HELP NEEDED - Adding SHOUTcast Streams
PC Bigboy
Post Thu Mar 06, 2014 11:06 pm
I have the SHOUTcast website set to open the Winamp player. I open & load the stream in Winamp. I then copy the URL using VIEW FILE INFO in Winamp & paste it into Serviio (Making sure it's set to detect audio of course) but every time I go back to play it back via Serviio (Either on my TV or another device), it won't play By that, I mean the title shows up as being supported data but it won't play :(
Here's an example - http://50.7.79.82:80 (BEWARE - This is Alex Jones' Infowars show)
Post that into Serviio & you'll see (And hear) what I mean :(
Cheers & 73 :)
Pat Cook
Englewood, CO
shomizu9
Post Fri Mar 21, 2014 5:23 am
Re: HELP NEEDED - Adding SHOUTcast Streams
I added that url as an Online Source with the following settings, and it comes through:
Source Type: Live Stream
Source URL: http://50.7.79.82:80
Display Name: Alex Jones Hollering (no offense ;-) )
Media Type: Audio
left thumbnail url blank
Hope the above helps
Stephen Morin
Post Fri Apr 06, 2018 7:42 am
It seems like it's time to update Winamp ...thanks for source
Return to Audio feeds
