Trying to figure this RSS feed out
Moderator: martyn
sway
Post Wed Jan 16, 2013 4:53 am
I've not had any luck getting the RSS feed for online resources working.
I've added the following RSS feed to the online resources, but nada.
http://www.1tv.ru/rss_item/71
Is there any guide I can use to help me troubleshoot this?
Shawn Way
Non-quite Complete Newbie.
r-win
Post Wed Jan 16, 2013 9:41 am
Re: Trying to figure this RSS feed out
From the Wiki:
Each item in the rss must contain a <title>, a unique http://<link>, a <media:stream and optionally a <media:thumbnail. The <media:stream must contain the live stream url and if it is an audio stream, the stream type for that item. that the groovy will match in order to extract the <media:stream for that item. The groovy will use the unique <link> value to match the item to extract the <media:stream info for that item and pass it to Serviio with the required live attribute. Serviio will then list the valid items in the menu and display the provided <media:thumbnail icon and the item <title>. If no thumbnail is available, that entry in the item must be omitted. (To maintain unique http:// link names it is best to use simple http://link1, http://link2 etc. numbered sequentially)
The RSS feed you've provided doesn't contain a link node as child of each item node. Also, it doesn't contain a media:stream, which means you can't use this RSS feed for Serviio. You'll have to write a WebResource plugin for that.
Besides that, the links in the RSS feed points to webpages, and not to video files. The webpages contain flash movies. So you'll be needing a WebResource plugin which downloads the webpage, extracts the stream url's (if possible), and give that to Serviio.
Linksys WRT320N | Samsung PS-50C7700 | Microsoft XBOX 360 | Windows 8.1 | Linux Ubuntu 13.04
sway
Post Wed Jan 16, 2013 1:04 pm
Thank you very much for explaining it to me. Off to the wiki!
Shawn Way
Return to Video feeds
