unable to add local in Serviio Web UI
LGstudio
Post Sat Oct 19, 2013 12:38 pm
Recently I reinstalled Serviio on my Synology NAS also with the Serviio Web UI. I wanted to add the local folders to the to the Library but it is not able.
This is the problem: https://www.dropbox.com/s/u633ni8oexbgumz/pc5dczc_fail.jpg
There are no folders visible in this dialog, and it is not able to write manually the path into the "Selected Folder" area.
Thank you for your help.
Using: Serviio on Synology DS413j and Sony Bravia KDL-46HX800.
Xmantium
Post Sun Oct 20, 2013 4:39 pm
Re: unable to add local in Serviio Web UI
Are you sure your using the latest web UI 1.5.1 - https://github.com/SwoopX/Web-UI-for-Se ... io-1.3.zip
SwoopX made new GIT repo for the new build
LGstudio
Post Sun Oct 20, 2013 8:32 pm
Xmantium wrote:Are you sure your using the latest web UI 1.5.1 - https://github.com/SwoopX/Web-UI-for-Se ... io-1.3.zip
Thanks, I'll check it
