Updated List of Live Streams!
Xmantium
Post Thu Jan 19, 2012 10:50 pm
I come across rtmpGUI, brilliant program that uses RTMPDump to play live streams to VLC player
rtmpGUI is a Windows application that uses RTMPDump, and comes with a updated maintained list of channels for you to stream from!! This list of live channels is HUGE! All the URLs and links are provided within the program! Download here - http://forum.wiziwig.eu/threads/58518-rtmpGUI-Offical-thread, video tutorial here
NOTE
You cannot simply enter the "rtmpdump -r" code in Serviio
You MUST CHANGE THE PARAMETERS from RTMPDUMP to LIBRTMP parameters
If you want easy way to find Live streams without changing parameters, follow my XBMC Live Streams guide, this also has a rtmpGUI plugin
UPDATE!
Serviio users took one step ahead of you having to change the parameters manually! Thankyou for your efforts!!
1. RSS livestream Folders
Thanks to the amazing efforts of jhb50, he has created maintained RSS livestream folders, you just copy the RSS feeds from this post into Serviio, make sure you have jhb50's livefeeds.groovy.zip available from the wiki, make you set Serviio to "RSS/Atom Feed"
2. User Chosen RSS Folder Solution
ragefuljoe made a brilliant filter that converts the xml rtmpGUI uses to an RSS folder in Serviio
Firstly go here - http://growing-flower-3635.herokuapp.com, choose the channels you want to view, copy the code to an rss file "LiveFeeds_YourTitle.rss" and host it locally or online, this also needs jhb50 livefeeds.groovy.zip, also make you set Serviio to "RSS/Atom Feed"
NOTE TO LINUX or NAS USERS
You MUST compile ffmpeg with librtmp enabled, without this some feeds will NOT work.
As a test, if you live in the UK, try the 4oD plugin, if those videos dont work then you've not installed ffmpeg with librtmp correctly
WildRushSykes
Post Thu Jan 19, 2012 11:45 pm
Re: Updated List of Live Streams!
According to the latest compiled ffmpeg build for windows rtmp is enabled....
http://ffmpeg.zeranoe.com/builds/readme ... readme.txt
Xmantium
Post Fri Jan 20, 2012 12:09 am
The external libaries compiled into this FFmpeg are:
RTMP git-60218d0a http://rtmpdump.mplayerhq.hu/
Its weird that this works in VLC (you can enable to view command line code in rtmpGUI)
rtmpdump -r rtmp://s7.webport.tv/live/z050001.stream -W http://tvsector.com/mediaplayer/player.swf live=1 -p http://tvsector.com/ -y z050001.stream | "C:\Program Files (x86)\VideoLAN\VLC\vlc.exe" -
But rtsp://s7.webport.tv/live/z050001.stream refuses to play in Serviio, is it because it needs to be wrapped with player.swf?
harperlee
Post Fri Jan 20, 2012 8:48 am
Post Fri Jan 20, 2012 10:58 am
Serviio uses libRTMP, which is the core of rtmpdump. But the parameter you pass to rtmpdump may have different names (but the same functionality).
librtmp: http://rtmpdump.mplayerhq.hu/librtmp.3.html
rtmpdump: http://rtmpdump.mplayerhq.hu/rtmpdump.1.html
Xmantium
Post Fri Jan 20, 2012 2:00 pm
Ahhh!! That worked!!! Thanks zip, i didnt know we can pass parrameters in the URL!
So if you guys want to get rmpt to work, get the url code from rtmpGUI and change
To:
rtmp://s7.webport.tv/live/z050001.stream swfUrl=http://tvsector.com/mediaplayer/player.swf live=1 pageUrl=http://tvsector.com/ playpath=z050001.stream
The other thing aswell, its playing in the correct ratio on my Bravia!! :D
@zip - How did this happen? Previously these HD streams were squashed ratio on my TV, but with parameters its plays correct ratio
mhand
Post Fri Jan 20, 2012 7:56 pm
I've been trying to do the exact same thing but for http://mypremium.tv/ for the past few days but with no joy - though largely because a lot if this stuff is way over my head I will admit.
