[CDS API] Retreiving resources and cover image
kissskoool
Post Mon Aug 05, 2013 1:24 pm
First thanks for all the good work and the well documented APIs.
But i still have some little questions :
- When i browse the medias with the CDS API, i get this value for thumbnailUrl : cds/resource/12/COVER_IMAGE,1
Then i try to retreive the cover image giving this complete url to curl : http://localhost:23424/cds/resource/12/ ... xxxxxxxxxx
But it doesn't work. is it right ?
- My other question is with the browse method.
In this url, /cds/browse/{profile_id}/{object_id}/{browse_method}/{filter}/{start_index}/{requested_count}?authToken={token}, what profile_id stands for ?
Where cab i find the different values for this parameter ?
Thanks !
kissskoool
Post Mon Aug 05, 2013 4:09 pm
Re: [CDS API] Retreiving resources and cover image
I made a little step forward, and i found that the problem wasn't with the url but with my php/curl code.
Now, i retreive the image binary but i'm trying to display it.
Here is my php code :
$url = 'http://localhost:23424/cds/resource/12/COVER_IMAGE,1?authToken=xxxxxxxxxxxxxxxxxxxxxxxxxxxx';
function cds_cover($url) {
   $ch = curl_init();
   curl_setopt($ch, CURLOPT_URL, $url);
   curl_setopt($ch, CURLOPT_RETURNTRANSFER, TRUE);
   curl_setopt($ch, CURLOPT_BINARYTRANSFER, TRUE);
   curl_setopt($ch, CURLOPT_HEADER, FALSE);
   curl_setopt($ch, CURLOPT_HTTPHEADER, array("Content-type: image/jpeg"));
   $res = curl_exec($ch);
   curl_close($ch);
   return $res;
How to show the cover image from the binary ?
Post Mon Aug 05, 2013 4:37 pm
to your original question, profile id is found in application-profiles.xml or profile.xml, try with 'flv_player'
You must also add token at the end of the URL.
kissskoool
Post Mon Aug 05, 2013 11:25 pm
Thanks for your answer !
About my original question, i found the solution if someone has the same problem :
   $ch = curl_init();
   curl_close($ch);
   return $res;
$t = $item->thumbnailUrl;
$t = "http://localhost:23424".$t."?authToken=".$token;
$img = cds_cover($t);
$img = base64_encode($img);
<div class="cover_image">
   <img src="data:image/jpeg;base64,'.$img.'">
</div>
kissskoool
Post Tue Aug 06, 2013 2:07 am
I'm sorry, but all this topic is my mistake :oops: ;/
The previous solution works but is really heavy.
I must be tired because i was writing html with php, setting image sources to localhost links .... :cry:
Forget all i said, and just be careful to set the right url for your cover images :
<img src="http://yourdomain_or_ip:23424/cds/resource/12/COVER_IMAGE,flv_player?authToken=xxxxxxxxxxxxxxxxxxxxxxxxxxxx" />
Sorry !
