMemoryCache] verifycache: checking linked list by key
2011-10-31 09:12:08,508 DEBUG [DoubleLinkedList] returning first node
2011-10-31 09:12:08,508 DEBUG [LRUMemoryCache] verifycache: checking linked list by value
2011-10-31 09:12:08,508 DEBUG [LRUMemoryCache] verifycache: checking via keysets!
2011-10-31 09:12:08,508 DEBUG [CompositeCache] local_default - Miss
2011-10-31 09:12:08,509 DEBUG [CompositeCache] Updating memory cache
2011-10-31 09:12:08,509 DEBUG [DoubleLinkedList] returning first node
2011-10-31 09:12:08,509 DEBUG [CompositeCache] No auxilliary cache to update
2011-10-31 09:12:08,524 DEBUG [CompositeCache] get: key = V_F#FOL_R1$F66:BrowseDirectChildren:upnp:class:0:100::8, localOnly = false
2011-10-31 09:12:08,524 DEBUG [LRUMemoryCache] getting item from cache local_default for key V_F#FOL_R1$F66:BrowseDirectChildren:upnp:class:0:100::8
2011-10-31 09:12:08,524 DEBUG [LRUMemoryCache] local_default: LRUMemoryCache miss for V_F#FOL_R1$F66:BrowseDirectChildren:upnp:class:0:100::8
2011-10-31 09:12:08,524 DEBUG [LRUMemoryCache] verifycache[local_default]: mapContains 11 elements, linked list contains 11 elements
2011-10-31 09:12:08,524 DEBUG [LRUMemoryCache] verifycache: checking linked list by key
2011-10-31 09:12:08,524 DEBUG [DoubleLinkedList] returning first node
2011-10-31 09:12:08,524 DEBUG [LRUMemoryCache] verifycache: checking linked list by value
2011-10-31 09:12:08,524 DEBUG [LRUMemoryCache] verifycache: checking via keysets!
2011-10-31 09:12:08,524 DEBUG [CompositeCache] local_default - Miss
2011-10-31 09:12:08,529 DEBUG [CompositeCache] Updating memory cache
2011-10-31 09:12:08,529 DEBUG [DoubleLinkedList] returning first node
2011-10-31 09:12:08,529 DEBUG [CompositeCache] No auxilliary cache to update
2011-10-31 09:12:08,550 DEBUG [CompositeCache] get: key = V_F#FOL_R1$F66:BrowseDirectChildren:@id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency:0:54::8, localOnly = false
2011-10-31 09:12:08,550 DEBUG [LRUMemoryCache] getting item from cache local_default for key V_F#FOL_R1$F66:BrowseDirectChildren:@id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency:0:54::8
2011-10-31 09:12:08,550 DEBUG [LRUMemoryCache] local_default: LRUMemoryCache miss for V_F#FOL_R1$F66:BrowseDirectChildren:@id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency:0:54::8
2011-10-31 09:12:08,550 DEBUG [LRUMemoryCache] verifycache[local_default]: mapContains 12 elements, linked list contains 12 elements
2011-10-31 09:12:08,551 DEBUG [LRUMemoryCache] verifycache: checking linked list by key
2011-10-31 09:12:08,551 DEBUG [DoubleLinkedList] returning first node
2011-10-31 09:12:08,551 DEBUG [LRUMemoryCache] verifycache: checking linked list by value
2011-10-31 09:12:08,551 DEBUG [LRUMemoryCache] verifycache: checking via keysets!
2011-10-31 09:12:08,551 DEBUG [CompositeCache] local_default - Miss
2011-10-31 09:12:08,556 DEBUG [CompositeCache] Updating memory cache
2011-10-31 09:12:08,556 DEBUG [DoubleLinkedList] returning first node
2011-10-31 09:12:08,556 DEBUG [CompositeCache] No auxilliary cache to update
2011-10-31 09:12:08,586 DEBUG [CompositeCache] get: key = V_F#FOL_R1$F66:BrowseDirectChildren:@id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency:0:54::8, localOnly = false
2011-10-31 09:12:08,586 DEBUG [LRUMemoryCache] getting item from cache local_default for key V_F#FOL_R1$F66:BrowseDirectChildren:@id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency:0:54::8
2011-10-31 09:12:08,586 DEBUG [LRUMemoryCache] local_default: LRUMemoryCache hit for V_F#FOL_R1$F66:BrowseDirectChildren:@id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency:0:54::8
2011-10-31 09:12:08,586 DEBUG [LRUMemoryCache] verifycache[local_default]: mapContains 13 elements, linked list contains 13 elements
2011-10-31 09:12:08,586 DEBUG [LRUMemoryCache] verifycache: checking linked list by key
2011-10-31 09:12:08,586 DEBUG [DoubleLinkedList] returning first node
2011-10-31 09:12:08,586 DEBUG [LRUMemoryCache] verifycache: checking linked list by value
2011-10-31 09:12:08,586 DEBUG [LRUMemoryCache] verifycache: checking via keysets!
