Convert .m3u in .sob
Paolo
Post Thu May 11, 2017 1:39 pm
I have to import in Serviio a m3u file full of a long list of lines. Too many.
in Serviio online resource, the import export work only with .sob format. unknown format for me.
"search " pushbutton is not helping a lot.
I found a old raw converter in another topic but don't work.
How can I do it ?
Any tool ? any trick ?
Suggestion ? :?
theflima
Post Sun Mar 25, 2018 11:46 am
Re: Convert .m3u in .sob
Paolo wrote:I have to import in Serviio a m3u file full of a long list of lines. Too many.
How can I do it ?
Suggestion ? :?
Post Sun Mar 25, 2018 10:50 pm
The SOB format was created by the Serviio developer for use with Serviio. It's not an available format for other devices. Depending on what's in your m3u playlist, they may not be compatible with Serviio online source requirements. Remember that playlists are typically used for local media, not online resources.
Basically the SOB format tells the Serviio console what type of online resource the entry is (Web Resource, RSS or Live Feed), the media type (video, audio or image), the source URL and the display name. Basically, it just auto-populates the same fields you would use in the console for entering a single resource.
Panasonic ST30 Plasma, Samsung JU7100 4K TV, Sony BDP-S3500, Sharp 4K Roku TV, Roku 2 XS, 4, Ultra and Stick, Yamaha RX-V679 AVR.
Primary server: Intel i5-6400, 8 gig ram, Windows 10 Pro, 18 TB hard drive space | Test server Windows 7 Home Premium, AMD Phenom II X4 965, 8 gig ram
Enable debug logging Identify media file contents
Paul C
Post Sat May 12, 2018 12:22 pm
You can do this using the playlist groovy plugin - see post at viewtopic.php?f=20&t=6022&p=117132#p117132
There are a few issues as I point out but it works.
Serviio 1.9.2 (PRO), DBpoweramp & Asset UPnP (registered), Acer Aspire One netbook, HP Elitebook, Windows 10 Pro, Denon DNP-730AE, NEET AirstreamPro renderer, Naim NAC72/NAP140 (x2), Celestion Ditton 25 and Spendor A5 speakers, WD TV Media Player (x2), Panasonic Blu-ray DMP-BDT360, Panasonic TV, Amazon Fire 7 HDX, BubbleUPnP control app, Mezzmo Android control App, Qobuz streaming.
