panasonic SC-BTT490 blu-ray player
rghinnaples
Post Sun Feb 16, 2014 2:22 pm
Once I pause a movie, I cannot restart it. Controls show up, they respond to the remote, but no response to the action.
Cannot fast forward. Can stop playback, but cannot start again.
In summary, movies can be selected to play, will play all the way through without problems. Once paused, stopped, fast forward, play -- nothing works even though
control on screen shows proper response to the remote, nothing happens. Movie just stops and that's it.
Any suggestions?
Quaddy1
Post Mon Mar 24, 2014 10:08 am
Re: panasonic SC-BTT490 blu-ray player
Same here on Panasonic DMP-BDT220.
Funny thing is, a couple of updates ago, it was working fine, but with v 1.4.1.2 it is back to how you describe it.
Post Tue Apr 01, 2014 11:29 am
Post MediaInfo details for the offending files - see viewtopic.php?f=5&t=1123
Try turning transcoding off and seeing if they then play properly.
Return to Panasonic
