Serviio DLNA ID broadcasts seem very slow
What I mean by this is that Can take up to 15 minutes to appear on media render control points or player devices
Other media servers "Twonky" appears within a minute or so. They are running on different boxes. The second etherport
is bound to br0 for guest machines
System is a big hairy linux box - Some details
stevef >route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default router.asus.com 0.0.0.0 UG 100 0 0 enp5s0
link-local 0.0.0.0 255.255.0.0 U 1006 0 0 br0
192.168.99.0 0.0.0.0 255.255.255.0 U 100 0 0 enp5s0
192.168.122.0 0.0.0.0 255.255.255.0 U 0 0 0 virbr0
239.0.0.0 0.0.0.0 255.0.0.0 U 100 0 0 enp5s0
inxi -F
System: Host: pita-24 Kernel: 4.9.10-200.fc25.x86_64 x86_64 (64 bit)
Desktop: Gnome 3.22.3 Distro: Fedora release 25 (Twenty Five)
Machine: Device: server Mobo: ASUSTeK model: Z10PE-D16 WS v: Rev 1.xx
UEFI [Legacy]: American Megatrends v: 3204 date: 12/18/2015
CPU(s): 2 Multi core Intels (-MCP-SMP-) cache: 61440 KB
clock speeds: max: 3000 MHz 1: 1200 MHz 2: 1200 MHz 3: 1200 MHz
4: 1200 MHz 5: 2944 MHz 6: 1201 MHz 7: 2189 MHz 8: 1200 MHz
9: 1200 MHz 10: 1203 MHz 11: 1282 MHz 12: 1200 MHz 13: 1207 MHz
14: 1200 MHz 15: 1200 MHz 16: 1200 MHz 17: 1236 MHz 18: 1200 MHz
19: 1200 MHz 20: 1200 MHz 21: 2934 MHz 22: 1200 MHz 23: 1200 MHz
24: 1200 MHz 25: 1200 MHz 26: 1202 MHz 27: 1555 MHz 28: 1201 MHz
29: 3005 MHz 30: 1201 MHz 31: 1200 MHz 32: 1200 MHz 33: 1203 MHz
34: 1200 MHz 35: 1200 MHz 36: 1200 MHz 37: 1200 MHz 38: 1201 MHz
39: 1199 MHz 40: 1201 MHz 41: 1295 MHz 42: 1707 MHz 43: 1200 MHz
44: 1441 MHz 45: 2996 MHz 46: 2709 MHz 47: 2685 MHz 48: 2635 MHz
Graphics: Card-1: NVIDIA GP104 [GeForce GTX 1070]
Card-2: NVIDIA GM206 [GeForce GTX 960]
Display Server: Fedora X.org 119.1 drivers: modesetting,nvidia,nouveau (unloaded: fbdev,vesa)
Resolution: 1920x1080@60.00hz, 1920x1080@60.00hz
GLX Renderer: GeForce GTX 1070/PCIe/SSE2
GLX Version: 4.5.0 NVIDIA 378.13
Audio: Card-1 NVIDIA Device 0fba driver: snd_hda_intel
Card-2 Intel C610/X99 series HD Audio Controller
Card-3 NVIDIA GP104 High Definition Audio Controller
Sound: ALSA v: k4.9.10-200.fc25.x86_64
Network: Card-1: Intel I210 Gigabit Network Connection driver: igb
IF: enp5s0 state: up speed: 1000 Mbps duplex: full
mac: 14:dd:a9:d4:ed:d4
Card-2: Intel I210 Gigabit Network Connection driver: igb
IF: enp6s0 state: up speed: 1000 Mbps duplex: full
mac: 14:dd:a9:d4:ed:d5
Drives: HDD Total Size: 12502.5GB (21.4% used)
ID-1: /dev/sda model: ST1000LM014 size: 1000.2GB
ID-2: /dev/sdb model: ST1000DX002 size: 1000.2GB
ID-3: /dev/sdc model: Samsung_SSD_850 size: 500.1GB
ID-4: /dev/sdd model: ST4000DM000 size: 4000.8GB
ID-5: USB /dev/sdi model: 001 size: 2000.4GB
ID-6: USB /dev/sdj model: 02FAEX size: 1000.2GB
ID-7: USB /dev/sdk model: 001 size: 2000.4GB
ID-8: USB /dev/sdl model: 003 size: 1000.2GB
Partition: ID-1: / size: 799G used: 234G (31%) fs: ext4 dev: /dev/sdb5
ID-2: /home size: 3.6T used: 1.9T (54%) fs: ext4 dev: /dev/bcache0
ID-3: /boot size: 594M used: 165M (30%) fs: ext4 dev: /dev/sdb2
ID-4: swap-1 size: 128.00GB used: 0.00GB (0%) fs: swap dev: /dev/sdb3
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: System Temperatures: cpu: 97.5C mobo: 104.0C gpu: 36C
Fan Speeds (in rpm): cpu: 0 fan-1: 0 fan-2: 0 fan-3: 895 fan-4: 0 fan-5: 0 fan-6: 1086
fan-7: 1152 fan-8: 0
Info: Processes: 918 Uptime: 17:03 Memory: 6666.9/128818.8MB
Client: Shell (bash) inxi: 2.3.8
stevef >route
inxi -F
