Post Sun Aug 31, 2014 7:22 pm
ST30 transcoding question
With all the different inhertances that are part of the ST30 profile, I can't quite follow it the following video would be transcoded. I have doubts that this old of a TV will play this without any sort of transcoding, but I'd like to make it the minimum amount necessary.
I found a new Blu-Ray ripper that outputs the movie to M2TS, leaving all audio and text tracks intact. I'd like to fine tune the profile to fit these files:
Complete name                            : \\SERVER\Video_4\Star Wars Episode IV - A New Hope (1977).m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 38.7 GiB
Duration                                 : 2h 2mn
Overall bit rate                         : 45.3 Mbps
Maximum Overall bit rate                 : 48.0 Mbps
Menu ID                                  : 1 (0x1)
Codec ID                                 : 27
Duration                                 : 2h 2mn
Maximum bit rate                         : 36.8 Mbps
Height                                   : 1 080 pixels
Audio #1
Menu ID                                  : 1 (0x1)
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Format profile                           : MA / Core
Mode                                     : 16
Muxing mode                              : Stream extension
Codec ID                                 : 134
Duration                                 : 2h 2mn
Bit rate                                 : Unknown / 1 509 Kbps
Channel(s)                               : 7 channels / 6 channels
Channel positions                        : Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE
Bit depth                                : 24 bits
Compression mode                         : Lossless / Lossy
Audio #2
Menu ID                                  : 1 (0x1)
Codec ID                                 : 129
Duration                                 : 2h 2mn
Bit rate                                 : 448 Kbps
Stream size                              : 392 MiB (1%)
Audio #3
Menu ID                                  : 1 (0x1)
Codec ID                                 : 129
Duration                                 : 2h 2mn
Bit rate                                 : 448 Kbps
Audio #4
Menu ID                                  : 1 (0x1)
Format                                   : DTS
Mode                                     : 16
Codec ID                                 : 130
Duration                                 : 2h 2mn
Bit rate                                 : 768 Kbps
Bit depth                                : 24 bits
Stream size                              : 672 MiB (2%)
Audio #5
Menu ID                                  : 1 (0x1)
Codec ID                                 : 129
Duration                                 : 2h 2mn
Bit rate                                 : 448 Kbps
Audio #6
Menu ID                                  : 1 (0x1)
Codec ID                                 : 129
Duration                                 : 2h 2mn
Bit rate                                 : 224 Kbps
Stream size                              : 196 MiB (0%)
Audio #7
Menu ID                                  : 1 (0x1)
Codec ID                                 : 129
Duration                                 : 2h 2mn
Bit rate                                 : 224 Kbps
Text #1
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Duration                                 : 2h 2mn
Delay relative to video                  : 1s 1ms
Text #2
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Duration                                 : 2h 2mn
