Philips TV with DLNA
Post Thu Nov 03, 2011 10:31 am
2009
40PFL9704H
47PFL9664H
2010
46PFL7605H
40PFL7605H
37PFL7605H
52PFL8605H
46PFL8605H
40PFL8605H
37PFL8605H
40PFL8505K
46PFL9705H
40PFL9705K
40PFL9705H
40PFL9715K
58PFL9955H
Format supported over DLNA:
- Vidéo WMV (wmv) : WMV9/VC1
- Audio MPEG (mp2, mp3, mpg, mpeg, vob) : MPEG1 couche 2, MPEG1 couche 3, LPCM, AC3
- Vidéo MPEG4 (mp4) : MPEG-4 AVC (H.264, L2-CIF), MPEG-4 AVC (H.264, L4-HD)
- Audio MPEG4 (mp4) : AAC-LC, AAC-HE
- Vidéo MKV (mkv) : H.264
- Audio MKV (mkv) : HE ACC, AC3
2011
46PFL5806K
55PFL6606H
46PFL6606H
40PFL6606H
37PFL6606H
40PFL6626H
46PFL6626H
40PFL6636H
55PFL6606K
46PFL6606K
40PFL6606K
37PFL6606K
42PFL7406K
42PFL7406H
37PFL7606H
42PFL7606H
47PFL7606H
55PFL7606H
37PFL7606K
47PFL7606K
55PFL7606K
47PFL7666H
42PFL7666H
37PFL7666H
42PFL7676H
42PDL7906H
50PFL7956H
47PFL7696H
46PFL8505H
40PFL8505H
40PFL8606H
46PFL8606H
52PFL9606H
58PFL9956H
Format supported over DLNA (2011 models)
AVI :
- MPEG4 SP, 640 x 480p, 30 fps, 3 Mbps, AAC
- MPEG4 ASP, 720 x 576p, 30 fps, 8 Mbps, MP3 / MPEG1 L2 / AC3
MKV : H.264, 1920 x 1080p, 24 fps, 20 Mbps, HE-AAC / AC3 / MP3 / PCM
TS : MPEG2, 1920 x 1080p, 30 fps, 20 Mbps, MPEG2 L2 / MPEG1
ASF / WMV :
- WMV9 / VC1 SP, 352 x 288p, 15 fps, 0.384 Mbps, WMA
- WMV9 / VC1 MP, 1920 x 1080p, 25 /30 fps, 20 Mbps, WMA
- WMV9 / VC1 AP, 1920 x 1080p, 24 / 30 / 60 fps, 20 Mbps, WMA
MP4 :
- H.264 BP, 720 x 576i, 15 / 30 fps, 5 Mbps, AAC / HE-AAC (V1 & V2) / AC3
- H.264 MP, 720 x 576i, 15 / 30 fps, 10 Mbps, AAC / HE-AAC (V1 & V2) / AC4
- H.264 HP, 1920 x 1080i, 15 / 30 fps, 20 Mbps, AAC / HE-AAC (V1 & V2) / AC5
- MPEG4 ASP, 720 x 576i, 30 fps, 8 Mbps, AAC
PS / MPG / MPEG / VOB :
- MPEG2, 1920 x 1080p, 30 fps, 20 Mbps, MPEG2 L2 / MPEG1 L2 / AC3 / LPCM
- MPEG1, 352 x 288, 30 fps, 1.5 Mbps, MPEG1 L2
GetProtocolInfo
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM_ICO,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T,
http-get:*:audio/x-ms-asf:*,
http-get:*:audio/wav:*,
http-get:*:audio/x-ms-wma:*,
http-get:*:audio/vnd.dlna.adts:*,
http-get:*:audio/mp4:*,
http-get:*:video/x-matroska:*,
http-get:*:video/x-ms-asf:*,
http-get:*:video/x-ms-asf-plugin:*,
http-get:*:video/mpeg4:*,
http-get:*:video/avi:*,
http-get:*:video/x-ms-avi:*,
http-get:*:video/msvideo:*,
http-get:*:video/x-msvideo:*,
http-get:*:video/h264:*,
http-get:*:video/x-ms-wmv:*
These informations come from http://www.lcd-compare.com
With "Generic profile" selected in serviio console, need users to verify this information.
Philips profile
   <Profile id="21" name="Philips" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
            <FriendlyName>.*PHILIPS.*</FriendlyName>
         </UPnPSearch>
      </Detection>
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="video/avi" name="">AVI</MediaFormatProfile>
      </MediaFormatProfiles>
Northguy
Post Fri Jan 20, 2012 12:07 pm
Re: Philips TV with DLNA
What is it exactly that you need verified?
