Tou.TV (Canada)(French)
garfdotca
Post Wed Mar 06, 2013 3:05 am
I finally got it to work. A plugin for Tou.TV! :D
tested with 19-2 and Enquete.
ffmpeg 1.1.1 is required, at least it was for me.
I love comments ;)
EDIT: Updated to have different thumbnails for each episodes!
TouTV.groovy
(4.72 KiB) Downloaded 1653 times
Post Wed Mar 06, 2013 8:00 am
Re: Tou.TV
Merci garfdotca pour ce travail, je n'ai pas eu le temps pour réaliser ce plugin, je le testerais ce weekend...
J'ai rajouté un petit logo...
Kewl
Post Thu Mar 14, 2013 12:07 am
Re: Tou.TV (Canada)(French)
garfdotca wrote:I finally got it to work. A plugin for Tou.TV! :D
OK... Quel URL on entre dans l'onglet "Online Sources" de Seviio ? Merci !
MacBook Pro • macOS 10.13 -> Oppo UDP-203 -> Sony XBR-65X750D
garfdotca
Post Thu Mar 14, 2013 1:45 am
Post Sun Mar 17, 2013 1:28 pm
Hi garfdotca,
I suggest some modification on plugin.
Because I had error during items parsing, in fact some media are geo-localized and not available for french user.
So I suggest this following modification that delivered a more explicit 'error message':
On "extractItems" function:
I simply replace .text by .getText("UTF-8") to support special European string char.
and add a test if ( url.url == null )
        if(emission.size() > 0)
            emission.each {
                // Le titre, par exemple 19-2 S01E01
                def title = nomEmission + " " + it.SeasonAndEpisode
                // La date de diffusion
                def episodeDate = it.AirDateFormated
                def newdate = new Date().parse("yyyyMd", episodeDate)
                //Le PID de l'episode
                def pid = it.PID
                def jsonUrl = new URL( API_GETVIDEO_URL + pid).getText("UTF-8")
                def url = new JsonSlurper().parseText(jsonUrl)
                  if ( url.url == null ) {
                     log(url.message)
                  } else {
                     def mediaUrl = (url.url =~ '(.*?)\\?.*')[0][1]
                     //Nos items pour le conteneur, avec le titre, adresse du flux et date de diffusion
                     //swfUrl=http://static.tou.tv/lib/ThePlatform/4.1.2/swf/flvPlayer.swf
                     items += new WebResourceItem(title: title, releaseDate: newdate, additionalInfo: [
                        expiresImmediately: true,
                        cacheKey: nomEmission + it.SeasonAndEpisode,
                        episodeUrlLd: mediaUrl.replaceAll('_800','_500'),
                        episodeUrlMd: mediaUrl,
                        episodeUrlHd: mediaUrl.replaceAll('_800','_3000'),
                        thumbnail: it.ImageThumbNormalF ])
This is the log result :
2013-03-17 14:23:31,801 DEBUG [OnlineLibraryManager] Resource http://www.tou.tv/19-2 not in cache yet, loading it
2013-03-17 14:23:31,801 DEBUG [WebResourceParser] Parsing web resource 'http://www.tou.tv/19-2'
2013-03-17 14:23:31,801 DEBUG [WebResourceParser] Found matching url extractor (TouTV) for resource http://www.tou.tv/19-2
2013-03-17 14:23:31,801 DEBUG [FeedItemUrlExtractor] TouTV: Starting parsing resource: http://www.tou.tv/19-2
2013-03-17 14:23:34,520 DEBUG [FeedItemUrlExtractor] TouTV: Le contenu sélectionné n'est pas disponible dans votre pays
2013-03-17 14:23:34,785 DEBUG [FeedItemUrlExtractor] TouTV: Le contenu sélectionné n'est pas disponible dans votre pays
2013-03-17 14:23:35,066 DEBUG [FeedItemUrlExtractor] TouTV: Le contenu sélectionné n'est pas disponible dans votre pays
2013-03-17 14:23:35,348 DEBUG [FeedItemUrlExtractor] TouTV: Le contenu sélectionné n'est pas disponible dans votre pays
2013-03-17 14:23:35,613 DEBUG [FeedItemUrlExtractor] TouTV: Le contenu sélectionné n'est pas disponible dans votre pays
2013-03-17 14:23:35,910 DEBUG [FeedItemUrlExtractor] TouTV: Le contenu sélectionné n'est pas disponible dans votre pays
