Serviio library not adding files
Hello all,
So i started with Serviio a couple of days ago, i noticed some things where i cannot seem to find an answer to fix them.
My library refreshes but does not add all files or just stops with adding files.
It should give you what files Serviio added but sometimes it doesn't do anything and sometimes after a 1000 files it just stops.
I have my WD TV live connected to it, and i see folders but sometimes there are no files in it actually play and gives an error.
" there is no media to playback" translation from dutch to English but should be clear.
I think this has to do with the library thing.
Anybody of you guys know the answers to these 2 small problems?
If you follow the Dropboxlink below you can find a log file.
https://www.dropbox.com/s/tdgyhnf3rt5pq ... o.txt?dl=0
Thx in advance guys!