Currently I am running 0.6.1 with 47pfl9706. Serviio does not recognise the specific philips profile, but i can stream my mp3s without problems. Haven`t come round to streaming video though.
Post Fri Jan 20, 2012 2:02 pm
With Serviio 0.6.1 version Philips profile (id=20):
- AVI are delivered in native format with mime-type="video/avi"
- All other video media files are transcoded to MPEG Program Stream with MPEG2 Video and AC3 audio.
On serviio console, could you delete all device, save and restart serviio service, then refresh the device list.
Don' understand!
Do you try select the proper Philips profile on serviio console?
To customize profile for philips devices:
- First use Generic Profile then list all format that were supported in native.
- Second provide information about a file not supported then we will modify the profile in the first post.
Northguy
Post Sun Jan 22, 2012 7:29 pm
Hi there,
I guess that we are missing eachothers point. With:
I meant that I am not very busy with streaming video at the moment. I am currently only using the MP3 streaming of Serviio and still need to figure out the video thing. But given my lack of time at the moment, it is not my highest priority to spend much time on it.
Don' understand!
What I meant is that Serviio does not automatically recognise the device as a Philips device from the HTTP header that the television sends to Serviio (or maybe that is just standard practice?). It is recognised as a device with name NMR and a Generic Profile. See debug log below:
2012-01-22 20:06:37,210 DEBUG [WebServer] Incoming connection from /192.168.1.50:43466
2012-01-22 20:06:37,279 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65 from 192.168.1.50 (headers = [HOST: 192.168.1.10:8895,DATE: Sun, 22 Jan 2012 19:06:34 GMT,CONNECTION: close,USER-AGENT: Windows2000/0.0 UPnP/1.0 PhilipsIntelSDK/1.4 DLNADOC/1.50])
2012-01-22 20:06:37,290 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-01-22 20:06:37,494 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.10:8895,DATE: Sun, 22 Jan 2012 19:06:34 GMT,CONNECTION: close,USER-AGENT: Windows2000/0.0 UPnP/1.0 PhilipsIntelSDK/1.4 DLNADOC/1.50]
2012-01-22 20:06:37,498 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-01-22 20:06:37,645 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.50:49153/nmrDescription.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2012-01-22 20:06:37,647 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer f00dbabe-sa5e-baba-dada188ed53aa2e1 from address /192.168.1.50:42444
2012-01-22 20:06:37,651 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.50:49153/nmrDescription.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2012-01-22 20:06:37,652 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer f00dbabe-sa5e-baba-dada188ed53aa2e1 from address /192.168.1.50:51317
2012-01-22 20:06:37,683 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.50:49153/nmrDescription.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2012-01-22 20:06:37,684 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer f00dbabe-sa5e-baba-dada188ed53aa2e1 from address /192.168.1.50:36515
2012-01-22 20:06:37,942 DEBUG [RendererManager] Adding renderer Renderer [uuid=f00dbabe-sa5e-baba-dada188ed53aa2e1, ipAddress=192.168.1.50, name=NMR, profileId=1, manuallyAdded=false, forcedProfile=false] to list of active renderers
2012-01-22 20:06:38,230 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
I already checked and updated my Sink info into the serviio Wiki. Also added references to the Philips support forum. There they have an XLS file with an overview of all supported formats for televisions (PFL), home cinema sets (HTS) and Blu-ray players (BDP). Isn't it easier to take that as a starting point and change from there on?
Anyway, when I start using the Video stream functionality and encounter any file that cannot be played I will post it here.
Northguy
Post Sun Jan 22, 2012 10:24 pm
Did a quick try of streaming tonight. MKV container with H.264 compression works perfectly on my Philips TV, although I cannot see the embedded subtitles. Don't know if that is a TV or Serviio issue. Please find attached the Mediainfo file, if you are interested.
xxx_hdtv_x264-NLsubs.mkv.txt
(6.89 KiB) Downloaded 1659 times
nirnat
Post Wed Apr 10, 2013 5:46 pm
Having the same problem with Philips 55pfl7606k, cannot get subs to work at all over DLNA.
Any suggestions?
Post Fri Apr 12, 2013 10:30 pm
Enable burned-in subs in the console.
nirnat
Post Tue Apr 16, 2013 8:18 pm
Done that,
Still cannot see subtitles on the TV.
What profile should I use?
Tried the Philips 2010 one.
Post Fri Apr 19, 2013 3:59 pm
Post detailed log of playing the file please.
Return to Philips