2013-03-17 14:23:36,175 DEBUG [FeedItemUrlExtractor] TouTV: Le contenu sélectionné n'est pas disponible dans votre pays
2013-03-17 14:23:36,456 DEBUG [FeedItemUrlExtractor] TouTV: Le contenu sélectionné n'est pas disponible dans votre pays
2013-03-17 14:23:36,737 DEBUG [FeedItemUrlExtractor] TouTV: Le contenu sélectionné n'est pas disponible dans votre pays
2013-03-17 14:23:37,019 DEBUG [FeedItemUrlExtractor] TouTV: Le contenu sélectionné n'est pas disponible dans votre pays
2013-03-17 14:23:37,300 DEBUG [FeedItemUrlExtractor] TouTV: Le contenu sélectionné n'est pas disponible dans votre pays
2013-03-17 14:23:37,581 DEBUG [FeedItemUrlExtractor] TouTV: Le contenu sélectionné n'est pas disponible dans votre pays
2013-03-17 14:23:37,878 DEBUG [FeedItemUrlExtractor] TouTV: Le contenu sélectionné n'est pas disponible dans votre pays
2013-03-17 14:23:38,159 DEBUG [FeedItemUrlExtractor] TouTV: Le contenu sélectionné n'est pas disponible dans votre pays
2013-03-17 14:23:38,440 DEBUG [FeedItemUrlExtractor] TouTV: Le contenu sélectionné n'est pas disponible dans votre pays
2013-03-17 14:23:38,722 DEBUG [FeedItemUrlExtractor] TouTV: Le contenu sélectionné n'est pas disponible dans votre pays
2013-03-17 14:23:39,003 DEBUG [FeedItemUrlExtractor] TouTV: Le contenu sélectionné n'est pas disponible dans votre pays
2013-03-17 14:23:39,003 DEBUG [OnlineContentCacheDecorator] Stored online content 'http://www.tou.tv/19-2' in the cache (online_feeds), returning it
Post Sun Mar 17, 2013 7:27 pm
La source url : http://www.tou.tv/les-aventuriers-de-l-extreme ne fonctionne pas pour moi.
Cela donne par exemple un item avec une une url de type rtsp.
rtsp://medias-rtsp.tou.tv/vodtoutv/_def ... 11_800.mp4
mais il manque une clef hdnea:
rtsp://medias-rtsp.tou.tv/vodtoutv/_def ... a11412ef76
Et puis le changement de résolution _800 -> _3000 ne fonctionne pas (il faut surement calculer une nouvelle clef hdnea).
Post Sun Mar 17, 2013 7:44 pm
As-tu regardé du côté de l'API pour l'Iphone4:
final String API_GETVIDEO_URL = "http://api.radio-canada.ca/validationMedia/v1/Validation.html?appCode=thePlatform&deviceType=iphone4&output=json&connectionType=wifi&idMedia="
Cela renvoie une url de type "HTTP Live Steam" :
http://cp143903-f.akamaihd.net/i/004/mp ... 216a39b24d
#EXTM3U
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=390000,RESOLUTION=480x270,CODECS="avc1.66.30, mp4a.40.2"
http://cp143903-f.akamaihd.net/i/004/mp ... iP0g%3d%3d
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=490000,RESOLUTION=640x360,CODECS="avc1.66.30, mp4a.40.2"
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=854000,RESOLUTION=640x360,CODECS="avc1.66.30, mp4a.40.2"
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=1254000,RESOLUTION=852x480,CODECS="avc1.77.30, mp4a.40.2"
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=61000,CODECS="mp4a.40.2"
Suivant le débit demandé, il faudrait en extraire la ligne correspondante.
GuillauG
Post Mon Apr 22, 2013 12:37 am
Hi, i'm not able to make it work (tou.tv) via Serviio.
I downloaded the .groovy and put it in the addon folder.
When i add a new Online RSS/Atom Feed, let say: http://www.tou.tv/enquete/S2012E22
It never show up in the online folder from my tv. Any idea why?
wha about the ffmpeg 1.1, do i have to do something special to enable it?
Thank you.
Post Mon Apr 22, 2013 7:12 am
GuillauG wrote:When i add a new Online RSS/Atom Feed, let say: http://www.tou.tv/enquete/S2012E22
You have to add as "Web Resource" (not RSS feed).
But it does not work for me (france)
thenamelessthing
Post Thu Feb 27, 2014 4:00 am
J'ai réussi à le faire fonctionner mais la qualité de la video est mauvaise même à la meilleur qualité. J'ai pourtant une excellente bande passante..
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
Return to Available plugins
