Select from multiple external subtitles while playing
pcakl
Post Fri Aug 21, 2015 10:56 pm
is there any way how to select/change between the multiple external subtitle files (different languages) while playing the movie ? I only have an option to switch them on/off and select the encoding. But not the language/file.
I am using:
Serviio 1.5.2
Panasonic AS640
Panasonic Viera (2013) profile
Regards,
Pavel
Post Sun Aug 23, 2015 7:54 am
Re: Select from multiple external subtitles while playing
Are the files named correctly - see http://www.serviio.org/component/conten ... es-support and then set your prefered language in the console.
Panasonic Viera FX800A | Panasonic Viera CS610A | Sony PS4 | Sony PS3 | Panasonic DMP-BD79 | Yamaha RX-V500D | iPad | Windows 10 | Serviio 1.10 Pro
Return to Panasonic
