23424 port
bengio
Post Wed Aug 05, 2015 9:14 pm
23424 port
HI. I Tried to reinstall Serviio on my NAS Synology DS213J but after the confirmation of the package installation Serviio
I get the following error message " The port 23424 configured for this package is used by another service or is reserved for system usage . Disable or change the conflicting service or contact the developer to change the configuration of the package ". I tried to open the port 23424 on both the firewall nas that the router but still get the same message . how can I check and eliminate this conflict ?
Thanks a lot. Hello
ServiiGo beta tester
pepa.sajdler
Post Sat Aug 08, 2015 10:58 pm
Re: 23424 port
It has nothing to do with firewall - some process keeps using the port. If it runs on linux try 'netstat -lp' (I don't know Synology so you might need to goggle for a proper command), and look what is on port 23424.
Odesláno z mého A0001 pomocí Tapatalk
patters
Post Tue Nov 10, 2015 3:38 pm
Re: 23424 port
Sometimes on Synology when you uninstall and then reinstall in quick succession this can happen. Usually if it really insists, a reboot fixes it.
bengio
Post Wed Nov 11, 2015 5:08 pm
Re: 23424 port
Yes with hard reset I solved
Inviato dal mio LG-D802 utilizzando Tapatalk
BuVo
Post Wed Feb 03, 2016 9:53 am
Re: 23424 port
Hi patters,
I use a DS213 and have installed Serviio 1.5.2.-0028
But when tying to install 0029 I got the error: Conflict with port 23423 ...
23423 (!) not 23424 -> I can't resolve the problem ?!?!
The firewall do have entry for the 23423 Consol and 23424 MediaBrowser
I wan't uninstall serviio 1.5.2 because I fear I can't install 1.6 at all and than I don't have a mediaserver now more ...
Do you have a tipp to sesolve the problem?
Or can you give me a link to a 1.5.2 spk full install to have a relapse try?
Than I can uninstall 1.5.2 and than make a new install try to version 1.6 ?
Thanks Burkhard
paniko
Post Wed Feb 03, 2016 11:40 am
Re: 23424 port
bengio wrote:Yes with hard reset I solved
I tried with a reboot but it doesn't resolve my problem...
this is my netstat. no one service is on the oirt 23424
tcp 0 0 127.0.0.1:412 0.0.0.0:* LISTEN 15291/nginx.pid; da
tcp 0 0 127.0.0.1:4700 0.0.0.0:* LISTEN 10992/cnid_metad
tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 11425/smbd
tcp 0 0 0.0.0.0:990 0.0.0.0:* LISTEN 7974/sshd
tcp 0 0 0.0.0.0:161 0.0.0.0:* LISTEN 8575/snmpd
tcp 0 0 0.0.0.0:873 0.0.0.0:* LISTEN 7964/rsync
tcp 0 0 0.0.0.0:3306 0.0.0.0:* LISTEN 14964/mysqld
tcp 0 0 0.0.0.0:554 0.0.0.0:* LISTEN 13877/ssrtspserverd
tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 11425/smbd
tcp 0 0 0.0.0.0:21 0.0.0.0:* LISTEN 10935/ftpd
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 7974/sshd
tcp 0 0 0.0.0.0:631 0.0.0.0:* LISTEN 10695/cupsd
tcp 0 0 127.0.0.1:5432 0.0.0.0:* LISTEN 11386/postgres
tcp 0 0 10.10.10.200:58286 59.120.128.164:80 TIME_WAIT -
tcp 0 0 10.10.10.200:40085 216.58.212.100:443 TIME_WAIT -
tcp 0 0 10.10.10.200:445 10.10.10.205:57866 ESTABLISHED 19452/smbd
