Windows Media Player 12 Profile
Ryster
Post Sun Mar 13, 2011 11:55 pm
Are there plans to add a profile for Windows Media Player 12 at some point?
At present, WMP sees Serviio on the network but when you click on Serviio, it says there are no media files present.
Serviio Pro Purchaser - 24/07/2012
Post Mon Mar 14, 2011 12:06 am
Re: Windows Media Player 12 Profile
no plans, you might use it somehow using XBox profile maybe
patters
Post Mon Mar 14, 2011 9:25 am
I also noticed that. Is Windows Media Player completely non standard compliant (as a client) then?
Post Mon Mar 14, 2011 9:54 am
yer microsoft really messed up the standard when they made wmp12
Post Mon Mar 14, 2011 10:34 am
They expect particular IDs of the containers (e.g. music, artists), they don't claim they are DLNA, they are just UPnP - but AFAIK XBox is using the same IDs so it 'should' work
patters
Post Tue Mar 15, 2011 12:38 am
I tried it just now but WMP can't see anything under either Video or Audio, so it looks broken.
Unrelated - we have a uPnP internet radio made by Revo and it can stream from Serviio perfectly!
Ryster
Post Wed Mar 16, 2011 9:35 pm
If WMP is a no-go then, are there any other windows based media players out there that DO support DLNA that would work with Serviio?
Post Wed Mar 16, 2011 9:36 pm
XBMC
Post Wed Mar 16, 2011 9:37 pm
Ryster wrote:If WMP is a no-go then, are there any other windows based media players out there that DO support DLNA that would work with Serviio?
xbmc :)
akajester
Post Wed Mar 14, 2012 3:06 am
Any update to this? I'd love to be able to play files from serviio in wmp12.
thanks!
-akajester
Post Wed Mar 14, 2012 8:12 am
Its not going to happen as WMP is not DLNA compliant. While it probably would be possible, it would require a lot of extra work.
XBMC or the new VLC 2.0 work well though.
luckyy
Post Wed Mar 28, 2012 3:21 pm
akajester wrote:Any update to this? I'd love to be able to play files from serviio in wmp12.
thanks!
-akajester
For me, WMP 12 works if I set the DLNA profile in Serviio to XBox 360, for video at least, is all I've used it for.
My .2c :)
Paul C
Post Wed Feb 17, 2016 3:57 pm
Have you thought about using the Serviio MediaBrowser? It works well on Windows PCs and many other devices also.
Return to Feature requests
