pro version
Posted:
Sat Oct 27, 2018 6:22 am
by 3031
hi
if i buy pro version i have it for any future versions or?
thanks
Re: pro version
Posted:
Sat Oct 27, 2018 6:24 am
by 3031
btw serviigo is not anymore on google play. any other good replacement for it?
Re: pro version
Posted:
Sun Oct 28, 2018 2:24 am
by atc98092
When you buy Pro, it is good until the next major version number update. By major, I mean when he reaches 2.0. Right now he's on 1.10, with no near plans to jump the major version number.
Serviigo is developed by someone other than the Serviio developer. Last I heard, he removed it from the Play store because of an issue, and is currently working through the Google authorization process to get it back in the store. So it will be returning.
