Newly modified profile will no longer play particular file
Frankie15
Post Sun Feb 08, 2015 11:46 pm
Hello all,
I have recently altered my profile to play .mp4 and .avi files in their correct OAR. They were originally stretched. It fixed my issues, but I found one video that will no longer play. It worked fine before I changed my profile to add DAR 16:9 options. It works fine if I change the profile to generic. Here is the output when I run the ffmpeg -i command. Any help would be appreciated to get this running properly on my newly modified profile:
Thanks all!
Post Mon Feb 09, 2015 1:44 pm
Re: Newly modified profile will no longer play particular fi
Could you also provide the same info for a file that plays? Then we can look for differences.
Panasonic ST30 Plasma, Samsung JU7100 4K TV, Sony BDP-S3500, Sharp 4K Roku TV, Insignia Roku TV, Roku 4, Ultra and Stick, Yamaha RX-V583 AVR.
Primary server: Intel i5-6400, 8 gig ram, Windows 10 Pro, 18 TB hard drive space | Test server Windows 7 Home Premium, AMD Phenom II X4 965, 8 gig ram
Frankie15
Post Mon Feb 09, 2015 3:33 pm
Here is the info for a movie that does play. Thanks!
Frankie15
Post Fri Feb 13, 2015 1:48 am
<Profile id="viera2011a" name="Panasonic Viera G/GT/DT/UT/VT (2011/2012)" extendsProfileId="viera2013">
      <!-- Panasonic Viera G30, GT30, DT30, UT30 With avi (2011), xx50 (2012)  With AVI Support -->
      <Detection>
         <UPnPSearch>
            <FriendlyName>(VIERA (G|D|U)T?(3|5)0?.*)|(VIERA VT50.*)</FriendlyName>
            <Manufacturer>Panasonic</Manufacturer>
         </UPnPSearch>
      </Detection>
         <!-- remux VORBIS/FLAC/LPCM in MKV/MP4 to AC3 -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" DAR="16:9" forceInheritance="true">
The video will play as soon as I remove DAR="16:9" from that last line. The OAR is incorrect as it is stretching, but the video plays. It won't play once I change this back to include DAR="16:9". None of my other MP4 files have this issue. They will all play fine with the correct OAR when I add the DAR="16:9". Is it because the movie I am trying to watch has an even wider aspect ratio? (2.35:1 compared to 1.85:1)? Might be grasping at straws, but that's all that stands out to me.
Post Fri Feb 13, 2015 8:12 am
The SAR/DAR look strange in the first file. Try remuxing the file and see if the helps - to remux the file use the command:
ffmpeg -i "D:\Media\Movies\Into the Wild.mp4" -c copy -map 0 "D:\Media\Movies\Into the Wild - Test.mp4"
Panasonic Viera FX800A | Panasonic Viera CS610A | Sony PS4 | Sony PS3 | Panasonic DMP-BD79 | Yamaha RX-V500D | iPad | Windows 10 | Serviio 1.10 Pro
Frankie15
Post Mon Feb 16, 2015 3:50 am
Didn't work unfortunately. I get to "Please wait a moment" and the screen goes black and then that message prompt comes on again which is just like before. Thanks for responding though! Any other ideas? Appreciate your help.
Return to Panasonic