From digging around in the code on the website I've found the rtmp streams and file id's, for example, the page that plays eurosport points to
rtmp://live.yycast.com:1935/lb/jSmQPgh2uqSD0mt
but however I try to use this in Serviio I get the following message in the logs
2012-01-20 19:37:04,180 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://live.yycast.com:1935/lb/swfUrl=h ... player.swf pageUrl=http://www.streamiton.tv playpath=jSmQPgh2uqSD0mt. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:272)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:208)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:101)
I used streamiton.tv as that was what was mentioned in the code. I've also tried it with tvsector.com but get the saem error. I've also tried writing a plug in by copying some of the existing ones and again get the same error - though I also suspect my plug in code was pants.
The line quoted in the previous post works for me so I know Serviio is working as it should. Any ideas where I'm going wrong ?or am I barking up completely the wrong tree
By the way, I'm on a mac, so can't get the feed address from RMTP dump. And I dont know if it's a similar problem but I can;t get any feeds to work in VLC either, though again that might be my lack on knowledge
Any help greatly appreciated as from what I've read in these forums, this should be fairly strait forward
cheers
Martin
magnoman
Post Sat Jan 21, 2012 9:10 am
@ Mhand
i use that site too for footy streams ect.
I used urlsnooper to get the streaming point which is at the moment.. rtmp://live.yycast.com:1935/live/_defin ... JSEbJ7hv1i
to get that to play in serviio or vlc change the rtmp bit to rstp.. rtsp://live.yycast.com:1935/live/_defin ... JSEbJ7hv1i
Hope that helps.
@Xmantium
Thanks for the work on the tvsector streaming urls for serviio.
Any chance you can help me out with some others ..
i.e rtmp://a1tv.cdnvideo.ru/a1tv-live/ -W http://www.a1tv.ru/player/swf/player.swf -p http://www.a1tv.ru/online/flash/ -y 22 | "C:\Program Files\VideoLAN\VLC\vlc.exe" -
rtmp://95.67.65.136:1935/rtplive -W http://intv.ua/jwplayer/player.swf live=1 -p http://intv.ua/ -y discoveryeurope_m.stream | "C:\Program Files\VideoLAN\VLC\vlc.exe" -
How do i break this one down for serviio. I have tried various combinations and it wont play in serviio. Btw its russian music and discovery in russian for the missus.
much appreciated if you could help then i could relate that to some more russian sites on rtmpgui.
Cheers magnoman
Xmantium
Post Sat Jan 21, 2012 11:16 am
Both videos are working for me in Serviio, i think you including the VLC location, dont include this ;)
These have been tested working in my Serviio, the second one does take some time to load up
rtmp://a1tv.cdnvideo.ru/a1tv-live/ swfUrl=http://www.a1tv.ru/player/swf/player.swf pageUrl=http://www.a1tv.ru/online/flash/ playpath=22
rtmp://95.67.65.136:1935/rtplive swfUrl=http://intv.ua/jwplayer/player.swf live=1 pageUrl=http://intv.ua/ playpath=discoveryeurope_m.stream
Possibly someone can come up with a RTMPDUMP to LIBRTMP parameter converter!
magnoman
Post Sat Jan 21, 2012 11:38 am
Thanks Xmantium
Yeah that works fine :)
RTMPDUMP to LIBRTMP converter! thats a good idea ...
mhand
Post Sat Jan 21, 2012 12:34 pm
Thanks Magnoman. That's brilliant. It now streams using the rtsp link. Slightly off topic, but have you found that the yycast stream id's are volatile ?
magnoman
Post Sat Jan 21, 2012 1:52 pm
@mhand
If you mean they change alot .. yes
i usually urlsnoop them before what i want to watch :lol:
ritzzen
Post Sun Jan 22, 2012 4:54 pm
Please help, I am not able to play this url. when i use rtmpgui, i am able to play most of the channels but when i try to use the link from "cmd" prompt using ffmpeg it fails with following error
C:\Program Files (x86)\Serviio\lib>ffmpeg -i rtmp://95.67.65.136:1935/rtplive sw
nfig
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
rtmp server sent error
rtmp server requested close
rtmp://95.67.65.136:1935/rtplive: Operation not permitted
am i doing anything wrong? even using the same link on serviio, it did not parse or play it.
Here is the serviio log
2012-01-22 11:45:48,628 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmp://95.67.65.136:1935/rtplive swfUrl=http://intv.ua/jwplayer/player.swf live=1 pageUrl=http://intv.ua/ playpath=discoveryeurope_m.stream. It might not play.
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:344)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:87)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:254)
   ... 2 more
My profile is Sony Bravia TV(2011).
