How to Get 3rd Party Apps using Unapproved "Market" devices.
How to Get 3rd Party Android Apps using Unapproved Market/Google Play Devices.
I have a Nextbook 7" Tablet which is not Google approved and so does not have "Market/Google Play" preinstalled. As a result I was unable to download ServiiDroid or ServiiGo which are distributed via "Market/Google Play". With the help of their author and others here is how I installed "Market" on my device and "Successfully Installed"
1. Download the gapps zip corresponding to the android version installed on your device, to your PC.
See the table at http://wiki.rootzwiki.com/Google_Apps#20110120
and get the zip from http://goo.im/gapps/
or for Nextbook 7 which has android 2.3.1 installed, use the download at http://www.mediafire.com/?ql9ba6vaja7lbj9
per http://gunnersbarn.wordpress.com/2011/1 ... premium-7/
2. Unzip the gapps zip and copy the 9 .apk files identified in "gunnersbarn" to your device download directory via SMB, USB connect or SD card.
3. On your device install each of the .apk files. If you get "Unable to Parse" messages it means you got the wrong zip file for your device.
4. Using android "Manage Applications", select "Market" and "Clear data".
5. Reboot your device and turn on WiFi.
6. Start up "Market" and sign in. It made me open a new account on "gmail"
Its really that simple!
