updated to newest java now serviio wont start
RichRMG
Post Mon May 05, 2014 4:51 pm
updated to the latest version of java (update 7 version55) and now when my computer reboots and tried to start serviio or try to start it manually i get this error:
anyone see this before and know how to fix?
Iveky
Post Mon May 05, 2014 7:04 pm
Re: updated to newest java now serviio wont start
solve your java... then serviio will work:
http://www.java.com/en/download/installed.jsp
zoomerpsu
Post Tue May 06, 2014 4:02 am
I am having the same problem. I uninstalled the newly installed Java update 55.
I used Revo Uninstaller, and made sure all references to it were deleted.
Reinstalled update 55 and I am receiving the same error message window posted by OP.
Post Tue May 06, 2014 7:07 pm
zoomerpsu
Post Wed May 07, 2014 4:01 am
I still can't figure this out.. I have a 64bit system.. so I have the Java update 5. I still cannot get it to work. I've uninstalled and reinstalled so many times.. There has to be a simple solution. This hasn't worked for 3 days now. :/
Iveky
Post Wed May 07, 2014 5:28 pm
java can be so srewed that only system reinstalation helps. google for 'java complete remove'
zoomerpsu
Post Sun May 11, 2014 12:10 am
You mean reinstall the OS?!
I've just reinstalled Serviio again, and it still won't load. I've completely removed Java and reinstalled. I'm not sure what else to do.
Post Sun May 11, 2014 12:50 am
Try this:
If (particularly after the last step) Serviio is not working, start again but this time install the 32 bit version first - some users have reported that the order of installing matters and I can't recall which way around they did it.
