Installer Not Working
BillTalent
Post Mon Oct 24, 2022 7:12 pm
Hello Guys,
Just trying to update to 2.3 but having a bit of a weird experience. I'm unable to open the serviio installer. I get the UAC prompt but when I click yes to install nothing happens. Does not matter if I'm using admin permissions installing under compatibility for older windows etc. Since I was having issues I tried uninstalling Serviio but now I can't even get the old installer file (2.2.1) or a fresh download of the legacy version (1.10.1). Seems to be mainly a windows issue (I'm on windows 11) but it's got me completely stumped at this point. Any help or input would be appreacited.
Post Mon Oct 24, 2022 9:51 pm
Re: Installer Not Working
I have no experience with Windows 11, as Microsoft deems every computer I have as ineligible for an upgrade. It sounds like they've made some sort of change to the User Access Control function. About all I can suggest is to open a command prompt as administrator and run the Serviio EXE from there. Sometimes that will override any permissions issue.
BillTalent
Post Mon Oct 24, 2022 10:02 pm
Not having any luck from CMD prompt. I've got an old PC that's not 11 eligible. I can test on that and follow up. I did download on my work PC just as a check and got a warning about the software but I obviously don't have admin rights there to move past it. Likely it's a windows issue like you highlighted. I'll keep plugging away and advise if I get around it somehow. Worst case I can always roll back my machine but that just seems painful for what should be a simple fix.
Post Mon Oct 24, 2022 10:07 pm
I upgraded my backup server to 2.3 yesterday without an issue. That's on the latest version of Windows 10.
Does Windows 11 have a compatibility mode to run an application so it thinks it's on an older version of Windows? It likely does. Right click on the Serviio install program and select Properties. There's a compatibility tab that allows you to select a different OS to emulate. On this Windows 10 PC, I can select Windows 8 all the way back to Windows 95. I would expect Windows 11 to have Windows 10 as an option.
BillTalent
Post Tue Oct 25, 2022 2:07 am
Hey I loaded 2.3 onto my old PC and had no issues. I saved the install file to a flash drive and was able to install without issue. Seems to be some problem associated with the exe being flagged in Edge when I downloaded it. Definitely a Windows 11 issue. Glad I got a workaround though. Can't install the exe from my drive but works off the flash drive no problem. Thanks for reaching out!
Return to General discussion
