Panasonic TX-48AX630 MKV PLay Back Problems
Hi Guy's
need a bit of help, i've got a Panasonic TX-48AX630 which for the life of me won't play certain MKV files, i've tried converters, used the Panasonic 2013 profile but still now joy. I've ran one of the MKV's through Mediainfo which is below, any help would be great, been converting the MKV to MP4 to get them to work but i feel i'm losing quality and it's taking some time.
Unique ID : 123589142583737470750269409173915722938 (0x5CFA672E4E37703F3D994B44D83264BA)
Complete name : G:\Movies\Forest,_The_(2016)_t00.mkv
Format : Matroska
Format version : Version 2
File size : 17.1 GiB
Duration : 1h 32mn
Overall bit rate : 26.4 Mbps
Movie name : Forest, The (2016)
Encoded date : UTC 2016-07-10 14:55:43
Writing application : MakeMKV v1.9.3 win(x64-release)
Writing library : libmakemkv v1.9.3 (1.3.0/1.4.1) win(x64-release)
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=10
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 32mn
Bit rate mode : Variable
Bit rate : 24.3 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.490
Stream size : 15.8 GiB (92%)
Language : English
Default : No
Forced : No
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 1h 32mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Frame rate : 93.750 fps (512 spf)
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1 003 MiB (6%)
Title : Surround 5.1
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:05:16.441 : en:Chapter 02
00:12:00.344 : en:Chapter 03
00:17:20.497 : en:Chapter 04
00:23:25.153 : en:Chapter 05
00:29:17.589 : en:Chapter 06
00:34:38.284 : en:Chapter 07
00:40:09.865 : en:Chapter 08
00:47:34.935 : en:Chapter 09
00:53:04.681 : en:Chapter 10
00:58:56.908 : en:Chapter 11
01:03:52.328 : en:Chapter 12
01:08:35.069 : en:Chapter 13
01:12:50.407 : en:Chapter 14
01:19:52.454 : en:Chapter 15
01:25:04.849 : en:Chapter 16
and one that works
Unique ID : 291941840517428307430290140573818451472 (0xDBA1F40951C8A948AF84C33B65387610)
Complete name : G:\Movies\The_Abandoned_t00.mkv
Format : Matroska
File size : 16.5 GiB
Duration : 1h 27mn
Overall bit rate : 27.1 Mbps
Movie name : The Abandoned
Encoded date : UTC 2016-06-29 16:53:19
Format : AVC
Format settings, ReFrames : 4 frames
Duration : 1h 27mn
Bit rate : 25.0 Mbps
Maximum bit rate : 32.0 Mbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.504
Stream size : 15.3 GiB (92%)
Language : English
Default : No
Forced : No
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 1h 27mn
Bit depth : 24 bits
Stream size : 941 MiB (6%)
Language : English
Default : Yes
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Language : Spanish
Default : No
Forced : No
Menu
00:07:22.942 : en:Chapter 02
00:13:06.744 : en:Chapter 03
00:19:33.714 : en:Chapter 04
00:28:58.695 : en:Chapter 05
00:35:07.688 : en:Chapter 06
00:43:19.805 : en:Chapter 07
00:49:24.127 : en:Chapter 08
00:56:17.040 : en:Chapter 09
01:03:52.537 : en:Chapter 10
01:12:05.571 : en:Chapter 11
01:22:03.335 : en:Chapter 12
Format : Matroska
Duration : 1h 32mn
Format : AVC
Duration : 1h 32mn
Color space : YUV
Bit depth : 8 bits
Language : English
Default : No
Forced : No
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 1h 32mn
Bit depth : 24 bits
Language : English
Default : Yes
Forced : No
Menu
and one that works
Format : Matroska
Duration : 1h 27mn
Format : AVC
Duration : 1h 27mn
Color space : YUV
Bit depth : 8 bits
Language : English
Default : No
Forced : No
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 1h 27mn
Bit depth : 24 bits
Language : English
Default : Yes
Forced : No
Text #1
Format : PGS
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Language : Spanish
Default : No
Forced : No
Menu
