einthusan Hindi Movie Plugin
sheikh73
Post Mon Jan 28, 2013 3:30 am
Can anyone please make a plug in for this website. http://www.einthusan.com/movies/index.php?lang=hindi
It offers HD New and old Hindi movies.... Movies are really good quality...
vinothsubramanian
Post Sun Mar 24, 2013 5:45 pm
Re: einthusan Hindi Movie Plugin
einthusan.groovy
einthusan groovy
(5.63 KiB) Downloaded 1602 times
sheikh73
Post Thu Apr 11, 2013 8:37 pm
Thank you very much Bro it is working flawlessly. Can you please add option to search by year? it will easier to load new and old movies in different folder from each other... Here is the link for year link..
http://www.einthusan.com/movies/index.p ... _type=Year
I tried to modify the final link page extractor in the groovy file but it doesn't work properly...
final LINK_PAGE_EXTRACTOR = '&organize=Year&filtered=(.*?)&org_type=Year&page=(.*?)' //'<a href="?lang=hindi&organize=Year&filtered=2012&org_type=Year&page=(.*?)">(.*?)</a>'
I am not a coder so it was just a try....
popeyeg
Post Sun Apr 21, 2013 5:30 pm
I tried to build separate plugin based on Year=2012, but I had no success.
I am not expert in this area but anyone want to take it to next step, I appreciate. DOn't we all learn that way ?
ein2012.groovy
(5.84 KiB) Downloaded 1309 times
sheikh73
Post Sun May 05, 2013 1:51 am
Any progress in your plugin bro?
vinothsubramanian
Post Tue May 14, 2013 3:11 am
See if this works...
Sample links:
http://www.einthusan.com/movies/index.p ... phabetical
Of course Hindi links will work. I am not giving example... ;) ensure that you don't have &page= in your links.
einthusan.groovy
(6 KiB) Downloaded 1287 times
vinothsubramanian
Post Wed May 15, 2013 2:52 am
made an update for showing image.
einthusan.groovy
(6.23 KiB) Downloaded 1429 times
sheikh73
Post Wed May 15, 2013 6:33 pm
Thank you very much......
sheikh73
Post Thu May 16, 2013 7:13 pm
I added blueray link and also music link just to test if it loads but it didnt work.. Can you see if you can add bluray and music option in there also if possible.. Thanks bro sort with years is work good....
vinothsubramanian
Post Thu May 16, 2013 11:59 pm
Can you post the link that you are using...
sheikh73
Post Fri May 17, 2013 2:42 am
Hindi Bluray Year 2013 link
http://www.einthusan.com/bluray/index.p ... _type=Year
this is the hindi Music Link for year 2012-2013
http://www.einthusan.com/music/index.ph ... oser_list=
sheikh73
Post Fri May 17, 2013 2:46 am
Well I just check you need to be a premium user to watch bluray movies. So bluray cant be done but music link can be play ..........
patel1974
Post Thu Mar 27, 2014 4:52 am
all of the sudden my einthusan channel disappeared from my online content of my sony Bravia. it is showing on my serviio console on my online tab of the pc also tried all 3 different as online rss /atom feed ,live stream and web resource and also replaced the einthusan.groovy file on my plugin folder of serviio what could it be wrong if any one has the latest please share with me.... ohh by the way the webl ink for hindi movies is http://www.einthusan.com/index.php?lang=hindi
Thanks in advance
mhawaldar
Post Thu Apr 10, 2014 2:16 am
patel1974 wrote:all of the sudden my einthusan channel disappeared from my online content of my sony Bravia. it is showing on my serviio console on my online tab of the pc also tried all 3 different as online rss /atom feed ,live stream and web resource and also replaced the einthusan.groovy file on my plugin folder of serviio what could it be wrong if any one has the latest please share with me.... ohh by the way the webl ink for hindi movies is http://www.einthusan.com/index.php?lang=hindi
Thanks in advance
I managed to modify the original script and is working for me. Attaching the script that is working for me as of today.
einthusan.groovy
einthusan.groovy
(6.75 KiB) Downloaded 1264 times
mhawaldar
Post Sat Apr 12, 2014 2:56 am
I've made some optimizations to this script.
einthusan.groovy
einthusan.groovy
(8.1 KiB) Downloaded 1499 times
pc5dczc_snc
Post Fri Aug 15, 2014 5:28 am
None of my einthusan content show up on serviio any more.
I see the following errors in the log
2014-08-15 01:08:13,905 DEBUG [FeedItemUrlExtractor] einthusan.groovy: extractItems page_count - 8
2014-08-15 01:08:13,905 DEBUG [FeedItemUrlExtractor] einthusan.groovy: extractItems page_count_var - 8
2014-08-15 01:08:13,994 WARN [FeedUpdaterThread] An error occured while parsing the online resource http://www.einthusan.com/movies/index.p ... phabetical, will try again soon: Unexpected error while invoking plugin (einthusan.groovy): Cannot invoke method replaceAll() on null object
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (einthusan.groovy): Cannot invoke method replaceAll() on null object
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:78)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:181)
at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:198)
at org.serviio.library.online.metadata.FeedUpdaterThread.getOnlineItems(FeedUpdaterThread.java:185)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:108)
Caused by: java.lang.NullPointerException: Cannot invoke method replaceAll() on null object
at org.codehaus.groovy.runtime.NullObject.invokeMethod(NullObject.java:77)
at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.call(PogoMetaClassSite.java:45)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
at org.codehaus.groovy.runtime.callsite.NullCallSite.call(NullCallSite.java:32)
at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.call(PogoMetaClassSite.java:54)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:120)
at einthusan.extractItems(einthusan.groovy:112)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
This is hapenning with all URLs including this > http://www.einthusan.com/movies/index.php?lang=hindi
Any idea why this might be? Any help is greatly appreciated. Thanks.
patel1974
Post Sun Aug 17, 2014 2:20 pm
got the same problem can't see the online einthusan on my tv the april update groovy does not work me either please update it
Return to Plugin requests
