Serviio does not start
Charles Francis H.
Post Thu Jul 26, 2018 10:08 pm
Hello, since last Syno Update Serviio does not start :-( I already created a post in NAS install problems category, sorry for repost but maybe there is someone out there reading this post. Servvio gives me my daily entertain- and go-to-sleep-dose so without it I'm going to get crazy :-D
I'm using Serviio Pro long time on Syno DS916 but since todays Syno DSM Update Serviio permanently is "stopped". Clicking "Run" does not help.
Servvio version installed: 1.9.2-0035
DSM version: 6.2-23739 Update 2
Java version: 1.8.0_171-0047
Tried to reinstall Serviio without any change. Is this an actual problem?
viewtopic.php?f=14&t=24649
Post Sat Jul 28, 2018 6:40 pm
Re: Serviio does not start
If you attach a copy of the log we can see what error is showing for a start failure.
Charles Francis H.
Post Tue Jul 31, 2018 8:58 pm
atc98092 wrote:If you attach a copy of the log we can see what error is showing for a start failure.
Thanks for your help but what log do you need? Where can I get/record it? In Synoy protocol center there are no entries when trying to start serviio.
Post Tue Jul 31, 2018 9:26 pm
Not 100% certain where you will find Serviio installed on your NAS, but once you find the install location there will be a serviio.log file in the Log folder. This of course means needing file level access to your NAS. I have no idea how that is accomplished on your device. Some have a user interface, while others require logging in remotely with something like Putty.
Charles Francis H.
Post Tue Aug 07, 2018 7:23 pm
atc98092 wrote:Not 100% certain where you will find Serviio installed on your NAS, but once you find the install location there will be a serviio.log file in the Log folder. This of course means needing file level access to your NAS. I have no idea how that is accomplished on your device. Some have a user interface, while others require logging in remotely with something like Putty.
Accessing Syno via telnet is no problem but where to find a log from which anyone could read what happens when trying to start Servvio App from DSM??
Users browsing this forum: Google [Bot] and 30 guests
