Synology NAS installing legacy Serviio package versions
patters
Post Sun Jan 29, 2017 3:00 pm
A few people have requested access to the old Serviio package versions because they wish to keep their NAS on older DSM versions. I don't have the hosting space to keep the old native binary files available on the package repository so I've moved them to a Dropbox. Firstly, download the relevant native binary archive for your system (or all of them if in doubt) and store it in the /volume1/public folder which the package will check automatically during installation when the web download fails. Both the Serviio 1.5 and 1.6.1 package versions used the same native bins files below:
serviio1.5-native-armv5tel.tar.xz
serviio1.5-native-armv7l.tar.xz
serviio1.5-native-armhfneon.tar.xz
serviio1.5-native-ppc.tar.xz
serviio1.5-native-i686.tar.xz
serviio1.5-native-i686-add.tar.xz (was needed for DSM 5.x on one very specific large rack-mount NAS I think - if FFmpeg won't run on i686 you need to unpack this file in /var/packages/Serviio/target/lib after installation
serviio1.5-native-i686evansport.tar.xz
serviio1.5-native-x64.tar.xz
The legacy package .spk files themselves can be found at http://packages.pcloadletter.co.uk/downloads/old
You can download these and install them manually in DSM Package Center.
hipporoll
Post Sun Jan 29, 2017 9:59 pm
Re: Synology NAS installing legacy Serviio package versions
Thanks a lot. By downgrading Serviio to 1.6.1, I managed to fix the subtitle issue that I wrote on viewtopic.php?f=5&t=22531&p=112113#p112113.
piponato
Post Thu Mar 30, 2017 10:12 pm
Please, could you upload files again ?. I need serviio1.5-native-i686.tar.xz file.
Best regards,
patters
Post Sat Apr 01, 2017 10:25 pm
Sorry - Dropbox decided to disable all public file sharing on the 15th March 2017 :(
https://www.reddit.com/r/dropbox/commen ... h=1b0c94b3
I don't have room in my regular hosting plan to keep old versions of these files without going up to the next plan which costs quite a lot more.
patters
Post Sat Apr 01, 2017 10:33 pm
Ok, that Reddit thread allowed me to work around the new restrictions and re-create the direct links. The files are available once again.
piponato
Post Sun Apr 02, 2017 12:59 pm
Thanks a lot. :)
My synology platform can not upgrade to DMS6, so I have to use serviio 1.6.1.