Appreciate all help and guidance.
Post Sun Jan 22, 2012 7:15 pm
Nothing to do with Serviio. I could not get it to play using rtmpgui or the rtmpdump command and hence the ffmpeg -i command gave an error as well. Unless ffmpeg can open a stream and display the stream specs, Serviio cannot play it either.
magnoman
Post Mon Jan 23, 2012 12:23 am
yeah looks like the stream is down although it was up a few days ago :(
cbrf7
Post Mon Jan 23, 2012 3:32 pm
Is it known, why I can't stream some Italian live stations like:
rtmp://rtl-livestream4me.weebo.it/live/ swfUrl=http://www.viewmy.tv/player-licensed.swf pageUrl=http://www.viewmy.tv/clip.aspx?srcid=578 playpath=radiovisione_03
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\Andrej>cd C:\Program Files\Serviio\lib
C:\Program Files\Serviio\lib>ffmpeg -i "rtmp://rtl-livestream4me.weebo.it/live/
ffmpeg version N-36890-g67f5650 Copyright (c) 2000-2012 the FFmpeg developers
  built on Jan 16 2012 21:57:13 with gcc 4.6.2
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libope
ncore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en
able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger -
-enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben
c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-
libxvid --enable-zlib
  libavutil      51. 34.100 / 51. 34.100
  libavcodec     53. 56.105 / 53. 56.105
  libavformat    53. 30.100 / 53. 30.100
  libavdevice    53.  4.100 / 53.  4.100
  libavfilter     2. 59.100 /  2. 59.100
  libswresample   0.  6.100 /  0.  6.100
  libpostproc    51.  2.100 / 51.  2.100
Closing connection: NetStream.Play.StreamNotFound
3: Operation not permitted
It plays fine in VLC.
WIN 7, X86, Serviio 0.6.1, Samsung LE40C750, LAN
Post Mon Jan 23, 2012 6:35 pm
can you actually enter this kind of URL to VLC? ie including swfVfy, playpath, etc parameters?
This message is usually caused by wrorng parameters passed to librtmp/ffmpeg. Might also be geo location restriction.
Xmantium
Post Mon Jan 23, 2012 11:22 pm
OK, i checked all the five Italian live streams provided by rtmpGUI
RTL 102.5 TV, with rtmpGUI it took me a few tries to play in VLC (video with audio), in Serviio i used
It did not play in Serviio and got same error as you
I did try the other Italian streams
EuroNews - works fine in Serviio
rtmp://fr-par-1.stream-relay.hexaglobe.net:1935/rtpeuronewslive swfUrl=http://it.euronews.net/media/player_live_1_11.swf pageUrl=http://it.euronews.net/notizie/in-diretta/ playpath=it_video750_flash_all.sdp
Italia1 - also works good in Serviio
rtmp://s7.webport.tv/live/z010502.stream swfUrl=http://tvsector.com/mediaplayer/player.swf live=1 pageUrl=http://tvsector.com/ playpath=z010502.stream
I did try the two other live streams
Sky TG24 - VLC plays audio only, In Serviio doesnt load and has "Unknown video file type" in logs
rtmp://cp49989.live.edgefcs.net:443/live/ swfUrl=http://admin.brightcove.com/viewer/us20110820.1743/federatedVideoUI/BrightcovePlayer.swf pageUrl=http://tg24.sky.it/tg24/diretta.html playpath=streamRM1@2564
Cielo - Again VLC just plays audio only, In Serviio doesnt load and has "Unknown video file type" in logs
rtmp://cp86825.live.edgefcs.net/live swfUrl=http://www.freeetv.com/modules/Video_Stream/plugins/akaim/liveplayer.swf pageUrl=http://www.freeetv.com/ playpath=cielo_std@17630
@zip - Looking at the feeds, could it be URLs with symbols dont play ie "@","?"
Post Mon Jan 23, 2012 11:52 pm
as I said many times, they will only work if ffmpeg -i returns the content description. If it does not Serviio will not serve the file.
cbrf7
Post Tue Jan 24, 2012 7:53 am
zip wrote:can you actually enter this kind of URL to VLC? ie including swfVfy, playpath, etc parameters?
Not realy put in, but open with RtmpGUI, where VLC is set as a player. So it's obvious, that isn't necessary, serviio streams, what VLC does.
Return to Video streams
