SvtPlay
n3mmr
Post Wed Apr 24, 2013 5:44 am
Re: SvtPlay
ottomatic wrote:
n3mmr wrote:A minor question regarding the use of Pirateplay, a bit OT, but still.
I've tried using the pirateplay.se webapp and AdobeHDS.php to download stuff from SVTPlay, and it fails fairly often.
I' was going to write to the Pirateplay guy and ask, but.... I can't find a contact address anywhere?? Am I going blind??
And am I right in guessing that AdobeHDS.php only ever gets involved in downloading HDS streams ( the "only" bit isn't ever stated explicitly on the pirateplay web page ) and that to get a download command generated from the app I have to find an HDS stream and use that as data to the web app: the AdobeHDS.php script can't possibly be used from the ffmpeg commands generated for HLS streams, or can it??
From the front page of http://pirateplay.se:
Vem?
Vem står för sidan? Det gör jag, Jacques de Laval, licensbetalare. På fritiden utvecklar och underhåller jag Pirateplay.se och Pirateplayer. Man når mig enklast via e-post: jacques[snabel-a]pirateplay.se eller via Twitter.
AFAIK, yes: AdobeHDS.php only ever gets involved in downloading HDS streams.
I assume that the pirateplay app usually suggests HLS streams over HDS precisely for the same reasons as the SvtPlay plugin; because ffmpeg is more a more versatile tool (and the only one supported by Serviio).
Oh, GOOD, I'm going blind...
wapman
Post Tue Apr 30, 2013 11:59 am
Re: SvtPlay
I am trying to get SvtPlay live "kanaler" to work on my Samsung TV, but when I add http://www.svtplay.se/kanaler to my online web resources the only thing I get is an empty folder with that name, same thing if I try "local" by using VLC upnp..I am sure I make some basic misstake but I would be happy if you could point me to it.. 8-)
ottomatic
Post Tue Apr 30, 2013 12:33 pm
Re: SvtPlay
wapman wrote:Hi,
Did you add "Kanaler" as a Web resource type (not the default RSS type)?
wapman
Post Tue Apr 30, 2013 12:46 pm
Re: SvtPlay
Yes I added it as web resource..also tried http://www.svtplay.se/kategorier and that also gives an empty folder...if I put http://www.svtplay.se I get a folder with 2 working streams in it..I try to get this to fly on a Ubuntu 13.04 but it gives the same result when I try it from my friends PC (Windows Vista)...could this have something to do with Java?..and thanks for quick response..Lift my hat for you 8-)
sven
Post Wed May 01, 2013 3:21 pm
Re: SvtPlay
The svtplay plugin works fine with my Samsung TV. Thanks to the hackers who made this possible. :)
Swedish television has moved it's archive to http://www.oppetarkiv.se .The site look like svtplay so maybe the svtplay plugin only needs some small tweeking from a guru to work with the archive as well?
ottomatic
Post Thu May 02, 2013 8:10 am
Re: SvtPlay
wapman wrote:Yes I added it as web resource..also tried http://www.svtplay.se/kategorier and that also gives an empty folder...if I put http://www.svtplay.se I get a folder with 2 working streams in it..I try to get this to fly on a Ubuntu 13.04 but it gives the same result when I try it from my friends PC (Windows Vista)...could this have something to do with Java?..and thanks for quick response..Lift my hat for you 8-)
Wapman: "kategorier" is not supposed to work. You need to select one (or more) of the shows listed on that page. Create one feed for each show.
"Kanaler" are live shows and there still seem to be problems with the serviio command issued for these, and the support for these in ffmepeg.
regards
/ O
ottomatic
Post Thu May 02, 2013 8:12 am
Re: SvtPlay
sven wrote:The svtplay plugin works fine with my Samsung TV. Thanks to the hackers who made this possible. :)
Sven: se further up in this thread. I have posted a prototype for an Öppet Atkiv plugin. It (or rather: Serviio) does not support feeds with åäö in the url, but the other shows should work.
