[TOOLS] AVI FourCC Changer (Windows)
Post Wed Jan 04, 2012 9:51 am
The AVI FourCC Code changer allows you to change the FourCC code in an AVI file.
The FourCC code is the identification key used by the AVI format to inform itself of which decoder to use for the AVI file playback.
For example, with Sony BDV-S570 or S480, some video refuse to play and says " File is corrupt or not supported".
It seems like the files that don't play are "DivX 5" per MediaInfo.
Any divx files that have problems with then simply change the codec to xvid in both fields using avi fourcc changer.
Download here : http://www.videohelp.com/tools/AVI-FourCC-Code-Changer
Post Wed Jan 04, 2012 2:17 pm
Re: [TOOLS] AVI FourCC Changer (Windows)
