Synology DSM upgrade - will Serviio function after ?
crackedtooth
Post Sun Mar 24, 2013 10:06 am
Synology 212+ NAS , still running DSM 4.1
Intend to upgrade DSM to 4.2
Will that give problems with serviio or its library? ( am running latest serviio on the nas and works a-ok )
Use NAS a lot for the kids and library etc rebuild in past took tons of time...
So will the upgrade most likely be hassle free in relation to serviio ?
patters
Post Mon Mar 25, 2013 8:37 am
Re: DSM upgrade - will serviio function after ?
You will need to stop Serviio, and re-install the Java package after the upgrade. DSM upgrades wipe out the UTF-8 support. Should be fine other than that.