tcp 0 0 10.10.10.200:48201 59.120.128.163:80 TIME_WAIT -
tcp 0 0 10.10.10.200:53904 59.124.41.250:81 TIME_WAIT -
tcp 0 0 10.10.10.200:55696 54.93.211.135:443 ESTABLISHED 15595/synorelayd
tcp 0 0 10.10.10.200:43232 59.120.128.165:80 TIME_WAIT -
tcp 0 288 10.10.10.200:22 10.10.10.205:57872 ESTABLISHED 19514/1
tcp 0 1 10.10.10.200:43241 59.120.128.165:80 FIN_WAIT1 -
tcp 0 0 10.10.10.200:43233 59.120.128.165:80 TIME_WAIT -
tcp 0 0 10.10.10.200:59022 216.58.212.68:443 TIME_WAIT -
tcp 0 0 10.10.10.200:58195 108.160.172.237:443 ESTABLISHED 15125/syno-cloud-sy
tcp 0 0 10.10.10.200:43237 59.120.128.165:80 TIME_WAIT -
tcp 0 0 10.10.10.200:43236 59.120.128.165:80 TIME_WAIT -
tcp 0 0 10.10.10.200:58292 59.120.128.164:80 TIME_WAIT -
tcp 0 0 10.10.10.200:43227 59.120.128.165:80 TIME_WAIT -
tcp 0 0 10.10.10.200:55680 82.147.22.211:80 TIME_WAIT -
tcp 0 0 10.10.10.200:40505 74.125.232.145:443 TIME_WAIT -
tcp 0 0 10.10.10.200:43238 59.120.128.165:80 TIME_WAIT -
tcp 0 0 ::%134877389:445 ::%134877389:* LISTEN 11425/smbd
tcp 0 0 ::%134877389:990 ::%134877389:* LISTEN 7974/sshd
tcp 0 0 ::%134877389:8000 ::%134877389:* LISTEN 9830/httpd
tcp 0 0 ::%134877389:8800 ::%134877389:* LISTEN 9830/httpd
tcp 0 0 ::%134877389:8001 ::%134877389:* LISTEN 9830/httpd
tcp 0 0 ::%134877389:8801 ::%134877389:* LISTEN 9830/httpd
tcp 0 0 ::%134877389:161 ::%134877389:* LISTEN 8575/snmpd
tcp 0 0 ::%134877389:515 ::%134877389:* LISTEN 7944/inetd
tcp 0 0 ::%134877389:548 ::%134877389:* LISTEN 10991/afpd
tcp 0 0 ::%134877389:5000 ::%134877389:* LISTEN 9830/httpd
tcp 0 0 ::%134877389:6281 ::%134877389:* LISTEN 11192/img_backupd
tcp 0 0 ::%134877389:5001 ::%134877389:* LISTEN 9830/httpd
tcp 0 0 ::%134877389:873 ::%134877389:* LISTEN 7964/rsync
tcp 0 0 ::%134877389:139 ::%134877389:* LISTEN 11425/smbd
tcp 0 0 ::%134877389:9900 ::%134877389:* LISTEN 9830/httpd
tcp 0 0 ::%134877389:9901 ::%134877389:* LISTEN 9830/httpd
tcp 0 0 ::%134877389:5006 ::%134877389:* LISTEN 11268/httpd
tcp 0 0 ::%134877389:9007 ::%134877389:* LISTEN 9830/httpd
tcp 0 0 ::%134877389:80 ::%134877389:* LISTEN 15393/httpd
tcp 0 0 ::%134877389:9008 ::%134877389:* LISTEN 9830/httpd
tcp 0 0 ::%134877389:21 ::%134877389:* LISTEN 10935/ftpd
tcp 0 0 ::%134877389:22 ::%134877389:* LISTEN 7974/sshd
tcp 0 0 ::%134877389:631 ::%134877389:* LISTEN 10695/cupsd
tcp 0 0 ::%134877389:7000 ::%134877389:* LISTEN 9830/httpd
tcp 0 0 ::%134877389:7001 ::%134877389:* LISTEN 9830/httpd
Paniko
Sumsung EU46D6500 | XBox 360 | Samsung Galaxy S 6 Edge | Windows 10 - i7 64bit | Serviio 1.5.2 Pro
Beta Tester
patters
Post Fri Feb 05, 2016 12:28 pm
Re: 23424 port
This is how you can migrate your library without losing it:
viewtopic.php?f=14&t=3311&start=220#p106588
paniko
Post Fri Feb 05, 2016 12:58 pm
Re: 23424 port
thanks it was so helpfull.. thanks
Paniko
Beta Tester
catalano
Post Thu Feb 11, 2016 4:36 am
Re: 23424 port
Has there been any more progress on this problem? I also cannot do the upgrade. I have no idea about logging in as root, so maybe there's an easier way.
