onlineRepository updates
ptyork
Post Fri Oct 07, 2011 2:38 am
Hi Zip,
I'm finally getting around to finishing the 0.6 version of the WHS add-in. Your management console doesn't support updating online sources. Just add and delete. Can I assume this means that the API doesn't support this? What happens if I POST an onlineRepository with an updated contentUrl or fileType? The docs say it can include "updates," but I wanted to make sure.
Paul
Post Sun Oct 09, 2011 1:47 pm
Re: onlineRepository updates
yes, it should work, based on the ID
Users browsing this forum: Google [Bot] and 10 guests
