Cannot connect to the server, it doesn't seem to be running.
PC shut itself down, and on restart Serviio tells me, 'Cannot connect to the server, it doesn't seem to be running...'.
I have trawled the posts on here and tried some of the recommended solutions:
- Uninstall, delete folders reinstall
- Uninstall/ reinstall Java
- Permutations of the above, with plenty of restarts in between...
But all to no avail. Serviio log as follows:
Help!!!! ????
2017-04-01 16:43:56,780 INFO [MediaServer] ------------------------------------------------------------------------
2017-04-01 16:43:56,780 INFO [MediaServer] Serviio DLNA media streaming server v 1.8 (rev. cc55b64588cc)
2017-04-01 16:43:56,780 INFO [MediaServer] Petr Nejedly 2009-2015
2017-04-01 16:43:56,780 INFO [MediaServer] http://www.serviio.org
2017-04-01 16:43:56,780 INFO [MediaServer] Java 1.8.0_91-Oracle Corporation x86
2017-04-01 16:43:56,780 INFO [MediaServer] OS Windows 10 10.0
2017-04-01 16:43:56,780 INFO [MediaServer] File encoding: windows-1252
2017-04-01 16:43:56,811 INFO [MediaServer] Headless mode enabled: true
2017-04-01 16:43:56,811 INFO [MediaServer] User: LENOVO-PC$
2017-04-01 16:43:56,811 INFO [MediaServer] User home dir: C:\WINDOWS\system32\config\systemprofile
2017-04-01 16:43:56,811 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2017-04-01 16:43:56,811 INFO [MediaServer] ------------------------------------------------------------------------
2017-04-01 16:43:56,827 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2017-04-01 16:43:56,842 INFO [DatabaseManager] Using DERBY database language
2017-04-01 16:44:22,745 INFO [DBSchemaUpdateExecutor] Updating DB schema
2017-04-01 16:44:53,911 INFO [DBSchemaUpdateExecutor] Dropping search index
2017-04-01 16:44:53,911 INFO [SearchManager] Starting up search engine
2017-04-01 16:44:54,310 INFO [DBSchemaUpdateExecutor] Cleaning temporary cache
2017-04-01 16:44:54,510 INFO [WebServer] Socket buffer set to 65535 bytes
2017-04-01 16:44:54,510 INFO [Device] Created UPnP Device with UUID: 0121ef4a-a8e4-3075-80ee-802b5f459d46, bound address: 192.168.1.64
2017-04-01 16:44:54,673 INFO [DBSchemaUpdateExecutor] Cleaning persistent cache
2017-04-01 16:44:54,673 WARN [IndexedDiskCache] Region [online_technical_metadata] Reseting cache
2017-04-01 16:44:54,757 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/console) exposed on port 23423
2017-04-01 16:44:54,757 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/rest) exposed on port 23423
2017-04-01 16:44:54,757 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/console) exposed on port 23523
2017-04-01 16:44:54,757 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/rest) exposed on port 23523
2017-04-01 16:45:15,806 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: java.io.IOException: Unable to establish loopback connection
java.lang.RuntimeException: java.io.IOException: Unable to establish loopback connection
at org.serviio.restlet.RestletServer.runServer(RestletServer.java:93)
at org.serviio.MediaServer.main(MediaServer.java:128)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:62)
at com.exe4j.runtime.WinLauncher$2.run(WinLauncher.java:96)
Caused by: java.io.IOException: Unable to establish loopback connection
at sun.nio.ch.PipeImpl$Initializer.run(PipeImpl.java:101)
at sun.nio.ch.PipeImpl$Initializer.run(PipeImpl.java:68)
at sun.nio.ch.PipeImpl.<init>(PipeImpl.java:170)
at sun.nio.ch.SelectorProviderImpl.openPipe(SelectorProviderImpl.java:50)
at java.nio.channels.Pipe.open(Pipe.java:155)
at sun.nio.ch.WindowsSelectorImpl.<init>(WindowsSelectorImpl.java:127)
at sun.nio.ch.WindowsSelectorProvider.openSelector(WindowsSelectorProvider.java:44)
at java.nio.channels.Selector.open(Selector.java:227)
at org.simpleframework.transport.reactor.ActionSelector.<init>(ActionSelector.java:53)
at org.simpleframework.transport.reactor.ActionDistributor.<init>(ActionDistributor.java:141)
at org.simpleframework.transport.reactor.PartitionDistributor.start(PartitionDistributor.java:79)
at org.simpleframework.transport.reactor.PartitionDistributor.<init>(PartitionDistributor.java:65)
at org.simpleframework.transport.reactor.ExecutorReactor.<init>(ExecutorReactor.java:86)
at org.simpleframework.transport.reactor.ExecutorReactor.<init>(ExecutorReactor.java:71)
at org.simpleframework.http.core.ContainerSelector.<init>(ContainerSelector.java:84)
at org.simpleframework.http.core.ContainerProcessor.<init>(ContainerProcessor.java:76)
at org.simpleframework.http.core.ContainerServer.<init>(ContainerServer.java:129)
at org.simpleframework.http.core.ContainerServer.<init>(ContainerServer.java:90)
at org.simpleframework.http.core.ContainerServer.<init>(ContainerServer.java:77)
at org.restlet.ext.simple.HttpServerHelper.start(HttpServerHelper.java:90)
at org.restlet.Server.start(Server.java:588)
at org.restlet.Component.startServers(Component.java:637)
at org.restlet.Component.start(Component.java:562)
at org.serviio.restlet.RestletServer.startComponent(RestletServer.java:172)
at org.serviio.restlet.RestletServer.runServer(RestletServer.java:80)
... 7 more
Caused by: java.net.ConnectException: Connection timed out: connect
at sun.nio.ch.Net.connect0(Native Method)
at sun.nio.ch.Net.connect(Net.java:454)
at sun.nio.ch.Net.connect(Net.java:446)
at sun.nio.ch.SocketChannelImpl.connect(SocketChannelImpl.java:648)
at java.nio.channels.SocketChannel.open(SocketChannel.java:189)
at sun.nio.ch.PipeImpl$Initializer$LoopbackConnector.run(PipeImpl.java:130)
at sun.nio.ch.PipeImpl$Initializer.run(PipeImpl.java:83)
... 32 more
2017-04-01 16:45:15,806 WARN [IndexedDiskCache] Region [subtitles] Disk cache not shutdown properly, shutting down now.
