LiveFeeds
Post Wed Jul 11, 2012 4:19 am
LiveFeeds
This groovy is used to play folders of livestreams created as detailed in the wiki GUIDE TO CREATING LIVE STREAM FOLDERS http://wiki.serviio.org/doku.php?id=live_stream_folders
It is posted here for reference along with the other groovys.
LiveFeeds.groovy
LiveFeeds.groovy V4 July 12,2012
(3.01 KiB) Downloaded 9548 times
Post Thu Jul 12, 2012 3:45 pm
Re: LiveFeeds
Version 4 to fix bug if no thumbnail specified
grolschie
Post Thu Jul 19, 2012 8:56 pm
Re: LiveFeeds
This is a very useful plugin. Many thanks.
xs2inattar
Post Mon Jul 23, 2012 6:45 pm
Re: LiveFeeds
JHB, can the livefeeds plugin be updated to include the REFRESH-ON-DEMAND for a live-feed inside the feed folder itself ???
Post Mon Jul 23, 2012 10:30 pm
Re: LiveFeeds
Its the rss folders that would need to contain the refresh link, but it would do no good because tthe previously detected links in the rss will continue to display even if they are no longer live.
grolschie
Post Mon Jul 23, 2012 11:54 pm
Re: LiveFeeds
jhb50 wrote:Its the rss folders that would need to contain the refresh link, but it would do no good because tthe previously detected links in the rss will continue to display even if they are no longer live.
I think the RSS file cached by Serviio anyway until expiry (the expiry is set in the console).
hunnypuppy
Post Mon Feb 02, 2015 1:07 am
Re: LiveFeeds
This no longer works with Serviio 1.5, the default RSS given on the wiki page at the bottom from google sites, none of them work. They all show up empty
Post Thu Sep 24, 2015 2:23 pm
Re: LiveFeeds
The method works fine but you must provide your own list of feeds since those in the wiki have now all expired.
fearandir
Post Sat Sep 26, 2015 5:18 pm
Re: LiveFeeds
it did not work for me.
I created a RSS file and uploaded to sites.google.com. Later, on serviio console refered the url under the RSS/Atom feed section.
I navigate into online folder on my smart tv and not content found...
Post Sat Sep 26, 2015 8:44 pm
Re: LiveFeeds
fearandir wrote:it did not work for me.
How can I help if you don't post your RSS file?
fearandir
Post Wed Sep 30, 2015 6:26 pm
Re: LiveFeeds
https://sites.google.com/site/serviiofu ... futbol.rss
Post Thu Oct 01, 2015 4:09 am
Re: LiveFeeds
links must be unique.. as the wiki says "(To maintain unique http:// link names it is best to use simple http://link1, http://link2 etc. numbered sequentially) "
Yours are all <link>https://sites.google.com/site/serviiofutbol/LiveFeeds_futbol.rss</link>
And the <media:stream urls must be available. All yours are <media:stream url="http://localhost:8902" type="video" /> which requires you to start sopcast first.
It makes no sense to have the same stream for each link, The sopcast groovy is what you should use for sopcast.
Return to Available plugins