Thank you.
patters wrote:This is how you can migrate your library without losing it:
paniko
Post Thu Feb 11, 2016 7:48 am
Re: 23424 port
It's easy..
Download putty.exe (google it)
Open putty.exe and set your synology ip and check ssh port
Then login as user: root
Pwd: your admin password
Then copy and paste this commands:
cp -R /var/packages/Serviio/target/library /volume1/@tmp/
Uninstall Serviio 1.5.2. Install Serviio 1.6 but don't start it. Then:
rm -rf /var/packages/Serviio/target/library
mv /volume1/@tmp/library/ /var/packages/Serviio/target/
Paniko
Beta Tester
catalano
Post Thu Feb 11, 2016 1:19 pm
Re: 23424 port
Well, that does sound easy. But unfortunately I'm a Mac user.
paniko wrote:It's easy..
Post Thu Feb 11, 2016 1:34 pm
Re: 23424 port
catalano
Post Thu Feb 11, 2016 2:30 pm
Re: 23424 port
Ah, well that makes sense!
Thank You.
DenyAll wrote:https://www.quora.com/What-is-the-equivalent-of-PuTTY-for-Mac-OS-X
Keesmod
Post Fri Apr 08, 2016 2:16 pm
Re: 23424 port
Hi there,
Upon updating Serviio I get the following text:
Quote:
Serviio: Port undefined configured for this package is either used by another service for system use. Please disable or modify the conflicting service, or contact the developer to modify the package configuration.
Unquote.
I tried extra rebooting as well as the putty.exe method as discribed in previous posts.
Rebooting did not help and the putty.exe program can't find/connect to my Synology.
Totally stumped here.
Please help.
Warm regards,
Keesmod
patters
Post Tue Apr 26, 2016 7:38 pm
Re: 23424 port
If you can't do the manual steps for whatever reason, the other workaround is to completely remove Serviio (you will lose your library). Reboot the NAS, and reinstall. You will then have to re-scan the whole library again.
olivex
Post Wed Jun 01, 2016 10:38 pm
Re: 23424 port
How to completely remove serviio?
olivex
Post Sat Jun 04, 2016 2:03 am
Re: 23424 port
Serviio is not in package list already. But how to check if there is any rubbish left?
patters
Post Tue Jul 19, 2016 12:37 pm
Re: 23424 port
The Serviio package for Synology saves its data in the following locations:
/var/packages/Serviio - files relating to the way the package interacts with the OS, startup & install scripts
/var/packages/Serviio/target - the main Serviio application folder like you'd expect in C:\Program Files in Windows
/volume{X}/public/serviio/plugins - online content plugins (not cleaned up after uninstall since users are likely to want persistence)
/volume{X}/public/serviio/fonts - fonts for subtitle burning (not cleaned up after uninstall since users are likely to want persistence, but when new versions of the free deja-vu font are bundled, the old ones are removed).
/volume{X}/@tmp/Serviio - temp folder for transcoding jobs (/volume{X}/@tmp is deleted automatically every time the NAS boots)
/var/packages/Serviio_db_migration - this folder is used temporarily during package version upgrades to preserve the existing media database. If somewhow the upgrade went wrong it is possible this folder could still exist afterwards.
/usr/local/etc/services.d/Serviio.sc - the DSM firewall will leave the service definition file here. Sometimes due to what seems to be a DSM bug this will not be uninstalled properly when the package is removed. This file can be deleted to prevent the package installation error of the port already being in use.
Users browsing this forum: Bing [Bot] and 23 guests