2017-04-01 16:45:15,806 WARN [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2017-04-01 16:45:15,806 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2017-04-01 16:45:15,806 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2017-04-01 16:45:15,806 WARN [IndexedDiskCache] Region [subtitles_metadata] Disk cache not shutdown properly, shutting down now.
2017-04-01 16:46:55,774 INFO [MediaServer] ------------------------------------------------------------------------
2017-04-01 16:46:55,790 INFO [MediaServer] Serviio DLNA media streaming server v 1.8 (rev. cc55b64588cc)
2017-04-01 16:46:55,790 INFO [MediaServer] Petr Nejedly 2009-2015
2017-04-01 16:46:55,790 INFO [MediaServer] http://www.serviio.org
2017-04-01 16:46:55,790 INFO [MediaServer] Java 1.8.0_91-Oracle Corporation x86
2017-04-01 16:46:55,790 INFO [MediaServer] OS Windows 10 10.0
2017-04-01 16:46:55,790 INFO [MediaServer] File encoding: windows-1252
2017-04-01 16:46:55,806 INFO [MediaServer] Headless mode enabled: true
2017-04-01 16:46:55,806 INFO [MediaServer] User: LENOVO-PC$
2017-04-01 16:46:55,806 INFO [MediaServer] User home dir: C:\WINDOWS\system32\config\systemprofile
2017-04-01 16:46:55,806 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2017-04-01 16:46:55,806 INFO [MediaServer] ------------------------------------------------------------------------
2017-04-01 16:46:55,821 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2017-04-01 16:46:55,821 INFO [DatabaseManager] Using DERBY database language
2017-04-01 16:47:01,220 INFO [WebServer] Socket buffer set to 65535 bytes
2017-04-01 16:47:01,220 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/console) exposed on port 23423
2017-04-01 16:47:01,220 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/rest) exposed on port 23423
2017-04-01 16:47:01,232 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/console) exposed on port 23523
2017-04-01 16:47:01,232 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/rest) exposed on port 23523
2017-04-01 16:47:22,262 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: java.io.IOException: Unable to establish loopback connection
... 7 more
... 32 more
2017-04-01 16:47:29,729 ERROR [ApplicationInstanceManager] Error connecting to local port for single instance notification
2017-04-01 16:47:29,729 ERROR [ApplicationInstanceManager] Connection timed out: connect
at java.net.TwoStacksPlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at java.net.Socket.connect(Socket.java:538)
at java.net.Socket.<init>(Socket.java:434)
at java.net.Socket.<init>(Socket.java:244)
at org.serviio.ApplicationInstanceManager.registerInstance(ApplicationInstanceManager.java:105)
at org.serviio.MediaServer.checkForRunningInstances(MediaServer.java:299)
at org.serviio.MediaServer.main(MediaServer.java:118)
2017-04-01 16:47:29,729 INFO [MediaServer] ------------------------------------------------------------------------
2017-04-01 16:47:29,729 INFO [MediaServer] Serviio DLNA media streaming server v 1.8 (rev. cc55b64588cc)
2017-04-01 16:47:29,729 INFO [MediaServer] Petr Nejedly 2009-2015
2017-04-01 16:47:29,729 INFO [MediaServer] http://www.serviio.org
2017-04-01 16:47:29,729 INFO [MediaServer] Java 1.8.0_91-Oracle Corporation x86
2017-04-01 16:47:29,729 INFO [MediaServer] OS Windows 10 10.0
2017-04-01 16:47:29,729 INFO [MediaServer] File encoding: windows-1252
2017-04-01 16:47:29,812 INFO [MediaServer] Headless mode enabled: true
2017-04-01 16:47:29,812 INFO [MediaServer] User: Stuart
2017-04-01 16:47:29,812 INFO [MediaServer] User home dir: C:\Users\user
2017-04-01 16:47:29,812 INFO [MediaServer] Temp dir: C:\Users\user\AppData\Local\Temp\
2017-04-01 16:47:29,812 INFO [MediaServer] ------------------------------------------------------------------------
2017-04-01 16:47:29,814 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2017-04-01 16:47:29,814 INFO [DatabaseManager] Using DERBY database language
2017-04-01 16:47:30,578 INFO [WebServer] Socket buffer set to 65535 bytes
2017-04-01 16:47:30,578 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/console) exposed on port 23423
2017-04-01 16:47:30,578 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/rest) exposed on port 23423
2017-04-01 16:47:30,593 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/console) exposed on port 23523
2017-04-01 16:47:30,593 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/rest) exposed on port 23523
Help!!!! ????
... 7 more
... 32 more
... 7 more
... 32 more