Regards
/ O
csholmq
Post Thu May 02, 2013 2:39 pm
Re: SvtPlay
Regards
/ O
Did you ever file a ticket for that?
ottomatic
Post Thu May 02, 2013 3:00 pm
Re: SvtPlay
Regards
/ O
Ehrm... no. Sorry.
Will do.
/ O
ottomatic
Post Thu May 02, 2013 3:03 pm
Re: SvtPlay
ottomatic wrote:
csholmq wrote:Did you ever file a ticket for that?
Ehrm... no. Sorry.
On the other hand, Öppet Arkiv seem to have shaped up and removed special language characters in URL:s.
http://www.oppetarkiv.se/etikett/titel/ ... elefanter/
/ O
csholmq
Post Thu May 02, 2013 8:36 pm
Re: SvtPlay
ottomatic wrote:
Ehrm... no. Sorry.
/ O
The URL you posted still has Ä in the URL. The individual clips do not though. I filed a ticket.
ottomatic
Post Fri May 03, 2013 6:51 am
Re: SvtPlay
csholmq wrote:The URL you posted still has Ä in the URL. The individual clips do not though. I filed a ticket.
Actually, the URL I posted has escaped Ä:s. (%A4).
So, somewhere along they become unescaped, either when you copy the URL in your browser, or when Serviio passes it to the plugin.
Regards
/ O
csholmq
Post Fri May 03, 2013 11:56 am
Re: SvtPlay
Regards
/ O
You mean like this? http://www.oppetarkiv.se/etikett/titel/Fem%20myror%20%A4r%20fler%20%A4n%20fyra%20elefanter/. This gives me a 404.
ottomatic
Post Fri May 03, 2013 12:29 pm
Re: SvtPlay
csholmq
Post Sat May 04, 2013 8:26 am
Re: SvtPlay
ottomatic wrote:
It turns out the sequence is %C3%A4.
So I mean like this: http://www.oppetarkiv.se/etikett/titel/Fem%20myror%20%C3%A4r%20fler%20%C3%A4n%20fyra%20elefanter/
/ O
That actually works. How did you come up with that?
ottomatic
Post Sun May 05, 2013 8:13 pm
Re: SvtPlay
/ O
It is the url in the link according to MSIE.
JeppeTh
Post Wed Jun 12, 2013 7:41 pm
Re: SvtPlay
ottomatic wrote:I too have a Samsung Bluray with the same problems.
How does this really work - is SVT Play videos possible to play on the samung bluray without transcoding? I at least have believed so since even high resolution episodes works like a charm without my PC working too heavy.
I also tryout Plex from time to time - but here I can't get SVT Play to work without transcoding. And "plex transcoding" seems to be too heavy for my old PC.
ottomatic
Post Thu Jun 13, 2013 8:24 am
Re: SvtPlay
The way it works is (briefly):
If your player (The Samsung Bluray or the Plex player) has a player profile in Serviio, then this profile informs serviio about the player's supported media formats. (If there is no matching profile, then the generic DLNA profile will be used).
When the plugin locates a show, serviio will use ffmpeg to sniff the beginning of the stream to determine the media format of the stream.
If Serviio finds that the stream is encoded with a codec supported by the player, it will not apply transcoding (unless the profile forces it). But the container must also be supported. If not, then serviio will remux the stream. This is another form of re-packing of the stream which is much less cpu-intensive.
HTH.
/ Otto
JeppeTh
Post Thu Jun 13, 2013 10:25 am
Re: SvtPlay
ottomatic wrote:The way it works is (briefly):
HTH.
/ Otto
Ok, but since you have an Samsung (as I also have) I guess you knew if transcoding/remuxing normally is needed or nor for SVT Play?
Or is it possible to see in some log or similar in case transcoding/remuxing is used?
Post Mon Jun 17, 2013 3:26 pm
Re: SvtPlay
Is there still a problem with the accented characters in the URL?
Return to Available plugins
