serviio connection to the server failed
numero41
Post Mon Nov 30, 2015 11:27 am
I am using Serviio for several years now and greatly appreciate its features.
I did several changes this weekend, reinstalled a new computer with windows 10, and changed my connection to the tv. It was previously connected via a cpl plug, and is now directly connected via ethernet cable on a switch (on which is my computer too).
My problem is :
on my tv I can see Serviio icon, and folders, but each time I try to go inside a folder I get this message : "serviio connection to the server failed"
I tried to disable my firewall / antivirus with no effect.
On windows, file sharing is enbled, and network discovery too.
Thanks a lot for your help
David
numero41
Post Mon Nov 30, 2015 8:38 pm
Re: serviio connection to the server failed
problem solved...
I uninstalled/reinstalled serviio and everything works!
Return to Panasonic