2011-10-31 09:12:08,586 DEBUG [CompositeCache] local_default - Memory cache hit
2011-10-31 09:12:10,451 DEBUG [ShrinkerThread] Shrinking memory cache for: thumbnails
2011-10-31 09:12:10,451 DEBUG [ShrinkerThread] Keys size: 0
2011-10-31 09:12:10,451 DEBUG [ShrinkerThread] Shrinking memory cache for: online_feeds
2011-10-31 09:12:13,308 DEBUG [CompositeCache] get: key = V_F#FOL_R1$F66:BrowseDirectChildren:@id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency:0:54::8, localOnly = false
2011-10-31 09:12:13,308 DEBUG [LRUMemoryCache] getting item from cache local_default for key V_F#FOL_R1$F66:BrowseDirectChildren:@id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency:0:54::8
2011-10-31 09:12:13,308 DEBUG [LRUMemoryCache] local_default: LRUMemoryCache hit for V_F#FOL_R1$F66:BrowseDirectChildren:@id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency:0:54::8
2011-10-31 09:12:13,309 DEBUG [LRUMemoryCache] verifycache[local_default]: mapContains 13 elements, linked list contains 13 elements
2011-10-31 09:12:13,309 DEBUG [LRUMemoryCache] verifycache: checking linked list by key
2011-10-31 09:12:13,309 DEBUG [DoubleLinkedList] returning first node
2011-10-31 09:12:13,309 DEBUG [LRUMemoryCache] verifycache: checking linked list by value
2011-10-31 09:12:13,309 DEBUG [LRUMemoryCache] verifycache: checking via keysets!
2011-10-31 09:12:13,309 DEBUG [CompositeCache] local_default - Memory cache hit
2011-10-31 09:12:13,339 DEBUG [CompositeCache] Removed All keys from the memory cache.
2011-10-31 09:12:13,400 DEBUG [CompositeCache] Removed All keys from the memory cache.
2011-10-31 09:12:27,976 DEBUG [CompositeCache] get: key = V_F#FOL_R1$F66:BrowseDirectChildren:@id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency:0:54::8, localOnly = false
2011-10-31 09:12:27,976 DEBUG [LRUMemoryCache] getting item from cache local_default for key V_F#FOL_R1$F66:BrowseDirectChildren:@id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency:0:54::8
2011-10-31 09:12:27,976 DEBUG [LRUMemoryCache] local_default: LRUMemoryCache hit for V_F#FOL_R1$F66:BrowseDirectChildren:@id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency:0:54::8
2011-10-31 09:12:27,976 DEBUG [LRUMemoryCache] verifycache[local_default]: mapContains 13 elements, linked list contains 13 elements
2011-10-31 09:12:27,976 DEBUG [LRUMemoryCache] verifycache: checking linked list by key
2011-10-31 09:12:27,976 DEBUG [DoubleLinkedList] returning first node
2011-10-31 09:12:27,976 DEBUG [LRUMemoryCache] verifycache: checking linked list by value
2011-10-31 09:12:27,976 DEBUG [LRUMemoryCache] verifycache: checking via keysets!
2011-10-31 09:12:27,976 DEBUG [CompositeCache] local_default - Memory cache hit
2011-10-31 09:12:28,507 DEBUG [CompositeCache] Removed All keys from the memory cache.
2011-10-31 09:12:28,508 DEBUG [CompositeCache] Removed All keys from the memory cache.
2011-10-31 09:12:40,452 DEBUG [ShrinkerThread] Shrinking memory cache for: thumbnails
2011-10-31 09:12:40,452 DEBUG [ShrinkerThread] Keys size: 0
2011-10-31 09:12:40,452 DEBUG [ShrinkerThread] Shrinking memory cache for: online_feeds
I tried to play it with LG TV profile as well as with Generic DLNA profile. Same result.
Any ideas? :S
