Serviio server on WD My Book Live
Someone tried successfully to install serviio on Western Digital My Book Live?
If so, can you make a step by step guide for a newbie in Linux?
Thanx
joaorsfonseca wrote:I am affraid to try it because i've never tryed any linux commands. And if anything goes wrong, waranty will be avoided
zip wrote:joaorsfonseca wrote:I am affraid to try it because i've never tryed any linux commands. And if anything goes wrong, waranty will be avoided
So I'm not sure what you're asking for..
tozevv wrote:After several attempts I was able to make serviio run with MyBook Live:
5. Install ibm java - it's a 1.6 version. Grab the 32bit IBM POWER Install anywere J2SE version from http://www.ibm.com/developerworks/java/jdk/linux/download.html
6. Install serviio tgz package
7. Run Serviio.sh. Make sure JAVA_PATH points to you newly installed IBM JRE
8. Configure serviio console with -Dserviio.remoteHost=<hostname> (check the forum)
9. Set up a init.d script for serviio start / stop with NAS boots. Check this site for instructions http://www.debian-administration.org/articles/28
So far looks great. The box is fast enough to run it smoothly with subtitles, skip/ff and resume - all tested and working fine.
Error while processing resource, sending back 500 error. Message: Transcoded file '/tmp/Serviio/transcoding-temp-125-MPEG2TS.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-125-MPEG2TS.stf' cannot be found, FFmpeg execution probably failed
at org.serviio.delivery.resource.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:115)
jc_slig wrote:Thanks Cerberus,
I got the Serviio server running as a daemon at startup (as shown in forum how to) under a different user which has secondary group root so should be ok for Java.
All seems to be ok, iPad access works fine but the Bravia TV still fails to play the videos.
This points the server running ok and no issues with Java?
I have lost my serviio.log file but would appear to be still around transcoding.
Anything obvious I should be looking at? I have the latest ffmpeg and doing an ffmpeg -i <file> looks ok.
ffmpeg -i "/shares/Public/Shared Videos/TV Shows/TV Show/file.avi" -y -threads 1 -vcodec mpeg2video -b 17000k -maxrate 17000k -bufsize 5097k -r 24000/1001 -g 15 -copyts -acodec ac3 -ab 192k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-125-MPEG2TS.stf
FFmpeg version SVN-r0.5.4-4:0.5.4-1, Copyright (c) 2000-2009 Fabrice Bellard, et al.
configuration: --extra-version=4:0.5.4-1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --disable-stripping --disable-vhook --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdc1394 --disable-altivec --enable-shared --disable-static
libavutil 49.15. 0 / 49.15. 0
libavcodec 52.20. 1 / 52.20. 1
libavformat 52.31. 0 / 52.31. 0
libavdevice 52. 1. 0 / 52. 1. 0
libavfilter 0. 4. 0 / 0. 4. 0
libswscale 0. 7. 1 / 0. 7. 1
built on Mar 27 2011 04:50:25, gcc: 4.4.5
Input #0, avi, from '/shares/Public/Shared Videos/TV Shows/TV Show/file.avi':
Duration: 00:53:15.74, start: 0.000000, bitrate: 1442 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 624x352 [PAR 1:1 DAR 39:22], 23.98 tbr, 23.98 tbn, 23.98 tbc
Stream #0.1: Audio: mp3, 48000 Hz, stereo, s16, 128 kb/s
Unknown encoder 'mpeg2video'
