Update Groovy 1.8.6
Lockhead
Post Sun Mar 04, 2012 4:02 pm
Update Groovy 1.8.6
Would it be possible to update Groovy to 1.8.6 in the next update?
I encountered some problems when developing my first plugin. I needed the enhanced getText method and the use of requestProperties. The site didn't liked that there wasn't a User-agent so i couldn't get the right content.
It works for me now because i manually updated it but the i don't want to annoy other users with some update this and that stuff only because of my plugin.
BTW: serviio is awesome!
Post Sun Mar 04, 2012 5:45 pm
Re: Update Groovy 1.8.6
look at the plugin guide. there are some methods you can use to get content with a specific useg-agent
Lockhead
Post Sun Mar 04, 2012 7:52 pm
You mean the openUrl method? Will have a look at that. Thanks!
Post Sun Mar 04, 2012 9:14 pm
yes
Lockhead
Post Tue Mar 06, 2012 7:43 pm
Hm, i'm a little bit clueless.
Whatever i do he doesn't find the method.
groovy.lang.MissingMethodException: No signature of method: Gamestar.openUrl() is applicable for argument types: (java.net.URL, java.lang.String) values: [http://www.gamestar.de/videos/rss/videos.rss, ...]
log and getFFmpegUserAgent works fine.
Post Tue Mar 06, 2012 8:48 pm
look at Vimeo, Hypem or Gamespot plugins on how to use it
Lockhead
Post Tue Mar 06, 2012 9:13 pm
Thanks, helped a lot.
openUrl has to be written as openURL. It's wrong in the documentation.
Post Tue Mar 06, 2012 9:42 pm
thanks, will fix it
Return to Plugin development
