My solution for integrating Ace Stream with Serviio
AceServiio
Post Sun Dec 23, 2018 6:12 pm
Hi Everyone,
Was not able to find reasonable solution for watching Ace Stream TV channels via Serviio, so I had to create my own ;)
It's not a plugin actually, it's separate SW handling Ace Player and interfacing to Serviio via Playlist plugin shared here: http://forum.serviio.org/viewtopic.php?f=20&t=6022
General features:
- Channel selection from DLNA Client interface (ex., your Smart TV)
- Real-time Ace Content ID extraction right from tracker web pages, no playlist upload / update required (however, it could work directly with Ace Content ID)
- Channel names could be on your local language - for me it's working with Cyrillic (depend on DLNA Client)
- Several clients per one server support. Yes, you can watch different channels at the same time (solution is not perfect, but workable. If you need it - send me a message ;) )
- It's possible to configure individual VLC options per each channel (cropping, for example)
- No huge system requirements / hard installation / any add-ons required
- For you all that stuff is for free !
Requirements:
- Windows PC for server part (tested with Win7x64)
- Serviio installed (tested with Serviio 1.10)
- Ace Engine installed (tested with Ace Stream 3.1.11)
Installation instructions:
Attached !
Ace_Serviio_installation.pdf
(210.01 KiB) Downloaded 3551 times
Ace_Serviio.zip
(336.83 KiB) Downloaded 1419 times
AceServiio
Post Fri Jan 18, 2019 9:11 pm
Re: My solution for integrating Ace Stream with Serviio
New version 2.0.0.11 released !
Changes:
- M3U channel playlists with AceContentID's import
- Channel database managemet
- Resonable multi-client support (could serve up to 32 DLNA clients working in parallel)
- No DLNA client IP configuration needed anymore
- Multi-language support (now it's ru+eng but you could add your own)
- Advanced installer + manual
- Misc. improvements and bigfixes
Enjoy !
Download link: https://yadi.sk/d/PVtnE6uFBfjnpw
AceServiio
Post Wed Jan 23, 2019 5:55 pm
New and probably final version 2.0.0.15 !
- Import playlists in UTF-8
- AceContentID extraction from HTTPS web pages
- Forced scan mode
- Misc.
Download link: https://yadi.sk/d/g9K1lI8P4PMEnw
on3soul
Post Sat May 04, 2019 3:49 pm
Can't make it work, not even with default channels, i've followed exactly the steps on the manual
AceServiio
Post Tue May 21, 2019 10:48 am
New update 2.0.0.17 with some bugxixes:
https://yadi.sk/d/xbATWHBuCq9o4g
If it's not working, please describe what troubles you have exactly
Also I noticed that playlist plugin not working correctly with Serviio higher than 1.10
sake
Post Sat Jun 01, 2019 1:14 pm
Hi AceServiio,
Thank you for creating this nice plugin.
The exact error message that I get though is: Provided URL is not valid 'http://-SW-ufile:///C:/Program Files/Serviio/AceServiio/IPTV.m3u-SW-tVIDEO-SW-lLIVE' :roll: :?:
I use Windows 7 x64 + Serviio 1.10 + AceStream HD 3.1.32
Guys, this issue was connected with the blank space between the two words "Program Files" :shock: Had to change the path in the .ini file to D:\
However, now I experience another issue. Any assistance with this one, please?
P.S. I have copied the file Playlist.groovy in the proper folder: C:\Program Files\Serviio\plugins
AceServiio
Post Sat Jun 01, 2019 4:38 pm
This error means that AceServiio don't have write permission to playlist file (IPTV.m3u) you put in ini file. Try to change playlist path or run AceServiio with administrator rights.
P.S. To get detalied log, put string "log=true" to ini file. You will see it in popup window.
sake
Post Sat Jun 01, 2019 5:22 pm
AceServiio wrote:Hi,
Thanks for the quick reply. All I got was this from the log file:
[20:20:04] Program start
[20:20:08] Init complete
Unfortunately the result was the same when I ran AceServiio with admin rights. I changed the folder ... it`s still the same. Anything else I could be missing here?
Return to Available plugins
