Drop out every 20 mins
I have an issue whereby when playing a video from my WDTV via my main PC it drops out.
Connected via network cable and not Wifi.
Setting log on debug shows the following....
2017-09-20 02:11:04,347 INFO [UserDataUpdater] Updating user data
2017-09-20 02:11:05,092 INFO [PortMappingChecker] Running a check for external mapping of port 23524 on '110.148.123.61'
2017-09-20 02:11:25,333 WARN [UserDataUpdater] There was an error updating user data
java.net.SocketTimeoutException: connect timed out
at java.net.TwoStacksPlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at sun.net.NetworkClient.doConnect(NetworkClient.java:175)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:463)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:558)
at sun.net.www.http.HttpClient.<init>(HttpClient.java:242)
at sun.net.www.http.HttpClient.New(HttpClient.java:339)
at sun.net.www.http.HttpClient.New(HttpClient.java:357)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1202)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1138)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1032)
at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:966)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1546)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1474)
at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:480)
at org.serviio.util.HttpClient.retrieveStreamFromConnection(HttpClient.java:173)
at org.serviio.util.HttpClient.getStreamFromURL(HttpClient.java:103)
at org.serviio.util.HttpClient.retrieveTextFileFromURL(HttpClient.java:42)
at org.serviio.upnp.service.contentdirectory.rest.access.TuqPortCheckerProvider.isPortOpen(TuqPortCheckerProvider.java:20)
at org.serviio.upnp.service.contentdirectory.rest.access.PortMappingChecker.isPortOpen(PortMappingChecker.java:39)
at org.serviio.upnp.service.contentdirectory.rest.access.UserDataUpdater.isSSLPortOpen(UserDataUpdater.java:178)
at org.serviio.upnp.service.contentdirectory.rest.access.UserDataUpdater.doUpdateUserData(UserDataUpdater.java:101)
at org.serviio.upnp.service.contentdirectory.rest.access.UserDataUpdater.access$200(UserDataUpdater.java:32)
at org.serviio.upnp.service.contentdirectory.rest.access.UserDataUpdater$UserDataUpdaterRunner.run(UserDataUpdater.java:193)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:748)
2017-09-20 02:17:23,740 INFO [PlaybackEventsManager] Playback of media item 2080 (Churchill [churchill.2017.mkv]) has stopped at 28% on Identifier=192.168.178.23, Profile=WDTV Live, Name=WD TV
Anything stand out?
Cheers,
Snoozin
Anything stand out?
Cheers,
Snoozin
