IPTV support
Azique
Post Mon May 10, 2010 4:16 pm
IPTV support
Serviio works like a charm. But I'd like to be able to stream iptv over dlna. Is it possible? for example by adding playlists to library.
The most important feature for me is to switch audio stream, both in iptv and regular video
Post Mon May 10, 2010 4:42 pm
Re: IPTV support
Azique wrote:Serviio works like a charm. But I'd like to be able to stream iptv over dlna. Is it possible? for example by adding playlists to library.
What do you mean by IPTV? Streming from online sources? Or streaming outside local network?
Ad audio, I presume if the player can do it (e.g. pick up different track from mkv) then it's already there.
Azique
Post Mon May 10, 2010 8:43 pm
Re: IPTV support
Well, I mean multicasting.
Also forgot to mention that I am using Samsung LE40B653. And i cannot change audio stream while watching videos over dlna. But this feature works perfectly while using usb
Post Mon May 10, 2010 8:45 pm
Re: IPTV support
Multicasting to the net? Like justin.tv, veetle.com, etc?
Some of the function that the TV offers via usb is not supported by (their) dlna implementation.
Britinva
Post Tue May 11, 2010 8:55 pm
Re: IPTV support
Or do you mean being able to forward the stream from PC TV players like the BBC iPlayer?
DLNAhooray
Post Sat Sep 11, 2010 4:59 pm
Re: IPTV support
@Britinva
That's exactly what I'd like to do: forward the iPlayer display on my laptop to my Panasonic Viera DLNA TV via my home LAN instead of via the VGA and audio cables that I currently have to use. Can Serviio achieve this?
Post Mon Sep 13, 2010 8:47 am
Re: IPTV support
Not at the moment. iPlayer folks also put in some restrictions so that the stream can only be viewed by applications they approve. I think XMBC stopped working with iPlayer recently.
DLNAhooray
Post Fri Nov 19, 2010 9:55 am
Re: IPTV support
How about getting Serviio to display in real time on the TV whatever is being displayed on my PC screen: possible?
Post Fri Nov 19, 2010 1:07 pm
Re: IPTV support
maybe if you manage to make FFmpeg stream it. But wouldn't you just connect the PC via a cable? ;-)
DLNAhooray
Post Fri Nov 19, 2010 1:59 pm
Re: IPTV support
PC is 50m away in another room. Using laptop is clunky & untidy. I'll look at FFmpeg, about which I know nothing (= a bad start for someone with a small brain)
Post Fri Nov 19, 2010 2:03 pm
Re: IPTV support
what do you need it for? screen cast what you're doing, e.g. typying a document or do you intend to play a video on the laptop and watch on the TV?
tombert
Post Sat Nov 20, 2010 6:44 pm
Re: IPTV support
Well - I guess this would be hughe step for serviio and I also do support this - knowing that it wont be easy.
I already requested this for JRMC (which is my Audio/Video/Pic Manager) and put some screenshorts of TeamMedia Portal here as a good example here:
http://www.pix01.com/gallery/5775C91F-C ... o_Config/#
TeamMedia Portal isn't DLNA, but the Online Video plugin is super cool. It allows you to use all the free content of the internet:
http://tvthek.orf.at/
http://www.3sat.de/nano/nano_titel.html
... and 100!reds more like MTV, GoTV, ZDF, BBC, ...
directly integrated into the Player.
It uses XML files in order to define/configure where to find streams and programms for each Provider.
Grga001
Post Fri Feb 18, 2011 10:26 pm
Re: IPTV support
Hi!
Is it possible to forward IPTV MPEG4 stream with VLC like play list to DLNA able device.
I can acess IPTV streams normaly from my PC with a diffrent LAN card in MULTICAST range.
For DLNA Playback I will use Samsung 6 Series LCD TV.
Example from VLC:
#EXTINF:48,FOX Life
#EXTTV:FOXLIFE
udp://@232.4.2.18:5002
tnx Grga
Christopher_Povey
Post Wed Mar 02, 2011 10:22 pm
Re: IPTV support
IPTV would be an excellent feature to add. Shame about BBC restrictions, as Panasonic refuse to add BBC iPlayer to the streaming part of their TV's if they are Freesat enabled, even if you are not using it! :x
Would be good to be able to add others though like 4OD, ITV iPlayer to devices that do not have them in their lists (Sony BDP Blu-ray players for example).
Chris
Running Serviio on Intel Q6700 Windows 7 Ultimate x64 PC feeding a Sony BDP-S570, Pansonic TX-L37G20B, and a XBox 360.
Managed with Serviidroid via HTC One X
cousinitt
Post Wed Mar 23, 2011 3:30 pm
Re: IPTV support
I would like to use serviio for live streams from sites like justin.tv, gomtv.net (Starcraft II) as well as streams from sopcast. At the moment I need to download the archived files and share those which is not optimal :).
Maybe serviio could have a simple plugin system that can give it a list of available videos and the http address of the selected video.
Post Wed Mar 23, 2011 3:55 pm
Re: IPTV support
Add links to the streams (examples) to this ticket pls: https://bitbucket.org/xnejp03/serviio/i ... ideo-feeds
Christopher_Povey
Post Wed Mar 23, 2011 5:37 pm
Re: IPTV support
Would it be possible to make it fully configurable per device? So "channels" could be added and removed as required.
Also if individual users wished to add the beeb iPlayer they could with no come back on the author of Serviio! :)
Chris
Post Wed Mar 23, 2011 6:15 pm
Re: IPTV support
It is my intention, I just need to know what types of streams there are and people are using, so that I can add support for them
Post Wed Mar 23, 2011 6:27 pm
Re: IPTV support
zip wrote:It is my intention, I just need to know what types of streams there are and people are using, so that I can add support for them
safe ones to add that wont cause issues in long run: Hulu, BBC iPlayer, Joost, CBS, NBC, The WB, TV.com, ESPN, NFL, Comedy Central, South Park, Marvel, The Discovery Channel, National Geographic Channel.
just one thing though i think u would have legal issues in certain country if you add justin.tv and gomtv.net has bad reliability issues and is not supported in certain countries..
Christopher_Povey
Post Sat Mar 26, 2011 4:40 pm
Re: IPTV support
I would like:
BBC iPlayer
ITV iPlayer
4OD
Sky Player
Not sure Sky Player is possible as its strict install on one device only.
Chris
Return to Feature requests
